How to fix this air cleaner base? (missing mount) #1137659
12/17/11 01:25 PM
12/17/11 01:25 PM
BDW Offline OP
BDW  Offline OP
I found this and would like to use it. But someone in the past removed the center bar needed to mount the base & the lid.
Any ideas on how this could be fixed on the cheap?
Re: How to fix this air cleaner base? (missing mount) [Re: BDW] #1137660
12/17/11 01:47 PM
12/17/11 01:47 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Put it on the carb then cut, trim and bend a metal strip to fit then rivit it to the base. Shouldn't take more thasn a half hour to do.
Re: How to fix this air cleaner base? (missing mount) [Re: stumpy] #1137661
12/17/11 02:37 PM
12/17/11 02:37 PM
Kirkland, Washington
Pacnorthcuda Offline
Yep--easy fix. You can bolt the bracket to the base or weld it.
Re: How to fix this air cleaner base? (missing mount) [Re: Pacnorthcuda] #1137662
12/17/11 02:50 PM
12/17/11 02:50 PM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Pay attention to what metal you use, and its thickness.
1/16" sheet metal will bend easily....to easily and as you tighten the base to the carb it will distort and bend.
I would stay awy from the hardware stores on this one, head to a metal shop and buy a piece of their scrap/extras.
Re: How to fix this air cleaner base? (missing mount) [Re: NTOLERANCE] #1137663
12/17/11 02:54 PM
12/17/11 02:54 PM
BDW Offline OP
BDW  Offline OP
I thought of the metal strip, but it's a little more complicated because the bar also has to have the 2 studs to hold the lid.
Wasn't there a guy on here who makes fiberglass air cleaners?
Or maybe something from a donor car?
Maybe I could just get this piece and fiberglass/glue it in?
Re: How to fix this air cleaner base? (missing mount) [Re: BDW] #1137664
12/17/11 03:03 PM
12/17/11 03:03 PM
The easiest way is going be a flat bar laid across the opening. Then drill three holes (precisely!) One in the middle over the carb stud, the other two for the 1/4-20 bolts for the lid. Double nut everything. The double nut in the center stud will minimize deflection from tightening the lid.
Install bolts for the lid in the bar to serve as studs for the lid/wing nuts.
Re: How to fix this air cleaner base? (missing mount) [Re: BDW] #1137665
12/17/11 03:41 PM
12/17/11 03:41 PM
Lakeland, FL
sixpakchallenger Offline
Lakeland, FL
2007 Mustang GT Vert
2004 Ram 2500 QC 4X4
1971 Challenger Vert 5.7 Hemi Project
Re: How to fix this air cleaner base? (missing mount) [Re: BDW] #1137666
12/17/11 03:51 PM
12/17/11 03:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Bend a U shape(square edge bends) and drill it in the
correct place... rivet or weld in place... the U will
give you the strength
Re: How to fix this air cleaner base? (missing mount) [Re: sixpakchallenger] #1137667
12/17/11 03:51 PM
12/17/11 03:51 PM
Lakeland, FL
Lakeland, FL
The distance between studs is 6-5/8. Distance between the carb stud and the rear stud is 3-1/2.
Re: How to fix this air cleaner base? (missing mount) [Re: sixpakchallenger] #1137668
12/17/11 03:53 PM
12/17/11 03:53 PM
BDW Offline OP
BDW  Offline OP
Thx for the idea and pic!
I was getting caught up thinking I needed to duplicate the factory set-up.
Would be much easier to attach a flat piece (exactly same shape as the ruler in pic) and then add the holes/bolts.
Just need to make sure it doesn't need to be raised up some.
Re: How to fix this air cleaner base? (missing mount) [Re: BDW] #1137669
12/17/11 03:56 PM
12/17/11 03:56 PM
The length of the base throat should allow a flat piece just fine, but check it first on your carb. If it does need to be raised you just have to bend it into a handle-shape. No big deal.
Re: How to fix this air cleaner base? (missing mount) [Re: Pacnorthcuda] #1137670
12/17/11 06:35 PM
12/17/11 06:35 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
In the spirit of Christmas and to save all the time fabrication something, how would you like it if I sent you this original one I have for say $20.00 shipping included.
It will cost almost that much alone to ship it from Canada.
PM me your address and I'll send it and you can pay me when you receive it.
Hanging up my Santa Claus outfit now...
Re: How to fix this air cleaner base? (missing mount) [Re: mccannix] #1137671
12/17/11 09:20 PM
12/17/11 09:20 PM
NC
rc68rr Offline
rc68rr  Offline
NC
Terry (Mccannix) How nice to see someone be so gracious, especially at this time of year!
Re: How to fix this air cleaner base? (missing mount) [Re: rc68rr] #1137672
12/18/11 12:06 AM
12/18/11 12:06 AM
BDW Offline OP
BDW  Offline OP
That is awesome! PM sent
Re: How to fix this air cleaner base? (missing mount) [Re: mccannix] #1137673
12/18/11 01:32 PM
12/18/11 01:32 PM
indiana
mcmopars Offline
mcmopars  Offline
indiana
seeing your in the spirit,how about a 6 pack set up? and a stock bore hemi if you got it....
Re: How to fix this air cleaner base? (missing mount) [Re: mccannix] #1137674
12/18/11 01:56 PM
12/18/11 01:56 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
i think the mods should tag him as Santa!
Re: How to fix this air cleaner base? (missing mount) [Re: mikemee1331] #1137675
12/18/11 02:45 PM
12/18/11 02:45 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Always nice to see proof that there are good and generous people out there. Of course there are so many more that go unseen.
