Re: How to fix this air cleaner base? (missing mount)
[Re: Pacnorthcuda]
#1137662
12/17/11 02:50 PM
12/17/11 02:50 PM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
Pay attention to what metal you use, and its thickness.
1/16" sheet metal will bend easily....to easily and as you tighten the base to the carb it will distort and bend.
I would stay awy from the hardware stores on this one, head to a metal shop and buy a piece of their scrap/extras.
[Re: BDW]
#1137664
12/17/11 03:03 PM
12/17/11 03:03 PM
Posts: 21,824 Kirkland, Washington
Pacnorthcuda
I thought of the metal strip, but it's a little more complicated because the bar also has to have the 2 studs to hold the lid.
Wasn't there a guy on here who makes fiberglass air cleaners?
Or maybe something from a donor car?
Maybe I could just get this piece and fiberglass/glue it in?
The easiest way is going be a flat bar laid across the opening. Then drill three holes (precisely!) One in the middle over the carb stud, the other two for the 1/4-20 bolts for the lid. Double nut everything. The double nut in the center stud will minimize deflection from tightening the lid.
Install bolts for the lid in the bar to serve as studs for the lid/wing nuts.
[Re: BDW]
#1137666
12/17/11 03:51 PM
12/17/11 03:51 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Bend a U shape(square edge bends) and drill it in the correct place... rivet or weld in place... the U will give you the strength
[Re: sixpakchallenger]
#1137667
12/17/11 03:51 PM
12/17/11 03:51 PM
Posts: 75 Lakeland, FL
sixpakchallenger
Lakeland, FL
The distance between studs is 6-5/8. Distance between the carb stud and the rear stud is 3-1/2.
2007 Mustang GT Vert 2004 Ram 2500 QC 4X4 1971 Challenger Vert 5.7 Hemi Project
#1137668
12/17/11 03:53 PM
12/17/11 03:53 PM
Posts: 4,727 Florida
BDW
Thx for the idea and pic! I was getting caught up thinking I needed to duplicate the factory set-up. Would be much easier to attach a flat piece (exactly same shape as the ruler in pic) and then add the holes/bolts. Just need to make sure it doesn't need to be raised up some.
[Re: BDW]
#1137669
12/17/11 03:56 PM
12/17/11 03:56 PM
Pacnorthcuda
The length of the base throat should allow a flat piece just fine, but check it first on your carb. If it does need to be raised you just have to bend it into a handle-shape. No big deal.
[Re: Pacnorthcuda]
#1137670
12/17/11 06:35 PM
12/17/11 06:35 PM
Posts: 4,784 Ontario, Canada
mccannix
Ontario, Canada
In the spirit of Christmas and to save all the time fabrication something, how would you like it if I sent you this original one I have for say $20.00 shipping included. It will cost almost that much alone to ship it from Canada. PM me your address and I'll send it and you can pay me when you receive it. Hanging up my Santa Claus outfit now...
[Re: rc68rr]
#1137672
12/18/11 12:06 AM
12/18/11 12:06 AM
BDW
[Re: mccannix]
#1137673
12/18/11 01:32 PM
12/18/11 01:32 PM
Posts: 1,012 indiana
mcmopars
indiana
seeing your in the spirit,how about a 6 pack set up? and a stock bore hemi if you got it....
[Re: mccannix]
#1137674
12/18/11 01:56 PM
12/18/11 01:56 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
i think the mods should tag him as Santa!
