Page 3 of 8 1 2 3 4 5 6 7 8
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: BulletBob] #1135444
12/16/11 10:56 PM
12/16/11 10:56 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
The rotors will fit from 84-down. You can use the 4.5 axles from 84-down if you have a 81/4 rear the carrier is the same for those from 1966-1996 [as per Auburn Differential] If you have a 91/4 84' model axles are the key to the swap [according to the Chrysler parts catalog] A true 3/4 ton [1/2"lugs] does not have a pocketed control arm Trucks with 9/16"-5/8" lugs have a pocketed control arm. All vans 78-98 with 1/2" studs have pockets & correct size balljoints. Dakota Drop spindles & a balljoint reamer for the steering arm work. You ream from the opposite side so the tierods don't have to be turned over. A 3" drop spring for a 94up Ram will get you 2". The rear is up to you
. 79-84 not anything older. Bearings changed from the info iv found. 81-84 2wd trucks/rc's are 5x4.5 4wds went to 5.5 in 80. Aint nothing hard about changing rotors or a rear axle so if you want 4.5 its easily obtained. Try looking at Summit Racing for rims in the 5.5bp. Your buddy had to modify those rims or he used spacers
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: BulletBob] #1135445
12/16/11 11:03 PM
12/16/11 11:03 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Ok...that's all I got in truck/van wheel knowledge! Right off hand, I'd say listen to Scratchinfotraction and forget the rest of us...lol. Well, maybe Mopar Jamie too.
Well, I guess the rest of us don't know anything & you're the judge! Can you disprove what I posted? I know that you can't. You're not only disrespectful to me but to everyone else who has posted a reply. This thread was made for a group of replies from more than just a select few of your choosing. W
Please , don't be upset with Jackie , we know each other and he is kinda messing with me
was not pointed at you, trust me
Sorry if you took it wrong ..
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: scratchnfotraction] #1135446
12/16/11 11:05 PM
12/16/11 11:05 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Can you buy new rotors at Napa with the 4 1/2 pattern ?
yes ask for a 83-84 d-150 or 76 newyorker front rotors
they swap right on with the same wheel bearing
I don't suppose you have PN#'S ??
Thanks for everyones help and suggestions too
And the nice words about the little blue truck too
Daryl
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: BulletBob] #1135447
12/16/11 11:06 PM
12/16/11 11:06 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
ok we will say 84 from now on..
I had a 88 318/NP435 shorty.
I thought that it had a 8 1/4, but was quite surprised to find it had a 9 1/4 under it.
A check on the VIN proved it to be original.
I am truckless..
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: 340SHORTY] #1135448
12/16/11 11:14 PM
12/16/11 11:14 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
rear diff
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: 76dodgeboy] #1135449
12/16/11 11:20 PM
12/16/11 11:20 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
The bearing diameter O.D. changed not the I.D. if I remember correctly I've always put an 83/4 in an not messed with either one anyway. I can't say that I'm right all the time for I am not a higher being. I don't claim to be & do not proclaim nor do I judge any of you. BOB
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135450
12/16/11 11:20 PM
12/16/11 11:20 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
rear diff
8.25
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: NITROUSN] #1135451
12/16/11 11:28 PM
12/16/11 11:28 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Ok, can I swap in a earler AKA "better" rear ?
and achieve the 4 1/2 bolt pattern ?
Are those black, 4"+ mouldings on the lower body glued on or bolted on ?
I'd like to make it all dark blue , two tone does not ring my bell
I see no data sheet under the hood , guess Dodge ended that process in these years ?
And, the gear indicator does not work, sure its a cable piece, bet you can't get that anymore
is there a fix , or look in scrap yards ?
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: NITROUSN] #1135452
12/16/11 11:29 PM
12/16/11 11:29 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
rear diff
8.25
Hi Pete !
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135453
12/16/11 11:35 PM
12/16/11 11:35 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Daryl, I'm sorry if I took it wrong. I love your truck, it's a great canvas. I can't wait to get my Shortbed home. Bob
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135454
12/16/11 11:37 PM
12/16/11 11:37 PM
N
N
Hello Daryl. Yes the older 4.5 pattern stuff should swap in. I had 2 trucks this past summer i sent to the scrap yard with the parts you needed. I would of given then to you. Looks like a nice clean cruiser to me.
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135455
12/16/11 11:38 PM
12/16/11 11:38 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
If there's no sheet there's a plate under the cowl grille. Those mouldings have clips w/welded pins Bob
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: BulletBob] #1135456
12/16/11 11:43 PM
12/16/11 11:43 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
It is ok, I hope everyone thown in their
I want to do it right and not make a pile of junk so I like everyones imput
I sadly failed to follow this era well enough because I just never thought I COULD find one nice enough to own
I have found 100's of them but, always they have some kind of major issue .
I wanted a V8, auto, and a driver ..with no large body panel problems
I wanted a 83-84 but, they are getting just old enough any thing I FOUND was beat to death
I wanted a rubber mat , roll windows, no trim stocker in SILVER !!
Make a younger brother to the 70 !
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: NITROUSN] #1135457
12/16/11 11:47 PM
12/16/11 11:47 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
It is for sure, I'd like it to have a little attitude if possible
I hope to be able to find the right parts simple enough ( my, luck .. they are all gone now !
Silk purse out of sows ear
any suggestions will be taken to achieve that
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135458
12/17/11 12:06 AM
12/17/11 12:06 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
I got lucky with my RC. It was parked in 89 or 90 with a bad engine. I paid $250.00 for it. After looking at hundreds with rust. Bob
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135459
12/17/11 12:08 AM
12/17/11 12:08 AM
Round Rock,Tx
N
Nirvana Offline
Nirvana  Offline
N
Round Rock,Tx
Wow
87 D100 225 4 speed.
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: Nirvana] #1135460
12/17/11 12:22 AM
12/17/11 12:22 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Wow
Guess you never seen the 70 ??
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: BulletBob] #1135461
12/17/11 12:25 AM
12/17/11 12:25 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Neighbor has one, super clean, never drives it
stock , red /white I've asked him to sell but,
NOPE !!
SLAMCHARGER !
I looked for those too, guess I'm a pickup man
http://www.youtube.com/watch?v=eGs-T5FNAyc
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135462
12/17/11 12:30 AM
12/17/11 12:30 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
YES... the 4.5 axles will interchange with your 5.5 axles.
if you were closer I have a set of rotors and even a nice set of wheels that would fit.
Id be interested in the fender and door mouldings.. the shortbox moulding wont work on my long box Dually..
I am truckless..
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135463
12/17/11 12:31 AM
12/17/11 12:31 AM
Round Rock,Tx
N
Nirvana Offline
Nirvana  Offline
N
Round Rock,Tx
Wow
Man that thing is gorgeous!
