installing 11/32" valve stemmed valves on iron heads #1135235
12/16/11 02:30 PM
12/16/11 02:30 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
If I were to install 11/32" stem sized 2,14" and 1,81" valves on a set of cast iron OEM mopar big block heads....
which bronze valve guides would I have to use? and where do I get them?
I am asking because I need to do this myself down here in Peru and I need to get the right parts.
thanks
Re: installing 11/32" valve stemmed valves on iron heads [Re: domingo] #1135236
12/16/11 02:57 PM
12/16/11 02:57 PM
dogdays Offline
dogdays  Offline
There's at least two ways that I know about.
Drill and ream the stock valve guides to a 0.500" ID hole, then press in the 0.502" OD guide of your choice. You could even go to 5/16" or 8mm stems, which would be pretty ordinary and would save you valve weight.
You can also insert bronze liners into your existing guide holes which seems to be pretty widely accepted. You may have to ream the guide first to establish a cylindrical guide, then insert then push a ball of the right size through the guide to expand the liner into the guide. Look at the www.goodson.com catalog to see tools for both of these methods.
R.
Re: installing 11/32" valve stemmed valves on iron heads [Re: dogdays] #1135237
12/20/11 02:12 PM
12/20/11 02:12 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
thanks for the advice!
Re: installing 11/32" valve stemmed valves on iron heads [Re: domingo] #1135238
12/20/11 08:13 PM
12/20/11 08:13 PM
New York
polyspheric Offline
polyspheric  Offline
New York
If the RPM and spring pressure are moderate, you can drop the intake down to 5/16" and pick up some CFM.
Boffin Emeritus
Re: installing 11/32" valve stemmed valves on iron heads [Re: polyspheric] #1135239
12/20/11 09:45 PM
12/20/11 09:45 PM
Delray beach, Florida
P
Performance Only Offline
P
could you use the 5/16 valve at .820 lift and 820lbs over the nose? maybe 8000rpm???
machine shop owner and engine builder
Re: installing 11/32" valve stemmed valves on iron heads [Re: Performance Only] #1135240
12/20/11 10:03 PM
12/20/11 10:03 PM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline
hemigod426  Offline
i dont know of any off the self 5/16 383-440 wedge valve, that would be custom made from ferrea valve and $$,them make my roller cam valves 11/32 for 440 and 5/16 for hemi, dont think a 440 head even has enough guide distance for 5/16 valve,hemi has 2x plus
MOPAR OR NO CAR
Re: installing 11/32" valve stemmed valves on iron heads [Re: Performance Only] #1135241
12/21/11 12:13 PM
12/21/11 12:13 PM
New York
polyspheric Offline
polyspheric  Offline
New York
That's so funny!!!
Do you just WAIT there in your trailer for these golden moments, or do you have a life?
Let's play it the other way next time: YOU say something, and I say you're wrong.
Boffin Emeritus
Re: installing 11/32" valve stemmed valves on iron heads [Re: domingo] #1135242
12/21/11 01:02 PM
12/21/11 01:02 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
thanks
Just sitting here in my trailer ...
Do they make stock length valves in that stem size ?
