'02 300M special going into LIMP mode. UPDATE!! #1134980
12/15/11 10:05 PM
12/15/11 10:05 PM
toledo, ohio
plasticfantastic Offline OP
toledo, ohio
Drive my 300m special, after awhile when coming to a stop, the car will make a hard down shift, and then be in limp mode. i can turn the car off and restart it and it will be out of limp mode, but then when i come to another stop, or slow down enough that it would down shift, it will go back into limp mode.
causes?
I read somewhere that the battery cable ends need replaced. will do that tomorrow, but wondered if anyone else had issues or an idea about this?
Re: '02 300M special going into LIMP mode. [Re: plasticfantastic] #1134981
12/15/11 10:15 PM
12/15/11 10:15 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
More likely, it is either the transmission input or output sensors. If either fail, the car goes into limp mode. One of them may be ready to quit. I have heard they are not too expensive or hard to replace yourself (but I have not had to replace mine yet).
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: '02 300M special going into LIMP mode. [Re: plasticfantastic] #1134982
12/15/11 10:26 PM
12/15/11 10:26 PM
Ohio
ralphie361 Offline
ralphie361  Offline
Ohio
Have seen quite a few transmissions do this from plugged filters, if its high mileage and fluid never changed. Loses pressure, and then goes into limp. Let sit for a second, drains back and repeats. May be worth a shot, but best case there is enough material to plug a filter...
Re: '02 300M special going into LIMP mode. [Re: ralphie361] #1134983
12/15/11 11:12 PM
12/15/11 11:12 PM
Columbus, Ohio
wheelsup68dart Offline
Columbus, Ohio
Doug, definitely fix the cable ends before worrying too much about transmission woes. I read an article today in GEARS magazine(a trans speciality mag) about chrysler transmissions being extremely succeptable to faults resulting from not enough voltage/bad grounds. They even say that the car will start fine like no problems with battery but still have problems.
Re: '02 300M special going into LIMP mode. [Re: wheelsup68dart] #1134984
12/16/11 01:49 AM
12/16/11 01:49 AM
toledo, ohio
toledo, ohio
thanks Lonnie, changing the cable ends tomorrow, hope it fixes the issue, if not just hoping to get an idea what would be next step.
Re: '02 300M special going into LIMP mode. [Re: plasticfantastic] #1134985
12/16/11 02:43 PM
12/16/11 02:43 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
My wifes 04 Intrepid did the same thing, it was a solenoid on the valve body.
Re: '02 300M special going into LIMP mode. [Re: justinp61] #1134986
12/16/11 10:37 PM
12/16/11 10:37 PM
toledo, ohio
toledo, ohio
changed the cable ends, took my nephew home and it drove great, until I pulled in his neighborhood and it went into limp mode. suppose i'll send it somewhere and let them figure it out.
Re: '02 300M special going into LIMP mode. [Re: plasticfantastic] #1134987
12/16/11 10:40 PM
12/16/11 10:40 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Have you checked to see what code it's throwing?
Re: '02 300M special going into LIMP mode. [Re: justinp61] #1134988
12/16/11 11:10 PM
12/16/11 11:10 PM
toledo, ohio
toledo, ohio
turn the key 3 times, only code showing is p0456, hook it up to a diagnostic machine, only code showing is p0456.
Re: '02 300M special going into LIMP mode. [Re: plasticfantastic] #1134989
12/17/11 03:36 AM
12/17/11 03:36 AM
Campbellsport, Wisconsin
Abodysforever Offline
I agree with input and output sensors. I have seen a few of these. Good luck keep us posted.
Take it to a dealer, they will give you an absolute acurate diagnostic. They have all the right equipment.
Re: '02 300M special going into LIMP mode. [Re: Abodysforever] #1134990
12/17/11 08:39 AM
12/17/11 08:39 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
My wifes 02 intrepid did same thing trans solenoids. I also have a k/n cold air kit for these cars i need to get rid of.
Re: '02 300M special going into LIMP mode. [Re: Scamp408] #1134991
12/17/11 08:25 PM
12/17/11 08:25 PM
toledo, ohio
toledo, ohio
sent you a PM
Re: '02 300M special going into LIMP mode. [Re: Abodysforever] #1134992
12/27/11 02:40 PM
12/27/11 02:40 PM
toledo, ohio
toledo, ohio
ended up being the valve body, $810, getting it fixed today.
Re: '02 300M special going into LIMP mode. [Re: plasticfantastic] #1134993
12/27/11 04:30 PM
12/27/11 04:30 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
May have been a solenoid in the solenoid pack as it comes on the valve body also. Some places take no chances and replace the valve body with the solenoid pack. Glad you got it fixed. Ron
Re: '02 300M special going into LIMP mode. [Re: 383man] #1134994
12/27/11 04:47 PM
12/27/11 04:47 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I remember my sister's minivan having similar issues. All the shops wanted to rebuild the transmission.
I fixed it by replacing the wire connectors to the solenoid pack. It cost less than $20.
- Stu Harmon
Re: '02 300M special going into LIMP mode. [Re: feets] #1134995
12/28/11 01:38 PM
12/28/11 01:38 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Back in 1999 my wife's 300M went into limp mode, it was the output sensor...
