Re: 69 HEMI water pump housing: MP alum looks the same??
[Re: MLR426]
#1130779
12/10/11 11:33 AM
12/10/11 11:33 AM
Posts: 75,125 A Banana Republic near you.
JohnRR
i believe John is speaking of the repro 65 A990 aluminum water pump housing that has the early alternator mounting holes in it.
logan425
Martin, The current MP aluminium housing has both locations, I had an A990 housing it only had the mounting boss up high.
I have modified the current to look closer to the 69 housing , removed the extra mount boss, ground on the part number, there is a pentastar also in the thermo neck that needs to be removed. I'm going to epoxy putty the spots under the thermo bolts to look like the stock 69 iron housing ...
[Re: JohnRR]
#1130780
12/10/11 11:36 AM
12/10/11 11:36 AM
Posts: 9,670 Lima, Peru
domingo
EL Master
EL Master
Lima, Peru
D , I see all your questions , you have been a member since 2003 selling repop parts and you don't know where to get any of this stuff ???
Anyways , the MP alum pump LOOKS SIMILAR but it has both alternater mounting points , and the thermo neck is not the same and the part number is a Pnumber , all these things can be addressed .
I know about where to got most parts, but I havent bought all of them before or have seen them in person at the shows because I dont live in the USA, sometimes there are several sources for the parts, sometimes there are better repros than others, yes, I get the magazines too, but it cant hurt to ask. I have gotten several tips and pointers I ignored by asking this questions.
I dont get to go to the shows every year and see the parts in person either....
Thats what mopars is for! Sharing info, right?
I havent restored rare cars before as well, so I didnt pay much attention to these small details. Now Im restoring some HEMI and other rare cars and Im starting to pay attention on the small details regarding part "correctness" not quality of work.
Yes, I have done repro parts, I just made sure they looked the same as the original samples I got, that doesnt mean I will know everything about every single part that goes on a mopar.
Unfortunately I am not blessed to know it all!
[Re: JohnRR]
#1130781
12/10/11 11:41 AM
12/10/11 11:41 AM
domingo
EL Master
EL Master
Lima, Peru
logan425
OK....yes I saw some pics of all the aluminum housings on the internet and they all have the dual bosses for the alternator mount and the water neck does look taller and shaped different.
OK so I guess all of them aluminum water pump housings are similar, and there are none that resemble the original more than any other....
Ill just buy one of the 440 source ones which is cheaper priced than the MP one and modifiy it too look stock. Ill be TIG welding and griding and then sandblasting to bring back the as cast texture...
Any reason to prefer the MP one over the 440 source one or are they basically the same?
[Re: astjp2]
#1130783
01/15/12 12:59 PM
01/15/12 12:59 PM
Posts: 49 Wisconsin
roadguy67
Wisconsin
Does anyone know if this is an original 65 in cast aluminum?
