sm bk rocker arm circle track
#1129106
12/06/11 11:00 PM
12/06/11 11:00 PM
fullfloater
I need a severe duty rocker arm for a sm bk for circle track ,years ago i always used 273 rockers ,tried Harland Sharp once ,it didn,t work out to well ,put some 273 rockers on a street car once ,bought a set of new Alinmun rockers and it really woke car up ,motor sounded so much crisper ,I then relized how far 273 rockers were off in ratio ,I need a steel rocker ,can be roller tip ,like comps magnum rockers ,no alinmun ,Is there any horsepower gain using a roller tip versus a doctile like a crane ,these comps are awful pricey ,Im all ears
Re: sm bk rocker arm circle track
[Re: fullfloater]
#1129107
12/06/11 11:24 PM
12/06/11 11:24 PM
Posts: 52,972 Romeo MI
MR_P_BODY
No real HP gain with the roller(that you can really measure)... but they do help guide wear on larger lift cams... cant help with any good steel rockers... all I use are TDs and they are alum
[Re: beeson44]
#1129109
12/07/11 12:10 AM
12/07/11 12:10 AM
fullfloater
I have to use a Oem head ,i am using 308 castings ,no port work ,valve size can be opened up ,we are using chevy style smaller stem stainless steel valve ,I can use a steel roller tip rocker arm ,just trying to decide on whitch one ,a doctile aftermarket like isky or crane ,send my 273 rockers in to rocker arm specialists and have them corrected or buy a set of comp cams ultra magnums i beleive ,i,m nervous about roller tip rockers arms in a circle track engine ,they can be hard on parts ,but if there is some horsepower there in a roller tip we can use it ,i just don,t see it as rocker arms manufactures claim horsepower gains with them ,is there any facts to this ,anybody have any hard evidence
[Re: fullfloater]
#1129110
12/07/11 12:19 AM
12/07/11 12:19 AM
MR_P_BODY
The big thing that they MIGHT try saying is they make more HP over stock rockers... well that would be a true statement ... most stock rockers are shorter than what the factory said... as in 1.3 ratio and the aftermarket would be 1.5 so thats added lift
