E Body Lower Dash Bezel Restoration #1129033
12/06/11 09:57 PM
12/06/11 09:57 PM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
What are you using to restore the Radio and Heater bezels with the correct texture. I thought it was the valve cover wrinkle paint but that says to only use on metal.I have a few ideas but could use some comments.
Bob
Mom & Dad let me buy a brand new 70 Challenger R/T 440 Six-Pack Super Trac Pack when I was 17
(Robert what is a 440 Six-Pack)
Re: E Body Lower Dash Bezel Restoration [Re: VCODE] #1129034
12/06/11 10:00 PM
12/06/11 10:00 PM
Tenn.
jrwoodjoe Offline
jrwoodjoe  Offline
Tenn.
Though it says to use on metal, crinkle paint is what I used.
65 Barracuda
70 Challenger
Re: E Body Lower Dash Bezel Restoration [Re: jrwoodjoe] #1129035
12/06/11 10:02 PM
12/06/11 10:02 PM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
Joe,
Does it work on plastic?
What brand did you use
Bob
Re: E Body Lower Dash Bezel Restoration [Re: VCODE] #1129036
12/06/11 11:07 PM
12/06/11 11:07 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Yes, it works on plastic. I used VHT brand but there are quite a few others. It did take a long time to dry though. I just let it sit for a couple weeks before trying to redo the letters.
I think Joe said he used a Krylon product. VHT was the only brand I could find locally.
Re: E Body Lower Dash Bezel Restoration [Re: burdar] #1129037
12/07/11 12:39 AM
12/07/11 12:39 AM
owensboro, ky
rallye73 Offline
rallye73  Offline
owensboro, ky
Guess I'm the oddball. I used Duplicolor spray on truck bed coating. It comes out of the can hard and fast, but a few swift coats and it turned out really good. Nice uniform texture. I never could get the wrinkle finish type paints to come out quite right.
Re: E Body Lower Dash Bezel Restoration [Re: rallye73] #1129038
12/07/11 04:31 AM
12/07/11 04:31 AM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline
I used the wrinkle finish paint as well. Works fine on plastic too. If you use heat to bring out the texture, be careful, as the plastic pieces will warp very easily.
Re: E Body Lower Dash Bezel Restoration [Re: Barnabas_Kriss] #1129039
12/07/11 09:01 AM
12/07/11 09:01 AM
White Plains, NY
VCODE Offline OP
VCODE  Offline OP
White Plains, NY
Thanks to everyone.I will be trying the wrinkle paint too see how it looks.
Bob
Re: E Body Lower Dash Bezel Restoration [Re: VCODE] #1129040
12/07/11 08:16 PM
12/07/11 08:16 PM
Mississippi
lahatte Offline
lahatte  Offline
Mississippi
I was informed by a guy at Performance Car Graphics about a paint. Partial quote...
"Our experience over many years with black crinkle:
-Krylon is thick, inappropriate, and unattractive
-Eastwood is mediocre or good or fair for appearance and originality. Very sensitive to thickness of costs, lapse time between coats, temperature, brightness of sunlight
-Plastikote is most reliable for all of the above factors, but you must practice first. Even-nes of coats, thickness of coats, and temperature are critical. Plastikote 217 Black."
I haven't tried it myself, so I would like to hear experiences.
Re: E Body Lower Dash Bezel Restoration [Re: lahatte] #1129041
12/07/11 08:54 PM
12/07/11 08:54 PM
Ct, Oxford
340swing Offline
340swing  Offline
Ct, Oxford
I have the eastwood stuff i will post pics after i try it. Any tips on detailing the letters and what paint do you use for them. Also any good tips for painting the letters I have used a mini roller wrap it with masking tape and carefully roll on paint. very small roller (homemade)
Re: E Body Lower Dash Bezel Restoration [Re: 340swing] #1129042
12/08/11 11:49 AM
12/08/11 11:49 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I just used a paint pen with a medium sized tip. I had to go over the letters twice. After the first pass, they still looked dirty. After the second pass(after the first coat had dried) they look nice and crisp. I didn't have any issues with seeing pen strokes in the paint.
Re: E Body Lower Dash Bezel Restoration [Re: rallye73] #1129043
12/08/11 05:26 PM
12/08/11 05:26 PM
New York
EF8aar Offline
EF8aar  Offline
New York
I used the same (Duplicolor)on the plastics... On the letters I used a new pencil eraser as a rubber stamp (nice and easy, takes a few coats) with Testors white paint.
I got these tips from posts on Moparts
Re: E Body Lower Dash Bezel Restoration [Re: EF8aar] #1129044
12/15/11 03:50 AM
12/15/11 03:50 AM
I used the plasticote 217 paint as well. Must follow the instructions exactly to get a good even texture.
