Popping out Intake #112787
08/31/08 02:01 AM
08/31/08 02:01 AM
Prescott Az
73 SSP Offline OP
73 SSP  Offline OP
Prescott Az
HELP me please?????????????????????????
I have popping out of the intake on all cylinders. Have tried resetting timing adv and ret w/ no resolution to problem. Running a mild MP purple shaft cam. Replaced lifters after finding a colapsed one. Replaced the MP junk lifters w/ Comp cams replacement hyd lifters. If no one answers will repost in race section.
Re: Popping out Intake [Re: 73 SSP] #112788
08/31/08 02:31 AM
08/31/08 02:31 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
When does it pop?? Any time you rev the engine? Only under load? Lots of things can cause it we need more info... To lean will cause a pretty severe backfire & the engine will stumble...A flat exhaust lobe on the cam will cause a series of little pops (pop pop pop pop) through the intake on light acceleration & while the engine will lack power it won't exactly stumble instead it will feel more like a miss..
Re: Popping out Intake [Re: 1_WILD_RT] #112789
08/31/08 02:38 AM
08/31/08 02:38 AM
Prescott Az
73 SSP Offline OP
73 SSP  Offline OP
Prescott Az
We first noticed it when it was first started. The intake is off and timing cover removed to check timing. It does it when you crank it over w/ a starter trigger.
Re: Popping out Intake [Re: 73 SSP] #112790
08/31/08 02:50 AM
08/31/08 02:50 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
So does it run at all? If not I'd be double checking the firing order, pull #1 sparkplug & bump the engine over till you feel compression, then check the timing marks while manualy turning the engine over to TDC...Now look where the rotor is pointing, it should be toward #1...If not either pull the distributor & reposition the intermediate shaft as needed to line it up or move the plug wires so #1 is were the rotor is pointing...then install the rest of the wires in the proper order (18436572) in the direction the rotor turns when cranking the engine....
Re: Popping out Intake [Re: 1_WILD_RT] #112791
08/31/08 03:01 AM
08/31/08 03:01 AM
Prescott Az
73 SSP Offline OP
73 SSP  Offline OP
Prescott Az
It runs
Re: Popping out Intake [Re: 73 SSP] #112792
08/31/08 03:06 AM
08/31/08 03:06 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Did it have even compression on all eight cylinders? When cranking over with the ignition disabled does it have an even rythym or does it seem to spin faster then slower?
Re: Popping out Intake [Re: 1_WILD_RT] #112793
08/31/08 03:10 AM
08/31/08 03:10 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
valve lash to tight...
I am truckless..
Re: Popping out Intake [Re: 340SHORTY] #112794
08/31/08 03:12 AM
08/31/08 03:12 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
He mentioned in the first post it's hydraulic...
Re: Popping out Intake [Re: 1_WILD_RT] #112795
08/31/08 10:49 AM
08/31/08 10:49 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Push rods too long?
Re: Popping out Intake [Re: stumpy] #112796
08/31/08 12:35 PM
08/31/08 12:35 PM
Prescott Az
73 SSP Offline OP
73 SSP  Offline OP
Prescott Az
Push rods too long?
Stumpy We were thinking that too, but I ordered the correct ones from MP when I replaced the cam.
Re: Popping out Intake [Re: 73 SSP] #112797
08/31/08 12:45 PM
08/31/08 12:45 PM
Southern Oklahoma
wildman340 Offline
wildman340  Offline
Southern Oklahoma
With the engine off, you should be able to spin/turn every pushrod that isn't on compression/lift. If you can't, then the valves are being held open.
1974 Dodge Dart Sport 340 4 Spd Endless Project 1999 Ram 1500 CC 5.2 5 speed
Re: Popping out Intake [Re: 73 SSP] #112798
08/31/08 02:36 PM
08/31/08 02:36 PM
Prescott Az
73 SSP Offline OP
73 SSP  Offline OP
Prescott Az
Thanks for the replies guys! The Problem wasn't what any of us discussed. It turns out the the crank gear was on the wrong notch. DOH!!
Re: Popping out Intake [Re: 73 SSP] #112799
08/31/08 03:44 PM
08/31/08 03:44 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Glad you found it!!! I've sen it before, you expect the dot inline with the keyway like Chevy & Ford, the mark is barely stamped so it's practically invisable & the fun begins....
Again Glad you found it!!!
