Re: Caltrac question... monos or xhd leafs?
[Re: sixpackbee]
#1127847
02/20/12 07:40 AM
02/20/12 07:40 AM
Posts: 1,627 anywhere@ anytime
actionange
anywhere@ anytime
You really have to have their monoleafs. The Cal Trac bars do not work up to their potential with s multi leaf type spring.
Here's Caltrac monos, bars and QA-1 shocks...
[Re: StealthWedge67]
#1127850
02/20/12 02:47 PM
02/20/12 02:47 PM
Posts: 4,570 Motor City
6PKRTSE
Motor City
When running Caltracs the split mono's are recommended. Seems like more people have better results & consistancy with running the mono's. I have the Caltracs/ -1" split monos' & the caltrac shocks on my Challenger. I haven't tested it yet. Still in the building process. The trick is running a very loose front end for transfer.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 6PKRTSE]
#1127851
02/20/12 02:49 PM
02/20/12 02:49 PM
6PKRTSE
Motor City
Even with the -1 springs & the 315's on I still will probably make it sit a little lower. Won't know until I get the driver train & eveything else installed to get the correct ride height.
[Re: 6PKRTSE]
#1127852
02/20/12 02:51 PM
02/20/12 02:51 PM
6PKRTSE
Motor City
One of the caltracs mounted.
[Re: dragram440]
#1127854
02/20/12 05:50 PM
02/20/12 05:50 PM
Posts: 2,465 Sydney,Australia
tex013
Sydney,Australia
i have the XHD springs in my 68 Satellite with the Caltracs,1.53 60' is my best off the footbrake.i have the rancho rear shock set to #9 on the strip #4 or 5 on the street rides fine.i did fit their aluminium front bush. qa1 on front set full loose at the strip.though i do have small block front bars
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: 67dodge67]
#1127857
02/21/12 02:23 AM
02/21/12 02:23 AM
Posts: 989 WI, USA
67dodge67
mopar addict
mopar addict
WI, USA
and how about one last one.... oh, that's right, I also installed in an 8 point roll bar purchased from S&W. Excellent piece from them. Dave
[Re: 67dodge67]
#1127858
02/21/12 06:02 PM
02/21/12 06:02 PM
tex013
Sydney,Australia
looks nice Dave, by the way i leave mine preloaded at all times
Tex
[Re: tex013]
#1127859
02/21/12 07:32 PM
02/21/12 07:32 PM
Posts: 3,210 robin hood country
deaks
robin hood country
Nice I've just bought a 67 R/T, just waiting for it to be shipped. I just run SS springs and 9way ranchos on my Dart. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: rapom]
#1127862
02/22/12 01:30 AM
02/22/12 01:30 AM
Posts: 989 WI, USA
67dodge67
mopar addict
mopar addict
WI, USA
I'm going to have to post of pic of my 67 tomorrow. I also have caltracs going in with 325/50/15 MT's on stock widened rims.
Very cool. As you might have guessed, I have the same size tires as well, on 15x10 prostars. Have tons of room up in there after doing the mini tubs a couple years back. Looking forward to seeing your pics!
[Re: 6PKRTSE]
#1127863
02/22/12 10:22 AM
02/22/12 10:22 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
Not necessarily. I found out the hard way that too loose up front can cause you major traction issues w/ Cal-Tracs on a 9 sec car. On a slower car, yes you need quick transfer. Not so much on others.
