Page 2 of 3 1 2 3
Re: Caltrac question... monos or xhd leafs? [Re: astjp2] #1127846
02/20/12 01:34 AM
02/20/12 01:34 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I run the spit mono's with Cal-Tracs, and like Dustin, I drive mine on the street regularly. If you back all preload out of the Cal-Tracs, the split mono's then actually act very nice on the street. I agree with Dustin that the aluminum bushings are probobly the biggest part of any change you feel. I noted that they also transfer much more sound into the chassis than rubber bushings do....
To the O.P.: Might as well try them with the XHD's. Calvert told me that the Split Mono's don't really pay off big until performance gets near the 10 second zone.
Re: Caltrac question... monos or xhd leafs? [Re: sixpackbee] #1127847
02/20/12 06:40 AM
02/20/12 06:40 AM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
You really have to have their monoleafs. The Cal Trac bars do not work up to their potential with s multi leaf type spring.
Here's Caltrac monos, bars and QA-1 shocks...
Re: Caltrac question... monos or xhd leafs? [Re: actionange] #1127848
02/20/12 12:28 PM
02/20/12 12:28 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Ok, I know that mono leafs are what is recommended but I am planning on running the XHD springs so does anyone have a part number or the needed lengths that I will need for a 68 b-body? Thanks Tim
Re: Caltrac question... monos or xhd leafs? [Re: astjp2] #1127849
02/20/12 01:21 PM
02/20/12 01:21 PM
Puyallup, WA
Puyallup, WA
If you already have the XHD's, then it makes sense to run them. If you are going to BUY springs to go with Cal-Trac's, then buying ANYTHING other than the Calvert mono spring is a BIG mistake, IMO.
Re: Caltrac question... monos or xhd leafs? [Re: StealthWedge67] #1127850
02/20/12 01:47 PM
02/20/12 01:47 PM
Motor City
6PKRTSE Online content
6PKRTSE  Online Content
Motor City
When running Caltracs the split mono's are recommended. Seems like more people have better results & consistancy with running the mono's. I have the Caltracs/ -1" split monos' & the caltrac shocks on my Challenger. I haven't tested it yet. Still in the building process. The trick is running a very loose front end for transfer.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Caltrac question... monos or xhd leafs? [Re: 6PKRTSE] #1127851
02/20/12 01:49 PM
02/20/12 01:49 PM
Motor City
Motor City
Even with the -1 springs & the 315's on I still will probably make it sit a little lower. Won't know until I get the driver train & eveything else installed to get the correct ride height.
Re: Caltrac question... monos or xhd leafs? [Re: 6PKRTSE] #1127852
02/20/12 01:51 PM
02/20/12 01:51 PM
Motor City
Motor City
One of the caltracs mounted.
Re: Caltrac question... monos or xhd leafs? [Re: 6PKRTSE] #1127853
02/20/12 04:12 PM
02/20/12 04:12 PM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I would certainly try the caltracs with the xhd springs. I run stock springs and a pinion snubber with some clamps on the front of one segment and some on the back of the other side segments. Mine hooks great with 275-60 mt e.t. street radials. 1.49 60' dead hook off the foot brake with a 5000 8" converter. Long front shocks made mine hook awsome!
67' charger 499 RB 10.57 at 127
Re: Caltrac question... monos or xhd leafs? [Re: dragram440] #1127854
02/20/12 04:50 PM
02/20/12 04:50 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
i have the XHD springs in my 68 Satellite with the Caltracs,1.53 60' is my best off the footbrake.i have the rancho rear shock set to #9 on the strip #4 or 5 on the street rides fine.i did fit their aluminium front bush. qa1 on front set full loose at the strip.though i do have small block front bars
Tex
New best ET 10.259@129.65 .
New best MPH 130.94
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Caltrac question... monos or xhd leafs? [Re: tex013] #1127855
02/21/12 01:14 AM
02/21/12 01:14 AM
WI, USA
67dodge67 Offline OP
mopar addict
mopar addict
WI, USA
Wow! This has been a good topic afterall! I didn't think there would be all of these responses from my original post. Well, a good update here... the caltracs are now on my car, as well as some other goodies... I was able to take out my car for a little spin around the block to see if I could feel any noticable difference and quite honestly, I didn't. Mind you, they were not loaded, nor did I take it for a hard launch.... just drove it for about 5 minutes. I'm getting anxious for warm weather and a trip to the track to get these dialed in.
For those who are wondering how hard it was installing them, it is VERY easy to do!!!! Took me about 5-6 hours and had a fun time doing so. Soooo here's some pics of whats been done... enjoy!
Re: Caltrac question... monos or xhd leafs? [Re: 67dodge67] #1127856
02/21/12 01:16 AM
02/21/12 01:16 AM
WI, USA
mopar addict
mopar addict
WI, USA
...another...
Re: Caltrac question... monos or xhd leafs? [Re: 67dodge67] #1127857
02/21/12 01:23 AM
02/21/12 01:23 AM
WI, USA
mopar addict
mopar addict
WI, USA
and how about one last one.... oh, that's right, I also installed in an 8 point roll bar purchased from S&W. Excellent piece from them.
Re: Caltrac question... monos or xhd leafs? [Re: 67dodge67] #1127858
02/21/12 05:02 PM
02/21/12 05:02 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
looks nice Dave,
by the way i leave mine preloaded at all times
Tex
New best MPH 130.94
Re: Caltrac question... monos or xhd leafs? [Re: tex013] #1127859
02/21/12 06:32 PM
02/21/12 06:32 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Nice
I've just bought a 67 R/T, just waiting for it to be shipped.
I just run SS springs and 9way ranchos on my Dart.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Caltrac question... monos or xhd leafs? [Re: deaks] #1127860
02/21/12 09:40 PM
02/21/12 09:40 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I'm going to have to post of pic of my 67 tomorrow. I also have caltracs going in with 325/50/15 MT's on stock widened rims.
Re: Caltrac question... monos or xhd leafs? [Re: rapom] #1127861
02/21/12 11:08 PM
02/21/12 11:08 PM
Camillus N.Y
rollerfork Offline
rollerfork  Offline
Camillus N.Y
I run a dearched SS spring with clamps on the rear section of each spring,Caltracs and a Competition Engineering shocks. With a 9 inch slick car 60s 1.45 to 1.46 range.
Re: Caltrac question... monos or xhd leafs? [Re: rapom] #1127862
02/22/12 12:30 AM
02/22/12 12:30 AM
WI, USA
mopar addict
mopar addict
WI, USA
Very cool. As you might have guessed, I have the same size tires as well, on 15x10 prostars. Have tons of room up in there after doing the mini tubs a couple years back. Looking forward to seeing your pics!
Re: Caltrac question... monos or xhd leafs? [Re: 6PKRTSE] #1127863
02/22/12 09:22 AM
02/22/12 09:22 AM
an8sec70cuda Offline
Not necessarily. I found out the hard way that too loose up front can cause you major traction issues w/ Cal-Tracs on a 9 sec car. On a slower car, yes you need quick transfer. Not so much on others.
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Re: Caltrac question... monos or xhd leafs? [Re: 67dodge67] #1127864
02/22/12 01:31 PM
02/22/12 01:31 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
Here's the pics.
I'm still putting mine together.
Re: Caltrac question... monos or xhd leafs? [Re: rapom] #1127865
02/22/12 01:33 PM
02/22/12 01:33 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
My car is a Coronet 500 with the Coronet 440 tail panel.
Page 2 of 3 1 2 3
