Page 3 of 3 1 2 3
Re: 71 Dart Drum brake problems [Re: savoy64] #1126291
12/05/11 12:06 PM
12/05/11 12:06 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
there have been several articles in different mopar magazines over the years about the propensity of Abody cars to lock up the rear brakes----and if i remember right it was the distribution block problem---bob
Had to do with the rear wheel cylinders being too big , I bought ase set of the smaller ones from Ebooger and installed them in a 67 barracuda convert for a friend , he swapped over to discs and it has an NOS manual disc brake master I got from Bill Rolik , should have bought 2. I put an adjustable wilwood valve in the rear line and no lock up on the rears .
Re: 71 Dart Drum brake problems [Re: HemiRick] #1126292
12/06/11 05:49 PM
12/06/11 05:49 PM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
The rebuilt $20 Advance master cyl fixed it for the most part. The car will now lock up the front brakes in gravel where it would not before. Autozone had none of the $14.97 MC....
Weird problem never seen a master act like this in 35 years of fixin cars.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: 71 Dart Drum brake problems [Re: HemiRick] #1126293
12/06/11 06:30 PM
12/06/11 06:30 PM
Wouldn't happen anywhere else exc on Moparts! Glad ya got it
Re: 71 Dart Drum brake problems [Re: HemiRick] #1126294
12/06/11 06:51 PM
12/06/11 06:51 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
It is hard to comprehend what went wrong with the master. If the primary piston had somehow stuck / frozen totally, there would be NO brakes (front or rear) but still a firm pedal. The rear line pressure is derived from the primary piston (toward rear of car) pressing on the "floating" secondary (for rear brakes, front outlet) piston. So if the rears were working, the primary piston HAD to be operating OK. Bizarre. I'd love to dissect that master.
Before...I was thinking stuck w/cyl pistons...
Rick
Re: 71 Dart Drum brake problems [Re: Rick_Ehrenberg] #1126295
12/06/11 07:39 PM
12/06/11 07:39 PM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
Should have spoke up sooner, Advance got it for the $10 core charge.
Take care,
Rick
Re: 71 Dart Drum brake problems [Re: HemiRick] #1126296
12/06/11 08:42 PM
12/06/11 08:42 PM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
Quick! Get it out of the recycle bin!
Glad it's fixed...
Re: 71 Dart Drum brake problems [Re: bobs66440] #1126297
12/07/11 05:10 PM
12/07/11 05:10 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
Bet it was full of rust. The rears activate first and if the front brake side had a clogged hole or something, it'd have pressure on the pedal cause the fluid cant move, but will not work the front brakes. Seen it a few times.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: 71 Dart Drum brake problems [Re: 70dart360] #1126298
12/07/11 05:17 PM
12/07/11 05:17 PM
Memphis
HemiRick Offline OP
HemiRick  Offline OP
Memphis
The fluid in it was full of rust. I've flushed the system as well.
Take care,
Rick
Re: 71 Dart Drum brake problems [Re: 70dart360] #1126299
12/07/11 06:41 PM
12/07/11 06:41 PM
Marlboro, NY, USA
Marlboro, NY, USA
Actually, the primary piston moves first, activating the front brakes and (hydraulically) moving the secondary piston, which, in turn, pressurizes the rear brakes.
Hard to imagine 1000 PSI not pushing past any hose defect.
Rick
Page 3 of 3 1 2 3
