Need help with dianosing my 99 Ram #1124870
12/01/11 08:24 AM
12/01/11 08:24 AM
None
71rm23 Offline OP
71rm23  Offline OP
None
I have a 99 Ram with a 5.9 L. It started fine and I drove it for a little while. Then all of the sudden, it died. It took awhile to start it but when I put the truck in gear, dies again. Also, the check engine light came on then.
I didnt have a chance to look at it because I was in a hurry to run an errand. My guess is a dead cell in the battery, and or going bad. I will use a meter to check voltage and probably take it out to have a load test done on it. Is there anything I might be missing?
Re: Need help with dianosing my 99 Ram [Re: 71rm23] #1124871
12/01/11 09:08 AM
12/01/11 09:08 AM
Catskill, NY
teflon Offline
teflon  Offline
Catskill, NY
Check the code, my guess is crank sensor.
Re: Need help with dianosing my 99 Ram [Re: teflon] #1124872
12/01/11 09:12 AM
12/01/11 09:12 AM
None
71rm23 Offline OP
71rm23  Offline OP
None
Would that keep it from running? I had that replaced a few years ago. That sensor is on the back of the block, between the block and tranny, correct?
Re: Need help with dianosing my 99 Ram [Re: 71rm23] #1124873
12/01/11 10:32 AM
12/01/11 10:32 AM
scratchnfotraction Offline
yes,back of black at the trans bellhousing
Re: Need help with dianosing my 99 Ram [Re: 71rm23] #1124874
12/01/11 06:58 PM
12/01/11 06:58 PM
Idaho, USA
W
White440 Offline
White440  Offline
W
Idaho, USA
Did you have to recharge the battery after the first time it died? I would check code because the the alt should put out enough to maintain the trucks running needs by its self.
"Full throttle until you see GOD then brake!" <img src="/ubbthreads/images/graemlins/drive.gif" alt="" /> Life's to short to ride the brakes!
Re: Need help with dianosing my 99 Ram [Re: White440] #1124875
12/01/11 11:39 PM
12/01/11 11:39 PM
North Carolina
Tadams Offline
Tadams  Offline
North Carolina
I had basically the same problem with mine. I had it towed to the garage and then it started perfectly after leaving me on the side of the road. 2 days later they called and said it was fixed and it was the crank sensor. Mine would only show a code when it would act up, but no code when it would start ok.
Good luck with your problem.
Re: Need help with dianosing my 99 Ram [Re: 71rm23] #1124876
12/02/11 11:18 PM
12/02/11 11:18 PM
Heart of Ohio
4boxers4 Offline
4boxers4  Offline
Heart of Ohio
any auto parts store will read the code for you. THEN...change out parts.
Persistance is omnipotent Durability Engineer, Chair and Couch division...
Re: Need help with dianosing my 99 Ram [Re: 4boxers4] #1124877
12/03/11 12:46 AM
12/03/11 12:46 AM
None
71rm23 Offline OP
71rm23  Offline OP
None
Found out its the crank sensor....AAAAUUUUGGGHHH!!!!!
