Re: 68 b body dash reverse light
[Re: Rebel2324]
#1123182
11/28/11 02:58 PM
11/28/11 02:58 PM
Posts: 8,827 Houston, Tx
hemi68charger
Houston, Tx
If you don't have a hole in your dash frame in the obvious location for a reverse light, then the bulb may go to something else. Can you take a picture of the component you're referring to? It could shed some light on the subject...
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
[Re: hemi68charger]
#1123183
11/28/11 04:16 PM
11/28/11 04:16 PM
Posts: 450 DFW
68RRFlyer
DFW
Here's the reverse light on my 69 and 68s should be the same. The Reverse light is held into the dash with a big nut on the back of the housing. Much like the side marker lights are installed on a 68. Also notice the ignition light hole. Maybe it's that too if you have the light package?? Disregard the rats nest under the dash, I'm in the middle of diassembling and rewiring the entire dash with new harnesses. Hope that helps! Cheers
