HHR Fan install, Early B Body #1122138
11/26/11 11:37 PM
11/26/11 11:37 PM
Madison Wi
NTOLERANCE Offline OP
Madison Wi
Thought I would throw this pic out there for anyone with an early B body considering a HHR fan.
I am running a 67 B body K frame so my engine is sitting back a bit. ( bout an inch)
I dont think the HHR fan would ever fit with the engine mounted in the stock location.
Re: HHR Fan install, Early B Body [Re: NTOLERANCE] #1122139
11/26/11 11:43 PM
11/26/11 11:43 PM
Thanks!
I've been looking at electric fan options in case my clutch fan doesn't get the job done.
I'm sure the HHR fan won't fit mine since it has the original style K.
Re: HHR Fan install, Early B Body #1122140
11/26/11 11:49 PM
11/26/11 11:49 PM
Madison Wi
Madison Wi
Thanks!
The one piece electric water pumps might help.
Re: HHR Fan install, Early B Body [Re: NTOLERANCE] #1122141
11/26/11 11:59 PM
11/26/11 11:59 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
What's the width of the HHR setup? Nothing fit between my 383 and my radiator. I bought Deraile's 18217 17" two speed fan - at 2-5/8" it still wouldn't clear.
I managed to squeeze it in front of the radiator, its really a great fan
Ride eternal, shiny and chrome
Re: HHR Fan install, Early B Body [Re: DirectSubjection] #1122142
11/27/11 12:02 AM
11/27/11 12:02 AM
I never realized that early B's had such space limitations fore/aft of the engine until I put this car together!
What a PITA!
Re: HHR Fan install, Early B Body #1122143
11/27/11 12:04 AM
11/27/11 12:04 AM
Here
Here
What I ended up fitting - barely:
http://www.jegs.com/i/Derale/259/18217/10002/-1
Re: HHR Fan install, Early B Body [Re: DirectSubjection] #1122144
11/27/11 12:13 AM
11/27/11 12:13 AM
Madison Wi
Madison Wi
Looks like its just over 3 5/8" from the fins.
Re: HHR Fan install, Early B Body [Re: NTOLERANCE] #1122145
11/27/11 12:15 AM
11/27/11 12:15 AM
Madison Wi
Madison Wi
Fits the early B 22" radiator like a glove.
Re: HHR Fan install, Early B Body [Re: NTOLERANCE] #1122146
11/27/11 12:18 AM
11/27/11 12:18 AM
Here
Here
Wow - no chance for me. Maybe the fan I used would fit in the other set-up you mentioned.
Re: HHR Fan install, Early B Body [Re: NTOLERANCE] #1122147
11/27/11 01:10 PM
11/27/11 01:10 PM
Missouri
StrokerPost Offline
StrokerPost  Offline
Missouri
So what year is your B and when did the eng location change?
Re: HHR Fan install, Early B Body [Re: NTOLERANCE] #1122148
11/27/11 01:16 PM
11/27/11 01:16 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
One won't fit in a small block A-body without hacking the fan up. But it will fit a small-block E-body with room to spare. It also cooled much better in the E-body, maybe having to do with better air circulation under the hood?
Re: HHR Fan install, Early B Body [Re: StrokerPost] #1122149
11/27/11 01:19 PM
11/27/11 01:19 PM
Madison Wi
Madison Wi
65 Coronet.
K frame change came in 66. Engine sits back further.
Re: HHR Fan install, Early B Body [Re: NTOLERANCE] #1122150
04/04/14 04:45 PM
04/04/14 04:45 PM
Summit, NJ
W
whiplash Offline
whiplash  Offline
W
Summit, NJ
so what year HHR do you look for to get one? GM part # also? thanks!
  • 67 coronet 4dr, 383/727/GVOD, blown, EFI, daily driver
  • 230/238, 114°LSA cam, 1.6 rollers, 9:1 comp, 8 psi boost
  • NEW BEST ET - 12.40@110mph...
