ARP main bolts / studs
#1120792
11/24/11 07:22 PM
11/24/11 07:22 PM
Posts: 347 FRANCE, Paris
Chal340
FRANCE, Paris
What's the difference between bolt ARP 140-5001 and stud ARP 140-5401? Studs center caps not bolts?
70 Challenger, A66, 340 ci
Re: ARP main bolts / studs
[Re: Chal340]
#1120793
11/24/11 08:44 PM
11/24/11 08:44 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
studs have more clamping force than bolts
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: Chal340]
#1120796
11/25/11 03:13 AM
11/25/11 03:13 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
About $30 The studs are stronger, 200,000 psi vs 180,000 psi for the bolts and will have a higher clamping force. The bolts are pretty nice. I have them on my small block to clear the oil pump (studs don't clear the oil pump on a small block), but I use the studs on my big blocks.
[Re: 451Mopar]
#1120797
11/25/11 03:57 AM
11/25/11 03:57 AM
Posts: 27,479 So Cal
autoxcuda
So Cal
I got a stud on my small block. Troy modified the nut by slightly rounding the nut and then shortening the stud exactly to the height of the nut.
[Re: autoxcuda]
#1120798
11/25/11 08:11 AM
11/25/11 08:11 AM
Chal340
FRANCE, Paris
Thanks, so with bolts, it's not necessary to line hone main caps? I will check if it's ok or not. ARP bolts are better than stock bolts?
[Re: Chal340]
#1120799
11/25/11 08:33 AM
11/25/11 08:33 AM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
ARP are better than stock.Typically you dont need line hone when using them as they are just stronger.I use studs in my builds.Rocky
Chrysler Firepower
[Re: lucky13]
#1120806
11/26/11 03:21 PM
11/26/11 03:21 PM
autoxcuda
So Cal
When you shorten/round over the nut that goes under the oil pump, do you do it by hand or a lathe? Any pics showing how much?
Stud cut hand, finshed sized by belt sander. Nut dressed chucked in drill press cut down by hand file.
This is a Milodon stud BTW.
[Re: autoxcuda]
#1120807
11/26/11 04:42 PM
11/26/11 04:42 PM
Posts: 153 Antioch, CA
lucky13
Antioch, CA
Thank you that gives me a better idea of how much to cut it down
