Re: Restoring 70 Cuda tailight housings options?
[Re: NV69B7RR]
#1119505
11/23/11 12:33 AM
11/23/11 12:33 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Scott Harms Smith does them...
[Re: ScottSmith_Harms]
#1119515
11/23/11 01:41 PM
11/23/11 01:41 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
So, as you can see, they varied from the factory, may have been two venders with two different methods of metal wash/plating, I can't say, but they definately varied. Also, age and humidity etc. can alter the finish, I believe this is why some look darker/muddier than others.
I strip them and recolor them similar to how a Holley carb body is refinished, this is what they look like when done. It's pretty darn close to the second OEM example. I don't know of any other method to get them closer. Cost is under $100.00 a pair.
#1119516
11/24/11 12:56 AM
11/24/11 12:56 AM
Posts: 7,647 Houston Texas
PAINT IT BLACK
Got a CHIP on my shoulder
Houston Texas
Very nice. I just redid mine last week the way Bill did his and I'm happy with the results. If I hadn't done all the labor myself, I'd definitely HAPPILY spend the $100 with Scott, no question. Instead I ended up with something that visually represents what its supposed to look like... total time on the housings probably 1hr + something like $18 for the paint. I'll give a shout out to Detroit Muscle Technologies for the gaskets. VERY, very nice. I think $25 for that gasket set is a BARGAIN. Should charge more.
[Re: PAINT IT BLACK]
#1119519
11/24/11 02:42 AM
11/24/11 02:42 AM
Posts: 12,432 Warren, MI
71TA
Warren, MI
Very nice.
Thanks for the props!
With Bills mad skillz he can probably whip some up. By the way what DO you do for gaskets Bill?
[Re: 71TA]
#1119521
11/24/11 12:58 PM
11/24/11 12:58 PM
Posts: 21,452 It's a dry heat
gtx6970
It's a dry heat
Jim, do you really need to ask this? Every gasket on this car AND on the 69 Charger I have in now is DMT stuff .
I usually just let my customer buy it at shows or off your site then drop ship it to me, saves me one less thing to worry about and saves them cash.
[Re: gtx6970]
#1119522
08/10/12 11:24 AM
08/10/12 11:24 AM
Posts: 374 Wisconsin
Mopar_Mudder
Wisconsin
Another member here last year recomended Eastwoods Carb coat paint. So I decided to give it a try. This stuff is kind of thin, so it takes a couple light coats to acheive this depth of color.
Can you tell me what Eastwood Carb paint you used, I see they have a couple. Carb Renew 2 and Carb Renew 2 Bronze.
