E-coating. Is it water resistant? #1115201
11/16/11 08:20 PM
11/16/11 08:20 PM
Oakley CA
69charger440_6pa Offline OP
Oakley CA
Does anyone know if E-costing is moisture resistant? Getting ready to install some new sheet metal and need to know if I need to worry about sealing the inside of the panels.
Thanks.
1969 Charger R/T under construction
2014 Ram 3500 Cummins
2006 Corvette Z06
2015 Corvette Z06
2014 BMW M5
Re: E-coating. Is it water resistant? [Re: 69charger440_6pa] #1115202
11/16/11 08:42 PM
11/16/11 08:42 PM
Andrewh Offline
Andrewh  Offline
same as paint.
basically charged paint particals disbursed in water.
they get pulled to a charged part so the entire thing is coated.
then baked.
treat it like a primered part.
Re: E-coating. Is it water resistant? [Re: Andrewh] #1115203
11/16/11 11:59 PM
11/16/11 11:59 PM
canada
mridolfo Online content
mridolfo  Online Content
canada
Don't leave Ecoat in the sun for very long. The suns UV rays are harmful to the ecoat. After a period of time it will turn the finish chalkie ( spelling) and lose some of its corrosion resistance.
Re: E-coating. Is it water resistant? [Re: 69charger440_6pa] #1115204
11/17/11 12:14 AM
11/17/11 12:14 AM
NJ
70_FJ6_RR Offline
70_FJ6_RR  Offline
NJ
Take the extra time now and weld coat the flanges to be welded, and put two coats of epoxy primer on the entire inside area to seal it. It's a lot easier to coat off the car.
Re: E-coating. Is it water resistant? [Re: 70_FJ6_RR] #1115205
11/17/11 09:58 AM
11/17/11 09:58 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I was under the impression that the e-coat WAS corrosion resistant?
sure, it's easy to paint it with epoxy sealer while off the car, but, if the e-coat is a sealer, why bother with it?
"better safe than sorry" sure, but why spend money and time to do something that's "already done"? if they came primer'd in a 2-part epoxy primer sealer, would you still scuff them and spray them with your own primer/sealer?
**Photobucket sucks**
Re: E-coating. Is it water resistant? [Re: 70Cuda383] #1115206
11/17/11 06:52 PM
11/17/11 06:52 PM
NJ
70_FJ6_RR Offline
70_FJ6_RR  Offline
NJ
I've seen panels with etch coat, and panels with epoxy coat. Etch coat has to be sealed to keep it from rusting. The epoxy coated ones would be fine for "ready to install", but I would still strip the outside of the panel to bare metal cause I've seen it "chip" off in flakes. Also, depending on the color of the car, you may want an even coverage of color. Spend the money now and do it right the first time.
Re: E-coating. Is it water resistant? [Re: 69charger440_6pa] #1115207
11/19/11 02:33 AM
11/19/11 02:33 AM
Jacksonville Florida
elitecustombody Offline
To keep your mind at ease,if you're dealing with aftermarket sheetmetal, it's best to strip/sand the e-coat off and apply epoxy primer.On OEM metal you'll be fine with sanding/scuffing before primer,sealer or paint .
