E-coating. Is it water resistant?
#1115201
11/16/11 08:20 PM
11/16/11 08:20 PM
Posts: 1,523 Oakley CA
69charger440_6pa
Oakley CA
Does anyone know if E-costing is moisture resistant? Getting ready to install some new sheet metal and need to know if I need to worry about sealing the inside of the panels.
Thanks.
1969 Charger R/T under construction 2014 Ram 3500 Cummins 2006 Corvette Z06 2015 Corvette Z06 2014 BMW M5
Re: E-coating. Is it water resistant?
[Re: 70_FJ6_RR]
#1115205
11/17/11 09:58 AM
11/17/11 09:58 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I was under the impression that the e-coat WAS corrosion resistant?
sure, it's easy to paint it with epoxy sealer while off the car, but, if the e-coat is a sealer, why bother with it?
"better safe than sorry" sure, but why spend money and time to do something that's "already done"? if they came primer'd in a 2-part epoxy primer sealer, would you still scuff them and spray them with your own primer/sealer?
**Photobucket sucks**
