Page 7 of 9 1 2 3 4 5 6 7 8 9
Re: New project ( stock suspension 275 drag radial 72 duste [Re: LA360] #1114752
04/29/13 03:52 PM
04/29/13 03:52 PM
michigan
jbmopars Offline OP
jbmopars  Offline OP
michigan
Thanks for answering that because I wouldnt have been able to. Mark @ Bullet will be handling my camshaft needs. I do know my engine has a 50 mm cam.
Re: New project ( stock suspension 275 drag radial 72 duste [Re: John Burdine] #1114753
04/29/13 03:58 PM
04/29/13 03:58 PM
michigan
jbmopars Offline OP
jbmopars  Offline OP
michigan
Some of the chevy guys around here went to Cobo and called me from the show to tell me about this Badass black Demon that was there. Looking forward to seeing it in person. Will you be at Milan this Saturday for the grudge event?
Re: New project ( stock suspension 275 drag radial 72 duste [Re: jbmopars] #1114754
04/29/13 06:50 PM
04/29/13 06:50 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
you sure this is going to be the kids car ????
looks like a 4 sec ride to me when done ! !
Looks great so far ! ! Keep working on it
....BAD A$$ STREET CAR.....
Re: New project ( stock suspension 275 drag radial 72 duste [Re: jbmopars] #1114755
04/30/13 02:52 AM
04/30/13 02:52 AM
Chesterfield Twp. Mi.
John Burdine Offline
cant go, my shift at Warren Truck is 4 10 hours on 2cnd shift wed thru saturday night.
Re: New project ( stock suspension 275 drag radial 72 duste [Re: John Burdine] #1114756
05/07/13 04:56 PM
05/07/13 04:56 PM
michigan
jbmopars Offline OP
jbmopars  Offline OP
michigan
Here are some updated pics.
Re: New project ( stock suspension 275 drag radial 72 duste [Re: jbmopars] #1114757
05/07/13 10:12 PM
05/07/13 10:12 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
Thanks for posting this build. You have done an excellent job on your car. WOW!
Keep up the good work!
I'm going to build a 440" W9 and put it in a '71 Demon (street car).
Re: New project ( stock suspension 275 drag radial 72 duste [Re: Biginchmopar] #1114758
05/09/13 12:35 PM
05/09/13 12:35 PM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
Looks good, those headers are nearly identical to mine, except you took the easy route with the round outlets on the header ports!
Forming mine to the stock shape flanges was a bear.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: New project ( stock suspension 275 drag radial 72 duste [Re: jbmopars] #1114759
05/09/13 02:36 PM
05/09/13 02:36 PM
tennessee
mike54 Offline
mike54  Offline
tennessee
good luck with the build....i tried to get my son involved in street and drag cars... but he chose video games...
Re: New project ( stock suspension 275 drag radial 72 duste [Re: topfueldart] #1114760
05/09/13 06:00 PM
05/09/13 06:00 PM
michigan
jbmopars Offline OP
jbmopars  Offline OP
michigan
Post some pics of yours.
There is a big difference in port shape and size from a 318 head to an Arrington cnc'd W8. My primarys are 2" because they have to be 1 7/8 i.d. I didn't really take the easy route, I took the only route. Just sayin.
Re: New project ( stock suspension 275 drag radial 72 duste [Re: jbmopars] #1114761
05/09/13 08:37 PM
05/09/13 08:37 PM
Temperance, MI
P
prochargedhemi Offline
P
Temperance, MI
them donuts can be a pita to work with but the end result is super nice and tight. I like your style
Re: New project ( stock suspension 275 drag radial 72 duste [Re: jbmopars] #1114762
05/09/13 08:53 PM
05/09/13 08:53 PM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
I know the round was mandated by the heads/size, just joking around. I WISH mine were round (and Arrington CNC W8's for that matter).
Re: New project ( stock suspension 275 drag radial 72 duste [Re: topfueldart] #1114763
05/10/13 11:29 AM
05/10/13 11:29 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
How many of the doughnuts did you end up using? They are the tightest CLR you can get in 2" correct? Beautiful workmanship on the car!
Re: New project ( stock suspension 275 drag radial 72 duste [Re: fbs63] #1114764
05/10/13 02:05 PM
05/10/13 02:05 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I love this build. You are obviously going to beat my Challenger out in the local D/R classes. Can't wait to see it in person at the track.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: New project ( stock suspension 275 drag radial 72 duste [Re: fbs63] #1114765
05/10/13 04:31 PM
05/10/13 04:31 PM
michigan
jbmopars Offline OP
jbmopars  Offline OP
michigan
Thank you, all donuts have the same clr as the diameter of the said donut. I used a total of four donuts, the rear tubes on both sides are the only mandrel bent tubes on the headers. The donuts are 10 times nicer to fit up than the mandrel bends because they are very round. The mandrel bends have been stretched on the outside of the radius and become ovaled which makes the fit bad. And yes they are the tightest clr you can get. Jody
Re: New project ( stock suspension 275 drag radial 72 duste [Re: 6PKRTSE] #1114766
05/10/13 04:42 PM
05/10/13 04:42 PM
michigan
jbmopars Offline OP
jbmopars  Offline OP
michigan
Thank you, you must have more confidence in me than I do. I know that I am making progress but it seems like I am still so far from done, and there is so much to spend.
Re: New project ( stock suspension 275 drag radial 72 duste [Re: jbmopars] #1114767
06/19/13 11:33 PM
06/19/13 11:33 PM
michigan
jbmopars Offline OP
jbmopars  Offline OP
michigan
A few updated pics. Borg Warner S480 turbo with race cover and Forced Inductions billet wheel. Still waiting on the Wilson Manifolds throttle body and the PTC powerglide to be delivered.
Re: New project ( stock suspension 275 drag radial 72 duste [Re: jbmopars] #1114768
06/20/13 07:25 AM
06/20/13 07:25 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
I ike it nice and neat and clean.
Re: New project ( stock suspension 275 drag radial 72 duste [Re: racerx] #1114769
06/20/13 08:30 AM
06/20/13 08:30 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
That sure is nice, who's flanges are on those headers?
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: New project ( stock suspension 275 drag radial 72 duste [Re: 1967dartgt] #1114770
06/20/13 06:52 PM
06/20/13 06:52 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
They look like SPD Flanges
Alan Jones
Re: New project ( stock suspension 275 drag radial 72 duste [Re: LA360] #1114771
06/20/13 07:59 PM
06/20/13 07:59 PM
San Diego, CA
mopar_man619 Offline
San Diego, CA
tremendous work ! love it !
1967 Plymouth Valiant Gen III Hemi
11.42@119
youtube.com/moparman619
