Re: E-Body tach location (aftermarket)
[Re: JonC]
#1114491
11/15/11 10:28 PM
11/15/11 10:28 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
[Re: Mr340]
#1114493
11/16/11 10:05 AM
11/16/11 10:05 AM
Posts: 2,536 o
wunderless
o
Mine's the same as Mr340. Tucked away in the corner but still usefull.
But existing is basically all I do.
[Re: wunderless]
#1114494
11/16/11 01:37 PM
11/16/11 01:37 PM
Posts: 2,930 Odessa, Tx.
cudarex
Odessa, Tx.
X2
[Re: Mr340]
#1114497
11/16/11 03:14 PM
11/16/11 03:14 PM
Posts: 6,497 N.E. Ohio
KillerBee
N.E. Ohio
I had big obnoxious monster tach with shift light mounted like Mr340's for years. Got tired of it covering up half the dash so I decided to ditch the setup and mount a small shift light behind one of my dash idiot lights. Having an RPM activated shift light is awesome, especially with a 4 speed, but I really don't need a big tachometer...I can tell if my car is idling low or high.
[Re: Blues_Cuda]
#1114498
11/16/11 11:13 PM
11/16/11 11:13 PM
Posts: 801 central CT
cudazappa
central CT
I mounted mine similarly to Blues_Cuda, using the dash screw on the left side of my standard gauge cluster. I can't see the light switch, but it's easy enough to feel for.
1971 Challenger
[Re: Blues_Cuda]
#1114500
11/17/11 06:27 PM
11/17/11 06:27 PM
Posts: 3,623 Millinocket, Maine
JonC
Millinocket, Maine
I used an existing hole, for I hate drilling unless I positively have to do so.
Is that a one screw bracket? And what make is the tach?
[Re: JonC]
#1114501
11/17/11 10:49 PM
11/17/11 10:49 PM
Posts: 3,897 St. Louis, MO
Blues_Cuda
St. Louis, MO
It's an AutoMeter Sport Comp in 3 3/8". Historically, I always had 5" Monster tachs on the previous cars and wanted to get away from that look. This one is mounted in front of the factory tach, so nothing important is covered except for a portion of the right blinker. I can still see it though.
It's a one screw bracket. I initially thought it would not be sturdy enough, but after 5+ years of rough roads and drag strip launches it is holding out just fine.
I did make the black bracket that attaches the tach to the light panel screw hole. It's just a simple aluminum channel that I had lying around. If I remember correctly, the Auto Meter bracket just would not work out for me. It's been a while...cannot remember the details.
[Re: JonC]
#1114503
11/17/11 11:00 PM
11/17/11 11:00 PM
Posts: 12,290 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I mounted my AutoMeter tach on the column. I just used 2 radiator clamps screwed together and some foam between the column and the clamp for friction and to protect the column. I also used some tissue on the back of the tach so that the tach wouldn't mar the face of the factory tach in case it rubbed it. I have had the tach mounted like this for years with no problems.
Master, again and still
[Re: JonC]
#1114505
11/20/11 01:17 AM
11/20/11 01:17 AM
Posts: 215 mo
ALKYW5DART
mo
[Re: ALKYW5DART]
#1114506
11/20/11 03:23 PM
11/20/11 03:23 PM
Posts: 8,857 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
i didnt want to drill any holes in my dash and just flat dont care for the look of putting a gage in front of other gages or hanginh off steering column that being said i took a peice of 1" wide flat stock bout 10" long or so bent it like a candy cane the short side up mounted my 5"monster tach on it long side is held to the bottom side of dash where the light bar is has nice bend that fits close to the pad but never touches it never have to look down at the tach can easy be removed if need be ,no repaint the column,no covering up other gages
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: toplescuda]
#1114507
11/20/11 03:27 PM
11/20/11 03:27 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
not really best pics but think ya get the ideal
[Re: toplescuda]
#1114508
11/20/11 06:06 PM
11/20/11 06:06 PM
JonC
Millinocket, Maine
I'd like to see better pics of that setup.
