E-Body tach location (aftermarket) #1114490
11/15/11 09:49 PM
11/15/11 09:49 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
How are you Ebody guys attaching your aftermarket tachs and where? I really don't want to drill holes or scratch the steering column. Pics and ideas are welcome.
Re: E-Body tach location (aftermarket) [Re: JonC] #1114491
11/15/11 10:28 PM
11/15/11 10:28 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: E-Body tach location (aftermarket) [Re: GoodysGotaCuda] #1114492
11/16/11 09:55 AM
11/16/11 09:55 AM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
don't mind the messy wiring, I had just installed my O2 gauge and was testing before cleaning up the wiring.
Re: E-Body tach location (aftermarket) [Re: Mr340] #1114493
11/16/11 10:05 AM
11/16/11 10:05 AM
o
wunderless Offline
wunderless  Offline
o
Mine's the same as Mr340. Tucked away in the corner but still usefull.
But existing is basically all I do.
Re: E-Body tach location (aftermarket) [Re: wunderless] #1114494
11/16/11 01:37 PM
11/16/11 01:37 PM
Odessa, Tx.
cudarex Offline
cudarex  Offline
Odessa, Tx.
X2
Re: E-Body tach location (aftermarket) [Re: cudarex] #1114495
11/16/11 02:57 PM
11/16/11 02:57 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
Excuse the dust in the picture. The car has not been driven for a couple weeks.
Re: E-Body tach location (aftermarket) [Re: Blues_Cuda] #1114496
11/16/11 03:10 PM
11/16/11 03:10 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
I used an existing hole, for I hate drilling unless I positively have to do so.
Re: E-Body tach location (aftermarket) [Re: Mr340] #1114497
11/16/11 03:14 PM
11/16/11 03:14 PM
N.E. Ohio
K
KillerBee Offline
KillerBee  Offline
K
N.E. Ohio
I had big obnoxious monster tach with shift light mounted like Mr340's for years.
Got tired of it covering up half the dash so I decided to ditch the setup and mount a small shift light behind one of my dash idiot lights.
Having an RPM activated shift light is awesome, especially with a 4 speed, but I really don't need a big tachometer...I can tell if my car is idling low or high.
Re: E-Body tach location (aftermarket) [Re: Blues_Cuda] #1114498
11/16/11 11:13 PM
11/16/11 11:13 PM
central CT
cudazappa Offline
cudazappa  Offline
central CT
I mounted mine similarly to Blues_Cuda, using the dash screw on the left side of my standard gauge cluster. I can't see the light switch, but it's easy enough to feel for.
1971 Challenger
Re: E-Body tach location (aftermarket) [Re: cudazappa] #1114499
11/17/11 06:23 PM
11/17/11 06:23 PM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
Re: E-Body tach location (aftermarket) [Re: Blues_Cuda] #1114500
11/17/11 06:27 PM
11/17/11 06:27 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
Is that a one screw bracket? And what make is the tach?
Re: E-Body tach location (aftermarket) [Re: JonC] #1114501
11/17/11 10:49 PM
11/17/11 10:49 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
It's an AutoMeter Sport Comp in 3 3/8". Historically, I always had 5" Monster tachs on the previous cars and wanted to get away from that look. This one is mounted in front of the factory tach, so nothing important is covered except for a portion of the right blinker. I can still see it though.
It's a one screw bracket. I initially thought it would not be sturdy enough, but after 5+ years of rough roads and drag strip launches it is holding out just fine.
I did make the black bracket that attaches the tach to the light panel screw hole. It's just a simple aluminum channel that I had lying around. If I remember correctly, the Auto Meter bracket just would not work out for me. It's been a while...cannot remember the details.
Re: E-Body tach location (aftermarket) [Re: Blues_Cuda] #1114502
11/17/11 10:58 PM
11/17/11 10:58 PM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
I like this particular tach because it kinda matches the factory gauges to some extent and it's a name brand. It's relatively affordable as well. Around $100 if I remember correctly.
I really dislike seeing a Wal-Mart brand tach in a musclecar. There's an orange survivor Hemi Cuda down the road from me that is ultra cool, but the dime store tach really knocks it down a few nothces.
Re: E-Body tach location (aftermarket) [Re: JonC] #1114503
11/17/11 11:00 PM
11/17/11 11:00 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I mounted my AutoMeter tach on the column. I just used 2 radiator clamps screwed together and some foam between the column and the clamp for friction and to protect the column.
I also used some tissue on the back of the tach so that the tach wouldn't mar the face of the factory tach in case it rubbed it.
I have had the tach mounted like this for years with no problems.
Master, again and still
Re: E-Body tach location (aftermarket) [Re: DaveRS23] #1114504
11/17/11 11:12 PM
11/17/11 11:12 PM
NH
72challorange Offline
He's Game
He's Game
NH
Small tach/shift light utilizing existing screws.
Tom
Re: E-Body tach location (aftermarket) [Re: JonC] #1114505
11/20/11 01:17 AM
11/20/11 01:17 AM
mo
ALKYW5DART Offline
ALKYW5DART  Offline
mo
mine
Re: E-Body tach location (aftermarket) [Re: ALKYW5DART] #1114506
11/20/11 03:23 PM
11/20/11 03:23 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
i didnt want to drill any holes in my dash and just flat dont care for the look of putting a gage in front of other gages or hanginh off steering column
that being said i took a peice of 1" wide flat stock bout 10" long or so
bent it like a candy cane the short side up mounted my 5"monster tach on it
long side is held to the bottom side of dash where the light bar is
has nice bend that fits close to the pad but never touches it
never have to look down at the tach
can easy be removed if need be ,no repaint the column,no covering up other gages
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: E-Body tach location (aftermarket) [Re: toplescuda] #1114507
11/20/11 03:27 PM
11/20/11 03:27 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
not really best pics but think ya get the ideal
1971 charger
Re: E-Body tach location (aftermarket) [Re: toplescuda] #1114508
11/20/11 06:06 PM
11/20/11 06:06 PM
Millinocket, Maine
JonC Offline OP
JonC  Offline OP
Millinocket, Maine
I'd like to see better pics of that setup.
Re: E-Body tach location (aftermarket) [Re: JonC] #1114509
11/20/11 06:09 PM
11/20/11 06:09 PM
Posting from 1893 in NW FL
TheBlueBeast Offline
Since e body stuff is so chaep just bondo it to the hood.
