I have never seen this before....new fuel pump!!! #1112880
11/13/11 06:54 PM
11/13/11 06:54 PM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
Has anybody ever played with one of these before??
http://www.ebay.com/itm/Race-Pumps-Pisto...=item4cf0ee0857
This could be something kinda cool!!
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: I have never seen this before....new fuel pump!!! [Re: Troy] #1112881
11/13/11 07:00 PM
11/13/11 07:00 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
McRobb sells them... I haven't played with one..
Re: I have never seen this before....new fuel pump!!! [Re: 1_WILD_RT] #1112882
11/13/11 08:12 PM
11/13/11 08:12 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I just got mine 2 weeks ago, they send it with candy and a nice crushed velour bag. Its a good looking product, I got the regulator too, but I still need the check valve and primer pump, for my stock tank. TIm
Re: I have never seen this before....new fuel pump!!! [Re: Troy] #1112883
11/13/11 08:16 PM
11/13/11 08:16 PM
Vancouver, WA
MoparMarq Offline
MoparMarq  Offline
Vancouver, WA
So it looks like the pushrod goes up through the pushrod hole in the block where the plug is located.
How does the hole in the block get sealed from oil leakage around the pushrod?
And the price...
Just to save 2 pounds?!
Re: I have never seen this before....new fuel pump!!! [Re: MoparMarq] #1112884
11/13/11 08:37 PM
11/13/11 08:37 PM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
And the price...
To me it's not the two pounds or anything like that....it is the simplicity of it all. Less drag on the engine and even the safety side of it. Yes you can run an electric pump but how many times have you left the pump on or forgot to shut it off? Your needle in your carb sticks and your engine dies with fuel flowing everywhere?? There are definitely some advantages to a pump like this on all street and strip applications. The true question is does it work??
Re: I have never seen this before....new fuel pump!!! [Re: Troy] #1112885
11/13/11 08:46 PM
11/13/11 08:46 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
Never. Mine has the pump mrelay wired to the ignition circuit. No key on, no gas pumpy.
Re: I have never seen this before....new fuel pump!!! [Re: Troy] #1112886
11/13/11 08:49 PM
11/13/11 08:49 PM
Mira Loma, CA
69B3GT Offline
69B3GT  Offline
Mira Loma, CA
I saw the price and didnt even read the ad. I didnt pay that much for a running 440-727 and the mounts and headers to put it in the car
Re: I have never seen this before....new fuel pump!!! [Re: MoparMarq] #1112887
11/13/11 08:58 PM
11/13/11 08:58 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
And the price...
I think the pump pictured is for a small block Chevy.. How would it seal to a big block Mopar?
Could you post a picture?
Re: I have never seen this before....new fuel pump!!! [Re: MoparMarq] #1112888
11/13/11 09:02 PM
11/13/11 09:02 PM
jersey
Spaceman Spiff Offline
jersey
And the price...
$320 isn't that expensive for a quality pump.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: I have never seen this before....new fuel pump!!! [Re: 1_WILD_RT] #1112889
11/13/11 09:06 PM
11/13/11 09:06 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
They block of the original pump hole with a machined phenolic block, the plug where the push rod goes is where the actuator goes and seals with a flat Oring. I have to use this pump if I want a mechanical pump on my world block. You cannot grind enough to get a carter to fit. Tim
http://www.racepumps.com/FuelPumps-Street.html
Re: I have never seen this before....new fuel pump!!! [Re: astjp2] #1112890
11/14/11 10:20 AM
11/14/11 10:20 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Why do you need 50 psi of fuel for your carb'd engine? Yeah...you could put a regulator on it...But I wonder if someone didn't do it and found all their gaskets and O-rings destroyed in the carbs.
I like the "RacePump should last for years, but it can be damaged by junk in the fuel line. It is rebuildable with a $10.00 kit."
So the other $310 is primarily made up of aluminum...thats expensive...
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
