Can anyone tell me what gauge OEM battery cables are? #1111349
11/11/11 05:15 PM
11/11/11 05:15 PM
Houston Texas
PAINT IT BLACK Offline OP
Got a CHIP on my shoulder
Houston Texas
Need to know what gauge OEM battery cables are on a 1970 Barracuda. I'm needing a custom length battery cable... I'd like to have OEM appearing terminals and insulation... can anyone point me in the right direction as to where I should buy?
Thanks in advance...
Re: Can anyone tell me what gauge OEM battery cables are? [Re: PAINT IT BLACK] #1111350
11/11/11 05:23 PM
11/11/11 05:23 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
It's been a long time since I cut an OEM cable open, but I would guess either 2AWG or 4AWG. That's pretty much all I've seen for replacements.
Re: Can anyone tell me what gauge OEM battery cables are? [Re: topside] #1111351
11/11/11 05:35 PM
11/11/11 05:35 PM
Anderson, IN
1969RR Offline
1969RR  Offline
Anderson, IN
4AWG is what I used on mine. Was almost exactly the same as the OE cable. Jeff
Re: Can anyone tell me what gauge OEM battery cables are? [Re: 1969RR] #1111352
11/11/11 09:51 PM
11/11/11 09:51 PM
Houston Texas
Houston Texas
Thanks..
Re: Can anyone tell me what gauge OEM battery cables are? [Re: PAINT IT BLACK] #1111353
11/11/11 10:38 PM
11/11/11 10:38 PM
Your going custom anyhow so might check the appearance (larger dia) of 2 ga & see if you can live with that. It'll help w voltage drops as is & esp if you add draws and a larger output alt later on EDIT Did not know you were going to the trunk. I would go larger than 2 ga, 1/0 or 2/0
Re: Can anyone tell me what gauge OEM battery cables are? [Re: RapidRobert] #1111354
11/11/11 11:01 PM
11/11/11 11:01 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Like Robert says. If you're putting the battery in the trunk, 2AWG is minimum.
Re: Can anyone tell me what gauge OEM battery cables are? [Re: RapidRobert] #1111355
11/13/11 12:24 PM
11/13/11 12:24 PM
Houston Texas
Houston Texas
The battery is NOT in the trunk. It is in the factory spot, but I added a cutoff switch at the core support to kill the battery when it is parked. It requires me to pit stop the (+) at the core before it goes to the starter, etc... Therefore I need new cables, but I really don't want huge obnoxious cables and I never experienced voltage drops before.
