Re: Can anyone tell me what gauge OEM battery cables are?
[Re: PAINT IT BLACK]
#1111353
11/11/11 10:38 PM
11/11/11 10:38 PM
RapidRobert
Your going custom anyhow so might check the appearance (larger dia) of 2 ga & see if you can live with that. It'll help w voltage drops as is & esp if you add draws and a larger output alt later on EDIT Did not know you were going to the trunk. I would go larger than 2 ga, 1/0 or 2/0
