Page 2 of 4 1 2 3 4
Re: OK, first passes on the 408, guess the ET and MPH [Re: Quicktree] #1110298
11/09/11 07:08 PM
11/09/11 07:08 PM
Guitar Jones Online laugh2 OP
And you know what? I must be retarded, the heads flow 330 @ .700 not 230. What a dolt I am. I really shouldn't drink before before noon.
I knew something was wrong with that picture. I think 9.60s are a given. with a better converter you could reach 50s or better imo. oh yea say a prayer for the rear.
To be honest I'm not worried about the rear...yet. It's an aluminum carrier with a pro gear and only 44" wide. It's well braced but I have to admit that if I had it to do over again I would have gone with a Dana.
Re: OK, first passes on the 408, guess the ET and MPH [Re: Hitman340] #1110299
11/09/11 07:11 PM
11/09/11 07:11 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I see no reason it for it not to run 9.30s at around 139mph.
it should
Re: OK, first passes on the 408, guess the ET and MPH [Re: Guitar Jones] #1110300
11/09/11 07:14 PM
11/09/11 07:14 PM
Q
Quicktree Offline
Quicktree  Offline
Q
you should be fine with that, i forgot it's light also.
Re: OK, first passes on the 408, guess the ET and MPH [Re: Quicktree] #1110301
11/09/11 07:18 PM
11/09/11 07:18 PM
A converter redo is also needed I know but that will have to wait until after the holidays.
Re: OK, first passes on the 408, guess the ET and MPH [Re: Quicktree] #1110302
11/09/11 11:01 PM
11/09/11 11:01 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Re: OK, first passes on the 408, guess the ET and MPH [Re: viperblue72] #1110303
11/10/11 02:37 AM
11/10/11 02:37 AM
Winter Park, Florida
classracer Offline
classracer  Offline
10.40's @ 126.50
Just kidding. See ya Saturday!!!!! Jimbo
Re: OK, first passes on the 408, guess the ET and MPH [Re: classracer] #1110304
11/10/11 07:05 AM
11/10/11 07:05 AM
10.40's @ 126.50
Ha ha, head porter humor I guess.
Re: OK, first passes on the 408, guess the ET and MPH [Re: Guitar Jones] #1110305
11/10/11 08:52 AM
11/10/11 08:52 AM
tboomer Offline
tboomer  Offline
9.45 at 142 mph...
Re: OK, first passes on the 408, guess the ET and MPH [Re: tboomer] #1110306
11/10/11 03:35 PM
11/10/11 03:35 PM
sweden
sshemi Offline
sshemi  Offline
sweden
10.0 @ 135 first run
Re: OK, first passes on the 408, guess the ET and MPH [Re: Guitar Jones] #1110307
11/10/11 03:38 PM
11/10/11 03:38 PM
SoCal
Brian Hafliger Offline
SoCal
And you know what? I must be retarded, the heads flow 330 @ .700 not 230. What a dolt I am. I really shouldn't drink before noon.
At least share!
Brian Hafliger
Re: OK, first passes on the 408, guess the ET and MPH [Re: Brian Hafliger] #1110308
11/10/11 04:09 PM
11/10/11 04:09 PM
At least share!
I always share!
Re: OK, first passes on the 408, guess the ET and MPH [Re: Brian Hafliger] #1110309
11/10/11 04:17 PM
11/10/11 04:17 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
my 422 w5 with a hair smaller cam, TTi headers, and a single dominator went 9.85 at 3350 pounds on gas, with a 727, small tires and leaf springs.
If this runs as good,( and with a bigger cam and better headers it should easily) and is 700 pounds lighter with a 904, it should go 9.20's without working up a sweat at 142- 143ish.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: OK, first passes on the 408, guess the ET and MPH [Re: B3422W5] #1110310
11/10/11 05:15 PM
11/10/11 05:15 PM
I certainly like what you guys are saying. Way beyond my expectations.
Re: OK, first passes on the 408, guess the ET and MPH [Re: sshemi] #1110311
11/10/11 05:30 PM
11/10/11 05:30 PM
First pass doesn't count as it will be a half track pass just to make sure nothing falls off the car.
Re: OK, first passes on the 408, guess the ET and MPH [Re: Guitar Jones] #1110312
11/10/11 05:34 PM
11/10/11 05:34 PM
sweden
sshemi Offline
sshemi  Offline
sweden
ok first true pass then
Re: OK, first passes on the 408, guess the ET and MPH [Re: sshemi] #1110313
11/10/11 05:38 PM
11/10/11 05:38 PM
It better be faster than that!
Re: OK, first passes on the 408, guess the ET and MPH [Re: Guitar Jones] #1110314
11/10/11 09:01 PM
11/10/11 09:01 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
bro a 4 link w 14x32's that should hook on an ice patch
Re: OK, first passes on the 408, guess the ET and MPH [Re: fishy340] #1110315
11/10/11 10:23 PM
11/10/11 10:23 PM
I have no complaints about the way the car works, it just leaves like it's on a string.
Re: OK, first passes on the 408, guess the ET and MPH [Re: Guitar Jones] #1110316
11/12/11 03:36 PM
11/12/11 03:36 PM
California, USA!!!
W
WheelsUp73 Offline
WheelsUp73  Offline
W
California, USA!!!
2650 is with me in it as it sits on the line. Maybe I should mention these are small chamber W5's with double quench pads, .032 piston to head.
At .032 piston to head you are risking having the piston hit the head at upper RPM's... .038 clearence is as tight as I would set it up at. Good luck! My 11.to 1 410 with edelbrock heads and 600 lift solid lifter cam ran 10.08 at 131, race weight 3134 #s
Re: OK, first passes on the 408, guess the ET and MPH [Re: WheelsUp73] #1110317
11/12/11 07:16 PM
11/12/11 07:16 PM
My old engine was .027 piston to head. 7500 rpm and more without a problem.
Page 2 of 4 1 2 3 4
