Re: OK, first passes on the 408, guess the ET and MPH
[Re: Quicktree]
#1110298
11/09/11 07:08 PM
11/09/11 07:08 PM
Posts: 20,646 in a cattle trailer down by th...
Guitar Jones
And you know what? I must be retarded, the heads flow 330 @ .700 not 230. What a dolt I am. I really shouldn't drink before before noon.
I knew something was wrong with that picture. I think 9.60s are a given. with a better converter you could reach 50s or better imo. oh yea say a prayer for the rear.
To be honest I'm not worried about the rear...yet. It's an aluminum carrier with a pro gear and only 44" wide. It's well braced but I have to admit that if I had it to do over again I would have gone with a Dana.
[Re: Hitman340]
#1110299
11/09/11 07:11 PM
11/09/11 07:11 PM
Quicktree
I see no reason it for it not to run 9.30s at around 139mph.
it should
[Re: Guitar Jones]
#1110300
11/09/11 07:14 PM
11/09/11 07:14 PM
Quicktree
you should be fine with that, i forgot it's light also.
[Re: Quicktree]
#1110301
11/09/11 07:18 PM
11/09/11 07:18 PM
Guitar Jones
A converter redo is also needed I know but that will have to wait until after the holidays.
[Re: classracer]
#1110304
11/10/11 07:05 AM
11/10/11 07:05 AM
Guitar Jones
10.40's @ 126.50
Just kidding. See ya Saturday!!!!! Jimbo
Ha ha, head porter humor I guess.
[Re: tboomer]
#1110306
11/10/11 03:35 PM
11/10/11 03:35 PM
Posts: 2,128 sweden
sshemi
sweden
[Re: Brian Hafliger]
#1110308
11/10/11 04:09 PM
11/10/11 04:09 PM
Guitar Jones
And you know what? I must be retarded, the heads flow 330 @ .700 not 230. What a dolt I am. I really shouldn't drink before noon.
At least share!
I always share!
#1110309
11/10/11 04:17 PM
11/10/11 04:17 PM
Posts: 11,721 Portage,michigan
B3422W5
Portage,michigan
my 422 w5 with a hair smaller cam, TTi headers, and a single dominator went 9.85 at 3350 pounds on gas, with a 727, small tires and leaf springs.
If this runs as good,( and with a bigger cam and better headers it should easily) and is 700 pounds lighter with a 904, it should go 9.20's without working up a sweat at 142- 143ish.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: B3422W5]
#1110310
11/10/11 05:15 PM
11/10/11 05:15 PM
Guitar Jones
I certainly like what you guys are saying. Way beyond my expectations.
[Re: sshemi]
#1110311
11/10/11 05:30 PM
11/10/11 05:30 PM
Guitar Jones
10.0 @ 135 first run
First pass doesn't count as it will be a half track pass just to make sure nothing falls off the car.
[Re: Guitar Jones]
#1110312
11/10/11 05:34 PM
11/10/11 05:34 PM
Posts: 2,128 sweden
sshemi
sweden
ok first true pass then
[Re: sshemi]
#1110313
11/10/11 05:38 PM
11/10/11 05:38 PM
Guitar Jones
It better be faster than that!
[Re: fishy340]
#1110315
11/10/11 10:23 PM
11/10/11 10:23 PM
Guitar Jones
bro a 4 link w 14x32's that should hook on an ice patch
I have no complaints about the way the car works, it just leaves like it's on a string.
[Re: Guitar Jones]
#1110316
11/12/11 03:36 PM
11/12/11 03:36 PM
Posts: 369 California, USA!!!
WheelsUp73
California, USA!!!
2650 is with me in it as it sits on the line. Maybe I should mention these are small chamber W5's with double quench pads, .032 piston to head.
At .032 piston to head you are risking having the piston hit the head at upper RPM's... .038 clearence is as tight as I would set it up at. Good luck! My 11.to 1 410 with edelbrock heads and 600 lift solid lifter cam ran 10.08 at 131, race weight 3134 #s
[Re: WheelsUp73]
#1110317
11/12/11 07:16 PM
11/12/11 07:16 PM
Guitar Jones
My old engine was .027 piston to head. 7500 rpm and more without a problem.
