426 HEMI block # stampings help #1109594
11/08/11 10:53 PM
11/08/11 10:53 PM
Cincinnati OH
Bishop Offline OP
Bishop  Offline OP
Cincinnati OH
I have a 426 HEMI block cast in 10 10 66 with WT & A on the engine ID pad and NM4262280022 stamped on the "Starter ear" down on the oil pan face what do these Numbers mean?
Thanks Brian
Re: 426 HEMI block # stampings help [Re: Bishop] #1109595
11/08/11 11:00 PM
11/08/11 11:00 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
NM42622800022
That is the date it was assembled which decodes as October 25, 1967. This means that it was originally built and installed in a 1968 model year Hemi car. The VIN sequence should appear stamped into the top of the blocks rear trans mating flange adjacent to the oil sender unit hole.
Re: 426 HEMI block # stampings help [Re: ScottSmith_Harms] #1109596
11/08/11 11:49 PM
11/08/11 11:49 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
That is one of the best 1968 block stampings that I have seen... usually they are more like this:
Re: 426 HEMI block # stampings help [Re: xs29j8] #1109597
11/09/11 06:23 PM
11/09/11 06:23 PM
Cincinnati OH
Bishop Offline OP
Bishop  Offline OP
Cincinnati OH
I'll have to check out the VIN # after it comes back from the shop, its getting cleaned. What does the NM mean before the 426?
Thanks Brian
Re: 426 HEMI block # stampings help [Re: Bishop] #1109598
11/09/11 06:39 PM
11/09/11 06:39 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Pretty sure that NM is the plant code.
Re: 426 HEMI block # stampings help [Re: JohnRR] #1109599
11/09/11 07:41 PM
11/09/11 07:41 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I'm guessing that is a mis-strike on the ID number. MV or MN was the Marysville engine plant.
Re: 426 HEMI block # stampings help [Re: 6PakBee] #1109600
11/09/11 08:20 PM
11/09/11 08:20 PM
JohnRR Offline
JohnRR  Offline
Was that the plant Hemis were built at ?
Re: 426 HEMI block # stampings help [Re: JohnRR] #1109601
11/10/11 01:27 AM
11/10/11 01:27 AM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
WT means water test, A means .020 over the spec bore size. Back in the day, Chrysler rarely threw anything away; they'd fix bores, bearing sizes, lifter bores, and guides to use a block casting.
Re: 426 HEMI block # stampings help [Re: JohnRR] #1109602
11/10/11 08:37 AM
11/10/11 08:37 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I've seen more than one of the '68 and later Hemi blocks with the 'MN' prefix on the ID # so I would say that Hemis were built there. Was that the only plant? I thought that Mound Road built them too but I can't find any examples of this.
Re: 426 HEMI block # stampings help [Re: 6PakBee] #1109603
11/10/11 09:43 AM
11/10/11 09:43 AM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
Hemis were only built at Marysville (MN or MV), not at Mound Road (PM,GM,HM)...
Re: 426 HEMI block # stampings help [Re: xs29j8] #1109604
11/11/11 11:20 AM
11/11/11 11:20 AM
Cincinnati OH
Bishop Offline OP
Bishop  Offline OP
Cincinnati OH
I just got back the Hemi block from the shop today from getting a good cleaning and I don't see any numbers stamped on the top of the back of the block for the VIN, could this be a over the counter block?
Thanks Brian
Re: 426 HEMI block # stampings help [Re: Bishop] #1109605
11/11/11 01:08 PM
11/11/11 01:08 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
No. With the assembly stamping on the bottom of the motor, this started life as an engine, not a bare block.
Re: 426 HEMI block # stampings help [Re: Bishop] #1109606
11/11/11 01:43 PM
11/11/11 01:43 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
Thanks Brian
This older thread may shed some light on a possible reason:
Earlier thread on this subject...
Re: 426 HEMI block # stampings help [Re: xs29j8] #1109607
11/14/11 05:41 PM
11/14/11 05:41 PM
Cincinnati OH
Bishop Offline OP
Bishop  Offline OP
Cincinnati OH
Maybe the engine block was never stamped? Should the enginge ID pad have something else stamped on it?
Re: 426 HEMI block # stampings help [Re: Bishop] #1109608
11/14/11 06:09 PM
11/14/11 06:09 PM
JohnRR Offline
JohnRR  Offline
If the only thing on the ID pad up top is WT and A then it's more than likely an over the counter short block assembly and wasn't a production line install.
Is there a small , 1/8" maybe , blind hole near a freeze plug ?
Re: 426 HEMI block # stampings help [Re: JohnRR] #1109609
11/14/11 09:10 PM
11/14/11 09:10 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
It would probably be best to start posting pics of each side of the block and any machined stamp pad areas with markings.
Re: 426 HEMI block # stampings help [Re: ScottSmith_Harms] #1109610
11/14/11 11:13 PM
11/14/11 11:13 PM
Cincinnati OH
Bishop Offline OP
Bishop  Offline OP
Cincinnati OH
side picture
Re: 426 HEMI block # stampings help [Re: Bishop] #1109611
11/15/11 12:48 AM
11/15/11 12:48 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Great shot, good high res pic. A similar shot of the other side, the rear, the front, and the bottom, plus of course the machined areas with numbers stamps would be helpful
Re: 426 HEMI block # stampings help [Re: JohnRR] #1109612
11/15/11 04:11 AM
11/15/11 04:11 AM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
Well, my numbers matching block for my '68 Charger only has WT & A (actually T W & A)...
I bought the car in about 1977...
Re: 426 HEMI block # stampings help [Re: xs29j8] #1109613
11/15/11 08:47 AM
11/15/11 08:47 AM
JohnRR Offline
JohnRR  Offline
