Re: 426 HEMI block # stampings help
[Re: JohnRR]
#1109599
11/09/11 07:41 PM
11/09/11 07:41 PM
Posts: 10,731 North Dakota
6PakBee
North Dakota
I'm guessing that is a mis-strike on the ID number. MV or MN was the Marysville engine plant.
[Re: 6PakBee]
#1109600
11/09/11 08:20 PM
11/09/11 08:20 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Was that the plant Hemis were built at ?
[Re: 6PakBee]
#1109603
11/10/11 09:43 AM
11/10/11 09:43 AM
Posts: 3,624 Fort Worth, Texas
xs29j8
Fort Worth, Texas
I've seen more than one of the '68 and later Hemi blocks with the 'MN' prefix on the ID # so I would say that Hemis were built there. Was that the only plant? I thought that Mound Road built them too but I can't find any examples of this.
Hemis were only built at Marysville (MN or MV), not at Mound Road (PM,GM,HM)...
[Re: Bishop]
#1109605
11/11/11 01:08 PM
11/11/11 01:08 PM
6PakBee
North Dakota
No. With the assembly stamping on the bottom of the motor, this started life as an engine, not a bare block.
[Re: Bishop]
#1109606
11/11/11 01:43 PM
11/11/11 01:43 PM
xs29j8
Fort Worth, Texas
I just got back the Hemi block from the shop today from getting a good cleaning and I don't see any numbers stamped on the top of the back of the block for the VIN, could this be a over the counter block?
Thanks Brian
This older thread may shed some light on a possible reason:
Earlier thread on this subject...
[Re: Bishop]
#1109608
11/14/11 06:09 PM
11/14/11 06:09 PM
JohnRR
U.S.S.A.
Maybe the engine block was never stamped? Should the enginge ID pad have something else stamped on it?
If the only thing on the ID pad up top is WT and A then it's more than likely an over the counter short block assembly and wasn't a production line install.
Is there a small , 1/8" maybe , blind hole near a freeze plug ?
[Re: JohnRR]
#1109612
11/15/11 04:11 AM
11/15/11 04:11 AM
xs29j8
Fort Worth, Texas
Well, my numbers matching block for my '68 Charger only has WT & A (actually T W & A)...
I bought the car in about 1977...
