Re: Super Stealth heads
[Re: 6PACMAC]
#1108210
11/06/11 10:18 PM
11/06/11 10:18 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
maybe the best flowing, stock length valve cylinder head,
Can you elaborate on that since no flow numbers were given and they have to be finished ???
[Re: JohnRR]
#1108211
11/06/11 11:07 PM
11/06/11 11:07 PM
Posts: 2,141 junction city oregon
viperblue72
If he could have elaborated he wouldn't have said "maybe". But you are correct that Brandon was a little vague about a few of the specifics. No intake volume size either but he did say not quite a max wedge size. and valves seats are 2.14x1.81 iirc. Chambers are same as standard stealths at 80cc.
[Re: viperblue72]
#1108212
11/06/11 11:09 PM
11/06/11 11:09 PM
viperblue72
If he could have elaborated he wouldn't have said "maybe", but being there aren't any other aftermarket factory appearing heads out there he is probably right. But you are correct that Brandon was a little vague about a few of the specifics. No intake volume size either but he did say not quite a max wedge size. and valves seats are 2.14x1.81 iirc. Chambers are same as standard stealths at 80cc.
[Re: JohnRR]
#1108213
11/06/11 11:16 PM
11/06/11 11:16 PM
Posts: 915 S.W. PA
6PACMAC
S.W. PA
The key word is "maybe".
[Re: 6PACMAC]
#1108215
11/07/11 07:49 PM
11/07/11 07:49 PM
BradH
Man the casting really look super thin around the pushrod hole.
Too thin for my taste. Those things better come w/ the phone number of your closest qualified aluminum welder.
