Page 2 of 3 1 2 3
Re: 440 build Any sugestions? [Re: BradH] #1105942
11/03/11 04:14 PM
11/03/11 04:14 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Another vote here for good rods, even before a roller cam
Re: 440 build Any sugestions? [Re: HotRodDave] #1105943
11/03/11 04:27 PM
11/03/11 04:27 PM
bigfork mn
dragram440 Offline OP
bigfork mn
Im sure the LY rods will work fine on a mild build like this one! They are already resized and balanced with the rest of the rotating assembly. Fairly low compression and not to many RPM's and im sure they will live just fine!
67' charger 499 RB 10.57 at 127
Re: 440 build Any sugestions? [Re: dragram440] #1105944
11/03/11 04:31 PM
11/03/11 04:31 PM
Marcell, MN
68 Roadrunner Offline
Marcell, MN
Maybe it's just me but it doesn't seem that mild. To me mild would be stock heads with a cam, intake, carb and headers. This sounds like a disaster waiting to happen! Lol
1968 Roadrunner 383 auto .060 KB 400 domed pistons, Stealth heads, Torker intake, Holley 830, Lunati Voodoo cam 276/284, .513/.533, TCI 3500, 3.91 gears, all ARP fasteners,
Re: 440 build Any sugestions? [Re: dragram440] #1105945
11/03/11 04:33 PM
11/03/11 04:33 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
My car was only running mid-to-high 12s and turning 5800 RPM when it spit the rod out I mentioned. They might be fine, or they might be time bombs...
Re: 440 build Any sugestions? [Re: 68 Roadrunner] #1105946
11/03/11 04:35 PM
11/03/11 04:35 PM
bigfork mn
bigfork mn
11-1 comp. 3800 converter and 3.91 gears and .590 flat tappet cam is about as mild as it gets. stock heads cam and intake sounds weak. Might as well build a 383 if thats the case!
Re: 440 build Any sugestions? [Re: dragram440] #1105947
11/03/11 04:47 PM
11/03/11 04:47 PM
Marcell, MN
Marcell, MN
I guess only time will tell.
Re: 440 build Any sugestions? [Re: dragram440] #1105948
11/03/11 04:52 PM
11/03/11 04:52 PM
BradH Offline
BradH  Offline
...and any suggestions on other opinions would be appreciated.
The rod issue has been raised by a number of people, yet you continue to ignore the legit concern. I don't think you really want other's opinions unless they already fall in line w/ your own.
Re: 440 build Any sugestions? [Re: BradH] #1105949
11/03/11 04:55 PM
11/03/11 04:55 PM
Marcell, MN
Marcell, MN
I am getting the same feeling. Lol
Re: 440 build Any sugestions? [Re: 68 Roadrunner] #1105950
11/03/11 05:12 PM
11/03/11 05:12 PM
bigfork mn
bigfork mn
My last mild 440 build had a rod failure. Im certainly not saying they are good rods. I dont have em in mine. My bent rod experience was not good. Im certainly not blaiming the rods on my issues though. Poor machine work none balanced and unfinished cylinders three years of runs and Nitrous was the culpret in my deal. I would certainly agree the rods are the weak link in this build.
Re: 440 build Any sugestions? [Re: dragram440] #1105951
11/03/11 05:20 PM
11/03/11 05:20 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Stick with the 440. It may not make the same hp but it'll spin the tires real good.
Re: 440 build Any sugestions? [Re: RemCharger] #1105952
11/03/11 05:30 PM
11/03/11 05:30 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
Surely he will have to turn the screw a bit to get the victor's to work.
RPM's would have been a better choice for a 440 with ly rods. If the car is reasonably light, 500 hp would drop into the tens, which could be achieved without having to rev the nuts off it.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: 440 build Any sugestions? [Re: deaks] #1105953
11/03/11 05:42 PM
11/03/11 05:42 PM
bigfork mn
bigfork mn
Mick
The screw is loose and I think the nuts are already off!
Re: 440 build Any sugestions? [Re: dragram440] #1105954
11/03/11 05:51 PM
11/03/11 05:51 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
best 60ft 1.36
Re: 440 build Any sugestions? [Re: deaks] #1105955
11/03/11 06:46 PM
11/03/11 06:46 PM
reynoldsburg,ohio
poppaj Offline
poppaj  Offline
reynoldsburg,ohio
If you use stock rods even reconditioned with new bolts they will always be a concern. Better off spending a few hundred now and get a decent set of rods, have the rotating assembly balanced. It will be the best money you can spend at this point.
AA/NSS 65'Coronet "Whompin Wedge"
Pop & Son Performance 557" B-1 power
John Holt Chassis
Re: 440 build Any sugestions? [Re: poppaj] #1105956
11/03/11 07:51 PM
11/03/11 07:51 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Going a step past just throwing yet another opinion out there............
Wouldn't the determining factors of using the LY's be the mass of the piston, rpm's applied and the dutycycle/history of the rods themselves???
A .590 cam and Victor heads do seem to be a bit much with forged KB pistons. Lotsa bobweight slingin' around.
I would think either less cam, read rpm's, or better rods & pistons would be the way to go. Or leave it dialed on "Kahboom".
I'm frugal, but not that cheap.
Re: 440 build Any sugestions? [Re: Dean_Kuzluzski] #1105957
11/03/11 08:08 PM
11/03/11 08:08 PM
dogdays Offline
dogdays  Offline
Dean's right.
Find a way to get piston weight down to smallblock chevy country and those smallblock chevy-sized rod bolts will be able to handle it.
350 chevies and 318s have the same diameter rod bolts as any B/RB non-hemi connecting rod. The rod bolts are the most highly stressed part of the connecting rod.
So no more than a 550 gram piston with 150 gram pin and hold rpm to 6000, where the heads will not even be starting to work. That's no way to go fast.
You do know that the LY rods were the "standard" rod first developed for 413s, right? There is nothing special about them. The 3/8" rod bolts are the weak link, however after several million cycles the rod top end can rip off at high rpm as well. It's kind of a race to see which side fails first.
The 908 heavy rods added mass to the shank which helps eliminate the top ripping off scenario, but which puts more stress on the wimpy 3/8" rod bolts. So now piston weight is even more important. NEITHER is a decent high performance rod. 7/16" rod bolts are a must in a big block that is going to make power.
R.
Re: 440 build Any sugestions? [Re: Dean_Kuzluzski] #1105958
11/03/11 08:15 PM
11/03/11 08:15 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
lots of choice
rods - well i'm split.a lighter piston will help,so will less rpm
those heads/cam will more likely want more rpm so
but then the vert is really too small as well
i have rebuilt rods,arp bolts etc, in my 440 but i shift at 6000 trap 63/6400rpm.i have a SRP piston .i won't aim for over 6500 even when i recam it.
heck as others have said put my motor in a Abody run 10's.
put a smaller cam in it but who am i to say i use a purple 509 cam
Tex
Re: 440 build Any sugestions? [Re: dogdays] #1105959
11/03/11 10:27 PM
11/03/11 10:27 PM
hibbing mn
440 valiant Offline
440 valiant  Offline
hibbing mn
i was reading thru the balance card from the machine shop and
piston 694.3
pin 190
total rod 831.6
rotary 1323.8
reciprocating .50%
bob weight is 2497.4
like any build this one has snowballed from a mild 906 head build into something much bigger. im not against changing the rods at this point im way over budget any ways. anyone have a sugestion on a decent rod that wont break the bank
Re: 440 build Any sugestions? [Re: 440 valiant] #1105960
11/04/11 09:55 AM
11/04/11 09:55 AM
bigfork mn
bigfork mn
OVER BUDGET
Re: 440 build Any sugestions? [Re: 440 valiant] #1105961
11/04/11 09:59 AM
11/04/11 09:59 AM
an8sec70cuda Offline
I'd use K1.
CHIP
'69 road runner, 440-6, 4 speed, Dana 60
'71 Demon 340, no drivetrain, on blocks behind the barn
'06 GMC 2500HD LBZ Duramax
Page 2 of 3 1 2 3
