Dyno # #1103636
10/29/11 10:13 AM
10/29/11 10:13 AM
Winnipeg,Manitoba
cudablues Offline OP
Winnipeg,Manitoba
440 dynod @584 HP @5400 and 640 lb torque @3900 on 108 octane.It has 10.5 compresson,so will be running pump gas.How much of a difference do you guys think running the lower octane will have on the numbers?
Re: Dyno # [Re: cudablues] #1103637
10/29/11 10:23 AM
10/29/11 10:23 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
With that much horsepower from a 10.5-1 440 you probably have aluminum heads and a nice cam. If so, then it clearly does not need 108 octane and it "MAY" actually pick up a few HP with pump gas.
Re: Dyno # [Re: GomangoCuda] #1103638
10/29/11 12:29 PM
10/29/11 12:29 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: Dyno # [Re: Dodgem] #1103639
10/29/11 01:08 PM
10/29/11 01:08 PM
Winnipeg,Manitoba
Winnipeg,Manitoba
Ported Edelbrok performers and the cam is a Bullit custom .540 lift[need some vacumm],258/258 duration@.050.Its actually a 496 stroker.
Re: Dyno # [Re: cudablues] #1103640
10/29/11 01:12 PM
10/29/11 01:12 PM
Kirkland, Washington
Pacnorthcuda Offline
Yep, assuming you don't have to back off the timing from its dyno setting you may pick up a bit...
Nice numbers!!!!!
Re: Dyno # [Re: cudablues] #1103641
10/29/11 02:56 PM
10/29/11 02:56 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Ported Edelbrok performers and the cam is a Bullit custom .540 lift[need some vacumm],258/258 [Email]duration@.050.Its[/Email] actually a 496 stroker.
Sure changes things when the engine grows 56 cubic inches between posts...
Re: Dyno # [Re: RemCharger] #1103642
10/29/11 03:26 PM
10/29/11 03:26 PM
GomangoCuda Offline
GomangoCuda  Offline
Yep, now i'm thinking he might have some more horsepower hiding in there somewhere. Why is the hp peak at only 5400 rpm?
Re: Dyno # [Re: GomangoCuda] #1103643
10/29/11 03:34 PM
10/29/11 03:34 PM
Winnipeg,Manitoba
Winnipeg,Manitoba
Yep.just looking at the dyno sheets again.584 at 5400.576 by 5600.566 at 5700.
