Page 4 of 5 1 2 3 4 5
Re: Street/Strip Car Street Usage [Re: rickraw] #1102630
10/29/11 12:32 AM
10/29/11 12:32 AM
Glendale Az
Darryls-Demon Offline
Glendale Az
This I my winter work car. IMM built 408 SB with ported W2 heads 9.8 to 1 small solid roller cam, .240@.050 .630 lift victor intake 950 ultra HP.
904 trans 9.5 converter. Alum drive shaft, Moser 8 3/4 housing with alum center section with 3.73 gears {3.23s} for road trips. 275/60/15 Drag Radials.
Full interior {need to install radio} heater, wipers.
Manual brakes, manual steering (quick ratio box) I would not recommed it.
I did the car over the summer and Iam working the bugs out trying to get it ready for its first trip (las Vegas) next month.
After Vegas the plan is to get it to the track to see what it will run.
Re: Street/Strip Car Street Usage [Re: Darryls-Demon] #1102631
10/29/11 01:19 AM
10/29/11 01:19 AM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
As stated above, there are some very nice and very quick cars on the board.
I built my wife's Barracuda as a street/strip car. It's not something I would want to hop in and drive 7 hours to the Mopar Nats, but I'm sure it would make it if I had the funds for fuel. It does see a lot of street duty around the general St. Louis area though.
Full steel '70 Barracuda with Gran Coupe interior, cast crank 440 with 10.4:1cr, 906 heads that flow .265 @ .600 lift, .588 Ultradyne solid cam, M1 intake, 850 AED Holley, 9.5" PTC converter, 727 w/ FWD pattern manual valve body and low band apply, 4.10 Powr Lok B-body Dana, heavy Magnum 500 wheels, 215/70s in front and 295/65 drag radials in back. Hooker Comp headers and a full TTI X-pipe exhaust. I added monoleafs, Caltracs, and adjustable Ranchos last year, but admit I have never gotten around to really messing with them since Gateway closed not too long afterwards. (I gave them some pre-load and ran it.)
Not sure what the car weighs...been meaning to take it to the scales to find out.
The car runs 11.50's @ 118 in full street trim including the baby seat in the back. Getting back to the suspension, it's obvious it is not optimized yet, for it only pulls a 1.68-1.78 60ft. There are a few other factors involved too...larger .960 torsion bars and regular gas shocks on the front of the car are not playing nice with the rest of the combo.
I've never heard the car open exhaust and have never run it without the air cleaner. I like the fact that the car is raced in the same exact configuration as you see it on the street.
Honestly, I don't want it to go any faster, for the car will never see a rollbar. ( I take that back...I want to see an 11.4x out it...I know it has it once the 60fts are where they should be.)
Re: Street/Strip Car Street Usage [Re: Blues_Cuda] #1102632
10/29/11 03:24 AM
10/29/11 03:24 AM
Cleveland Ohio
10secGTX Offline
10secGTX  Offline
Cleveland Ohio
I'm trying to keep my car a street car but every time I go to the track...the tech guy disagrees with me..LOL
I have owned this car since Feb 1986 I was 17 when I bought it and what a ROLLER COASTER RIDE it has been.
I have 440 .040 over eagle rods JE pistons and a Low lash roller cam 585 lift 11.6 comp eddy heads tti headers victor intake 1000 hp re worked by (Cubic) a 904 w/ a 8" ati a dana 60 w/3.90 gears.
My best pass was 10.67 @ 125 w/o cage and it had a race exhaust & 4.10 spool 8 3/4.
2yrs ago I put the full exhaust on a 3.73 sure grip and went 10.67 @ 123 1.45 60'
Now I have a cage and a DANA and it slowed to 10.82 @ 122 ...But I drive it when its nice out, my goal now is drive it to the track reset tire pressure run a 10...what ever and drive home
Re: Street/Strip Car Street Usage [Re: StealthWedge67] #1102633
10/29/11 09:18 AM
10/29/11 09:18 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
That is freaking AWSOME!!!!
How the H--L did you get such outstanding power at such a low RPM???
Please share
Russ's last name is Dudek....... So it's in his blood. I think god blessed those Dudek boys with a 2-second advantage at birth. Seems everything they touch is at least 2 ticks faster than it should be by everyone elses standards.
I was actually born and raised in the Detroit area, but no relation to Dave. It is simply amazing how often when talking to vendors or professional equipment/service providers in the sport they would say to me…”hey, you related to Dave?” I’m sure Dave gets that all the time too.
It's 500ci with E heads according to the signature, but more info on the combo would sure be appreciated
There is nothing special about this motor or car. I spend a lot of time on the details of the build, tuning and track time.
Short block: 4.25" arm, 7.10 rod, 4.360" dia/1.49 CH Diamond piston. Zeroish deck, 10.7-10.8 CR. Well massaged high pressure standard rotor oil pump, 1/2" PU, scraper, std stroke windage tray, and Hemi oil pan. Stud kit and .25" girdle. Full time unrestricted rocker oiling and selected main oil passages enlarged. Relieved the block for valve clearance.
Heads: Mopar (Eddy) MCH CNC std. port and valves. Isky 9315 springs. 90cc chambers.
Valve train: Comp custom solid roller (Dwyane Porter) w/ "lollypop" lobes, bushed ProMagnums, Isky rollers.
General Stuff: 440-2D intake, aftermarket 950 HP Holley, exhaust port window opened up on manifolds, 2.5 TTI w/ UltraFlos. 1800 rpm converter, CRT full auto street tranny with steel drum. Battery in trunk. Wilwood front disc brakes. Mopar distributor w/ MSD 6A.
And, you don't need a roller cam to get this power level. This cam is very mild. Wayne has gone faster, and Tony quicker with similar manifold builds using solid flat tappet cams.
The car's best 60 ft is 1.87 sec. Obviously no secret supension stuff going on here.
http://508charger.yolasite.com/
Re: Street/Strip Car Street Usage [Re: BSB67] #1102634
10/29/11 10:41 AM
10/29/11 10:41 AM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
The MCH ported heads and Porter camshaft are the pieces that stand out slightly (JMO) but your tuning skills have got alot to do with it as well.
Great job with it
Dwayne also hooked me up with a nice grind using the .420 endurance lobe design. Runs great.
Rich H.
Esse Quam Videri
Re: Street/Strip Car Street Usage [Re: BSB67] #1102635
10/29/11 10:52 AM
10/29/11 10:52 AM
ny
greenmcode Offline
greenmcode  Offline
ny
I drive my Road Runner a few hundred miles a season
plus 60 or so runs at the track..
The car is show room correct not on a diet in anyway 3920
with me in the car and a mild 440 6bbl..
Best et to date 11.74@117.05 1.74 60' on bias ply tire..
1969 A12 R.R. 11.61 117.96 F.A.S.T. STOCK STROKE..
Re: Street/Strip Car Street Usage [Re: ZIPPY] #1102636
10/29/11 11:23 AM
10/29/11 11:23 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Thanks.
Yeah, the -5s are easy on parts.
Re: Street/Strip Car Street Usage [Re: BSB67] #1102637
10/29/11 11:38 AM
10/29/11 11:38 AM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
Bsb67 and FatA12 Very impressive and very streetable
Re: Street/Strip Car Street Usage [Re: greenmcode] #1102638
10/29/11 11:38 AM
10/29/11 11:38 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Nice. I'm thinking about going to G/70/14 bias ply red lines and maybe a converter change to 2200 to 2400. I think that I might be able to get to 1.80 maybe high 1.70s.
What stall do you have?
Re: Street/Strip Car Street Usage [Re: scatpacktom] #1102639
10/29/11 11:41 AM
10/29/11 11:41 AM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Thanks Tom.
Re: Street/Strip Car Street Usage [Re: BSB67] #1102640
10/29/11 12:42 PM
10/29/11 12:42 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
"BSB67" I have always been impressed with your combo. Definetly a cool sleeper. I also have my heads worked and my cam speced by Dwayne Porter. Everytime I see a car that Dwayne has done work to the car always run real good. That one of the reasons I used Dwaynes head and cam service and they work great. Is the 440-2 a dual plane intake as I seem to have forgot without looking it up ?
"Greenmcode" I really like your Roadrunner alot. Thats one of if not my favorite color combo on a 69 Runner. If I ever have enough money to buy more Mopars a 69-1/2 six pack Runner would be top on my list as I really like the 69-1/2 six pack runners and yours looks great ! Ron
Re: Street/Strip Car Street Usage [Re: 383man] #1102641
10/29/11 01:31 PM
10/29/11 01:31 PM
Birmingham, England
Mick70RR Offline
Mick70RR  Offline
Birmingham, England
I drive my car to work every day for 8 months of the year. I run it at the drag strip exactly as I drive it there, no slicks or drag radials. Runs consistent low 12's with a best of 11.98 @ 117.
1970 Road Runner 505 cid MCH CNC ported Stealth heads MP 528 camshaft 4 speed GV overdrive 11.98 @ 117 on street treads
Re: Street/Strip Car Street Usage [Re: BSB67] #1102642
10/29/11 03:41 PM
10/29/11 03:41 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Our times are close, it would be a cool race. Last time out I ran 1.84 11.61 @ 121.8.
Why do you run the stock convertor?
Re: Street/Strip Car Street Usage [Re: 383man] #1102643
10/29/11 03:51 PM
10/29/11 03:51 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Ron - Thanks
It is the Indy dual plane. I see that you are using a spacer with yours. If it is not an "open" spacer, I suggest that you try it.
Re: Street/Strip Car Street Usage [Re: RemCharger] #1102644
10/29/11 04:04 PM
10/29/11 04:04 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
You've got serious steam on the big end.
I did not want to buy a converter for the motor until I ran it first to better determine what to buy, and this is what I had. I thought that with the bigger motor it would stall higher than the 440 it was behind before. I was mistaken
Re: Street/Strip Car Street Usage [Re: BSB67] #1102645
10/29/11 04:24 PM
10/29/11 04:24 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Yea, I would think with a 4500 8" ati or similar, you'd be around 11.20s? Then you might be looking into some "secret suspension" stuff.
Mines done caveman style,,, Big heads, cam, high rpm. Not much of street motor, But if I could afford the 13 bucks a gallon all day, I'd get some ice cream with it for sure.
Re: Street/Strip Car Street Usage [Re: RemCharger] #1102646
10/29/11 06:37 PM
10/29/11 06:37 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
My Dart "street car" has been 11.20s @ 119mph exactly how i drive it on the street. Air cleaner and all...
9.8:1 416 with W2's
Edelbrock victor intake
.570" flat tappet solid cam
727 with 4200 converter
4.10 gears
255/60/15 MT drag radials
Car weighs 3350 w/ me in it.
Re: Street/Strip Car Street Usage [Re: 340_Dart] #1102647
10/29/11 07:17 PM
10/29/11 07:17 PM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
9.8:1 416 with W2's
4.10 gears
And thats exactly where your Dart should be- on the street! a car as nice as yours needs to be out there to be seen and enjoyed by all!
Re: Street/Strip Car Street Usage [Re: 72demon416] #1102648
10/30/11 01:33 AM
10/30/11 01:33 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Allmost forgot about my boys Dart. It is a street car and he can drive it anywhere.
Pump gas 400 in his 72 Dart.
Stock stroke 400 that has .030 over KB pistons (406 cubes)
Crank and rods are stock
MP .557 cam
Eddy RPM heads
Eddy Performer RPM intake with a 750 DP
Stock electronic dist I worked and MSD box
CPPA 2" headers and 3" exh
727 with manual v/b and Dynamic 9.5 converter
3.91 gears and he uses 26 x 9.5 Hoosier QTP tires
Weighs 3550 with him in the car
Full interior all stock body
Stock suspension with SS springs and 90/10 shocks up front.
Driven to the track the same as me.
Best et 11.45 @ 117 , Ron
Re: Street/Strip Car Street Usage [Re: 383man] #1102649
10/30/11 02:38 AM
10/30/11 02:38 AM
Bama
Randy.. Offline
Randy..  Offline
Bama
well after my last toy 95 Dakota 5.9 5spd 3.91s big cam headers big injectors bla bla bla, it ran 8.12 in the 1/8 granny shifting the stock NV at 5100, cam was good to 6200, had a blast driving it and won't own another hot rod with a loose TQ and deep gears, my Valiant will have 3.54s a tight 9.5 converter and 9.0 440 with a pair of 76mm turbos, set at 10/12 lb [image]http://[/image] s of boost, and gonna drive the crap out of it.
