super trap mufflers?
#1102487
10/27/11 10:44 AM
10/27/11 10:44 AM
Posts: 15,487 Florida
scratchnfotraction
got to see a nice yellow/black Gremlin today. nice 304 SB with 3 on the floor. had manifolds with 2" head pipes and turned out in front of rear wheels. i thought it had chrome echo tips but looking a little closer it had the supertrap mufflers,with the stacked plates/defusers(I think thats what its called?) that thing sounded real good when he got on it leaveing anybody else run a set of them?, kinda thought I might give them a try on my 440 truck till the headers go on it,it has the mannys with 2" pipes but will need more pipe. I was going to run the headers with glass packes bolted to them and some pipes for turn outs in front of the rear wheels,but could just run headers with pipe and the supertraps sticking out a little in front of the tires. what are some pros and cons on them? the gremlin guys said they are tunable and he runs this many on the street and that many or open on the strip. are the worth the effort to run them on a street truck? thanks for opinions
Re: super trap mufflers?
[Re: scratchnfotraction]
#1102489
10/27/11 12:30 PM
10/27/11 12:30 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
We have used them on dirt bikes for years (they are considered old tech now) but I never even knew they made them for cars. I wouldn't bother with them for the reasons Stu mentioned.
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: DPelletier]
#1102490
10/27/11 04:14 PM
10/27/11 04:14 PM
scratchnfotraction
once I got the sound I like,I would not be adjusting them. just something differant for street duty and i think they would work with the look of my 88 440 truck. 45* angle in front of rear wheels headers and straight pipes with a set of super traps defferant indeed
[Re: BlwnCrcab]
#1102493
10/30/11 02:15 AM
10/30/11 02:15 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
Hey Scratchy,, I had them on my 71 RR. Loved them. Had 12 discs on each side. Great sounding. You can repack them when they burn out. If I was you Id notch the roll pan and run them out the back.With your lowered truck theres not a lot of clearance for the exhaust pipe to go under the frame and not drag on speedy bumps..
I am truckless..
[Re: 340SHORTY]
#1102494
10/30/11 08:43 AM
10/30/11 08:43 AM
scratchnfotraction
yea shorty i have thought about out the back. but with the mono leafs/lift bars it sit real low. the frame is about 3-4 inches off the axle tube and that spreds the shocks out wide.
that takes up the room where a pipe would go to around the outside of the shock. over the middle is a very tight clearance for 2 pipes also
I just had to grind clearance on the frame cross rail for the air shocks last weekend,the stock angle cut for the shock needed clearanced for the bigger shock body.
right now its sitting jacked up in the rear at max lift the shocks give. now if I drive up on some ramps in front,i should be able to get my fat azz under the truck and have room to swap the tranz out asap
sux to have to add airshocks to get under the truck..no?
I want to run the headers from kenworthgoose when the pipes get built,I also want them short and be able to unbolt them from the headers and hangers to be remove out from under the truck for work clearance.
so I was thinking the headers straight pipes with a 90* turn and hang them in front of the rear tire. header-pipe-supertrap x 2
after seeing the price 400-500 bones for a pair,may just go with some hookers or glass packs
but then again,i didnt think I would have 500 bones in just the fuel plumbing either
they have some nice short black ones that 18"L 3"ID 4" case tapperd to 5" with 12 disc that I really like
so far they are what I like/want but may have to go with what the budget dictates
#1102495
10/30/11 10:05 AM
10/30/11 10:05 AM
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
the black ones are the ones that I had. If I remember right they were around 100.00 eack 30 years ago.. you could make a homemade set.. cut a glasspack in half, cap the end, drill and tap the 6 screw holes and put on the guard, discs and cap . about half the price of a factory set.
I am truckless..
[Re: 1969RR]
#1102498
10/31/11 04:21 PM
10/31/11 04:21 PM
scratchnfotraction
Hello! I used them on a ProStreet Camaro (I know, I've seen the light!) I built. I did modify the tail pan so they'd fit closer. They did have s nice sound. I had them on for about 10 years with no issues. Jeff
thats sharp! even for a chebby
