Page 3 of 4 1 2 3 4
Re: I will never install a rubber rear main seal again!! [Re: coro500net] #1102387
10/30/11 08:20 PM
10/30/11 08:20 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
How hard is it to install block side of rope seal with engine in car?
I am one rubber rear main seal #3 (tried all style rear caps)so I am ready to try a rope seal.This is on a 67 440 and it does have the knurl.
Troy just did it twice in the last few days. Once on his car and once on that Landy built Hemi Charger.
Re: I will never install a rubber rear main seal again!! [Re: coro500net] #1102388
10/30/11 09:48 PM
10/30/11 09:48 PM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
It's not hard!! Read the first post on this thread and it will walk you through it. If you have any question, just ask!!
Here is a picture of my car after a 25 mile drive. Looks good so far!!
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: I will never install a rubber rear main seal again!! [Re: Troy] #1102389
11/02/11 07:42 PM
11/02/11 07:42 PM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
New update.
I just got my order in from Summit Racing and the FelPro rope seals are here!! They were only $6.45 each BUT I don't like the side seals at all. The rope it's self looks good but they come with a rubber looking round side seals that are 1/2" to short. I have no idea what you should do with them.
PS....I put another 20 miles on my Dart and all is dry, thank God!!
Re: I will never install a rubber rear main seal again!! [Re: Troy] #1102390
11/30/11 10:53 AM
11/30/11 10:53 AM
Out in Left Field, NY
bobs66440 Offline
bobs66440  Offline
Today I installed another rope seal in a friends car. Tomorrow we will see if it is fixed. He is on his 4th try. On try second try this is the cap that he took out. Look how off everything is. The mounting holes are off, the crank and seal area are shifted off to one side. I can't believe this is sold to the general public!!
I just found this thread. Can someone tell me what vendor's retainer this is? I have a billet aftermarket retainer on the engine I am putting together and would like to avoid any problems if possible.
Could it have been made in response to this?
http://www.forbbodiesonly.com/moparforum/archive/index.php/t-23510.html
Thanks.
Re: I will never install a rubber rear main seal again!! [Re: bobs66440] #1102391
11/30/11 12:05 PM
11/30/11 12:05 PM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
I must be a lazy old shade tree mechanic. My 410 stroker leaked and after two seals. I wasn't going to pull the engine to fix it. TTI W2 headers and a Milodon pan make dropping the pan cruel and unusual punishment, at least for this 70 year old. As a last resort I put in a quart of Lucas stop leak. Guess what No leaks. I ran it at Topgun and everything checks OK without pulling ther pan. We will find out next Spring when I change oil.
Re: I will never install a rubber rear main seal again!! [Re: babarracuda] #1102392
12/01/11 02:18 AM
12/01/11 02:18 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Looking past the point that I hate eagle crankshafts, that knurling is designed for rope seals. When I would polish the crankshafts after cleaning them for the last time I would spend some time with a narrow sanding belt on the sealing surface of the crank. I was worried about my seal leaking on my 440 so I cut .010" off the seal retainer. Well, it leaked like no other on the dyno so I was forced to pull the pan and replace the seal retainer with one that hadn't been cut, but just cleaned up on a flat surface with some fine sandpaper. One new half piece of seal and the new retainer later, no leaks. Good thing too because I didn't put it back on the dyno and my next test session was in the truck. God was looking out for this idiot.
I'm not against rope seals. I feel you did what you had to as that knurling was in the earliest mopars out there and all they had for seals were rope seals.
Re: I will never install a rubber rear main seal again!! [Re: dodgeboy11] #1102393
12/01/11 01:43 PM
12/01/11 01:43 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
I don't know the specific purpose intended by that knurling, nor have I looked at a crank or rope seal that closely, but I just had an unrelated discussion with an oil expert about the fine details of different blends of ATF, so I'm inspired to throw in my .02:
Here's my assessment.
A lip seal will ride on a thin oil film on a journal. That film actually does the sealing during rotation while protecting the lip of the seal. If that boundary film can escape, though, oil will begin to seep out. So add some pumping grooves (the knurling) so that crankshaft rotation keeps the oil film in place (picture waves that keep a floating object near the shore).
I suspect a rope seal is more porous and allows the oil to penetrate it, which then swells it against its sealing surface, and it is kept cool at the rotating boundary by the absorbed oil (which is continuously refreshed to some extent by oil splash). I'm guessing that it has a different boundary layer, perhaps one that is a very tight matrix that prevents the oil molecules from escaping to an extent that would manifest into a user-noticeable amount (aka 'a leak').
Or maybe I'm completely FOS.
Re: I will never install a rubber rear main seal again!! [Re: bobs66440] #1102394
12/01/11 04:10 PM
12/01/11 04:10 PM
bobs66440 Offline
bobs66440  Offline
Thanks.
Anybody?
Re: I will never install a rubber rear main seal again!! [Re: bobs66440] #1102395
12/03/11 12:44 AM
12/03/11 12:44 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
i replied once before but I'm going to add a few more points. apply red silicone under the seals,in the groove,just enough so as not ooze out.put some between the block and retainer and a dab on the seal ends then tighten down,this is where it leaks.put a little on the end of the side strips and slide in. but remember this whole area has to be dry, no oil what so ever or the silicone wont stick.let silicone cure for a day. done many engines and no leaks. this operation is just as important as all the big stuff and you can't be in a hurry.same as the oil pan,no oil, torque to factory spec's, no more drip pans on the floor. almost forgot,apply a VERY thin film of Vaseline to the crank journal surface before installing the retainer
Re: I will never install a rubber rear main seal again!! [Re: cudaman1969] #1102396
12/03/11 03:43 PM
12/03/11 03:43 PM
People's Republic of Kali
70runner Offline
70runner  Offline
pretty much what I did on my recent 440 build. Used the 440source viton seals, slight offset, lubed contact area with clevite bearing guard. Stock steel crank out of 68 Imperial. No leaks.
Re: I will never install a rubber rear main seal again!! [Re: 70runner] #1102397
12/03/11 03:56 PM
12/03/11 03:56 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Put the motor together in my Superbird in 1992,my wagon 2yrs ago both rubber seals and neither one has ever leaked a drop.
Re: I will never install a rubber rear main seal again!! [Re: 62maxwgn] #1102398
12/08/11 12:59 AM
12/08/11 12:59 AM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
Hi Bill, hope all is well.
The more I read and the more I see how some people have problems and other people don't.....I'm starting to see a common problem. It seems like many of the people that do have problems have after market cranks. Maybe more and more people are just building stroker engines and fewer people are building stock engines. I don't know what the answer is.
Re: I will never install a rubber rear main seal again!! [Re: Troy] #1102399
09/09/12 11:25 PM
09/09/12 11:25 PM
KillerCuda Offline
KillerCuda  Offline
i would like to thank troy for this thread! i have the same combo, 472 hemi, early second gen mopar performance block, eagle crank with grooves. i have had that damn engine out three times for issues, and the rear main being a killer as of late......
after getting no help or support from my engine builder in florida, (i paid A LOT of money for this engine, kind of sad that he took this route with me) i ended up following troy's lead, and going with a rope. i have a little moisture back there, (only have thirty miles on the latest seal), but compared to the water works i had with the other two lip seals, i'll take it.....
i think you might be onto something, saying some people have issues, and others don't, and that maybe it does have something to do with aftermarket parts. both lip seals looked ok, cap measured out ok, (used two different ones) but they just didn't work, no matter how careful they were installed.....
anyway, thanks again troy!
Re: I will never install a rubber rear main seal again!! [Re: KillerCuda] #1102400
09/10/12 09:31 PM
09/10/12 09:31 PM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
Very glad it worked out for you.
I was just outside looking at my engine and all is still well.
Re: I will never install a rubber rear main seal again!! [Re: Troy] #1102401
09/21/12 04:07 PM
09/21/12 04:07 PM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
I just got three more seals off of Ebay!!
FelPro number is BS11748
Re: I will never install a rubber rear main seal again!! [Re: Troy] #1102402
09/23/12 12:35 AM
09/23/12 12:35 AM
Midwest
fuseable Online rolleyes
fuseable  Online Rolleyes
Midwest
What are the 2 small rubber peices that come with the Victor Reinz part number JV551 rope seal kit? They are to small to be side seals.
Re: I will never install a rubber rear main seal again!! [Re: fuseable] #1102403
09/23/12 09:22 PM
09/23/12 09:22 PM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
What are the 2 small rubber pieces that come with the Victor Reinz part number JV551 rope seal kit? They are to small to be side seals.
That is for both big and small block. Those two small rubber parts are for a small block....they fit into the cap and seal it to the block.
Re: I will never install a rubber rear main seal again!! [Re: Troy] #1102404
06/06/13 02:14 PM
06/06/13 02:14 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
Troy how is this seal holding up ? I was told by the shop I have been going to recently that these seals are made of something like fiberglass and don't work very well. They suggested that I get rope seals from Best Gasket, they are a graphite material but they are not cheap. I just ordered them from Egge Machine , can not buy directly from Best, 25.12 each ... OUCH
Re: I will never install a rubber rear main seal again!! [Re: JohnRR] #1102405
06/07/13 06:08 PM
06/07/13 06:08 PM
Iowa State fan
kilroy Offline
kilroy  Offline
Iowa State fan
Troy how is this seal holding up ? I was told my the shop I have been going to recently that these seal are made of something like fiberglass and don't work very well. They suggest that I get rope seals from Best Gasket, they are a graphite material but they are not cheap , I just ordered them from Egge Machine , can not buy directly from Best , 25.12 each ... OUCH .
Only ouch if it leaks, if it doesnt itll be the best 25 buck you ever spent.
1973 Charger, former SE, former auto
I'm not trying to be difficult, it comes naturally....
Re: I will never install a rubber rear main seal again!! [Re: JohnRR] #1102406
06/08/13 12:00 AM
06/08/13 12:00 AM
KillerCuda Offline
KillerCuda  Offline
i believe you are correct on the fiberglass make up. i installed one in an engine 11 years ago, and it's leaking, started about six months after installation. i installed this felpro in my same hemi combo as troy, but it leaked. i probably chalk that one up to installer error, even though i thought it looked good upon install and later, removal.
i also installed one of the graphite ropes in my gto, (had VERY troublesome problems getting any seal to work, so i went to the graphite rope), and it has been great. that being said, i firmly believe in the graphite rope. i could not drag the graphite rope seal into/around the hemi crank like the fiber ones, so beware if that is your plan, they don't really like being installed that way, crank out worked best for me, as per the instructions as well.....
Page 3 of 4 1 2 3 4
