Std. Volume Oil Pump or High Volume? #1102314
10/27/11 02:02 AM
10/27/11 02:02 AM
New York, USA
Chargerfan68 Offline OP
New York, USA
I am building a 383 stock stroke engine to be used with Edelbrock Rpm heads and 10.2:1 with the MP 509 stick.
I just checked the Main clearances and they are between .0027-.0029". I haven't done the rods yet.
If the rods are similar clearances, should I run the High Volume Pump or the standard volume?? My machinist said if the clearances come out to .0015 - .0025", then I should use the std volume. If they come out to .003 - .0035", use a high volume pump. This is in the middle of those ranges.
What do you all suggest. If I go with the high volume, I would go with the 6 qt. pan and pickup...if it is the std. pump, then standard 5 quart pan.
Thanks for any input,
Greg
Re: Std. Volume Oil Pump or High Volume? [Re: Chargerfan68] #1102315
10/27/11 03:02 AM
10/27/11 03:02 AM
Use both the bigger oil pan, correct pickup and high volume pump, cut the bypass spring to set the oil pressure to 10 lbs per thousand RPM, IE 6500 RPM = 65 lbs hot I would and do use a cranksahft scraper, you can make your own I shoot for .030 to .060 clearances between the scraper and any rotating part, closer is better than looser
Re: Std. Volume Oil Pump or High Volume? [Re: Cab_Burge] #1102316
10/28/11 01:46 PM
10/28/11 01:46 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
I use the high pressure pump on all my motors not the high volume pump
qqRe: Std. Volume Oil Puimp or High Volume? [Re: Chargerfan68] #1102317
10/28/11 01:57 PM
10/28/11 01:57 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
How do you intend to use this car?
What weight oil will you be running?
Wait and see where those rod journals end up.
So far i see no reason to run either hi volume or high pressure, until we get a few more answers.
I WOULD run the 6 qt Hemi pan regardless
RIP Monte Smith
Re: qqRe: Std. Volume Oil Puimp or High Volume? [Re: CompWedgeEngines] #1102318
10/28/11 03:24 PM
10/28/11 03:24 PM
NC
440Jim Offline
440Jim  Offline
NC
And I couldn't have said it better.
Things for a high volume pump:
- larger bearing clearances
- full groove main bearings
- street driving (hotter oil, >180F)
- low idle speeds (800 rpm)
Things for a std volume pump:
- smaller bearing clearances
- drag race only (oil never gets hot, <180F)
- high idle speed (1200 rpm)
I have run both in my drag only engine. I used a relief spring to give me 70 psi going down the track. IMO, 50-70 is fine (>2000 rpm) and I like idle no lower than 20 psi, but that is just my preference.
Re: qqRe: Std. Volume Oil Puimp or High Volume? [Re: 440Jim] #1102319
10/28/11 03:37 PM
10/28/11 03:37 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Jim's the man.
I researched the tech info, and with Jim's high level of R&D, I went with a std vol. pump and put the spring out of my old pump(hp) in my 383. Even with the non restricted 440-1s the pressure stays at 55-60 , and drops to 45ish hot,hot idled down (900?). This was with generic 15/40 diesel oil.
I also run a BIG pan and crank scraper, stock pickup, 7000+ rpm.
Re: qqRe: Std. Volume Oil Puimp or High Volume? [Re: RemCharger] #1102320
10/28/11 08:01 PM
10/28/11 08:01 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
for up to around 7000 I generally prefer to run a ported stock pump opening up the suction and discharge lines to 1/2" or 17/32", a nice chamfer on the right angle turn in the inlet passage of the pump head increases the available flow significantly and reduces the pressure drop across the sharp turn, these mods result in a less obstructed, smoother oil delivery to the discharge side....even with the stock size rotor.
I've been doing this mod on BB/Hemis for nearly 30 yrs.
I never understood the point in running a 1/2" sump pick up and leaving the standard 3/8"-ish pump inlet passages (and it's the same casting/piece for both a std and HV pump) alone.
WIZE
In Car:
Re: qqRe: Std. Volume Oil Puimp or High Volume? [Re: Streetwize] #1102321
10/28/11 08:45 PM
10/28/11 08:45 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
So running a dual line external pickup must really have you scratching your head !!!!!
Re: qqRe: Std. Volume Oil Puimp or High Volume? [Re: Stanton] #1102322
10/28/11 11:28 PM
10/28/11 11:28 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Uhhh.... An external feed Bb pump allows you a straight shot feed to the pump and eliminates the 90 degree dog leg (in the pump head casting), that's one of the benefits of running one
WIZE
In Car:
Re: qqRe: Std. Volume Oil Puimp or High Volume? [Re: Streetwize] #1102323
10/28/11 11:36 PM
10/28/11 11:36 PM
Uhhh.... An external feed Bb pump allows you a straight shot feed to the pump and eliminates the 90 degree dog leg, that's one of the benefits of running one
Most of the Milidon external dual line systems I have seen have 90 degree elbows coming out of the swinging picksup I like to use straight AN bulkhead fittings in the pan and 90 degree female elbow fittings on the hoses
Re: qqRe: Std. Volume Oil Puimp or High Volume? [Re: Cab_Burge] #1102324
10/29/11 01:01 AM
10/29/11 01:01 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Cab that's true, no way around that but it's still less total bends than the near 90 straight up to the pick up boss in the block and then the 90 from the block through the pump head.
My point was any time you can reduce the inlet restriction providing supply/flow to the pump it allows the pump to work a bit more efficiently, especially at higher flow rates/rpm.
The factory 90 in the pump inlet is pretty severe, that's all I was pointing out.
WIZE
In Car:
Re: qqRe: Std. Volume Oil Puimp or High Volume? [Re: Streetwize] #1102325
10/29/11 03:09 AM
10/29/11 03:09 AM
I wanted to point out to those that don't know the Milidon external oiling systems that they are far from perfect also I'm thinking a external pump with a dry sump is the way to go, if you can Not for those that are faint of money
Re: qqRe: Std. Volume Oil Puimp or High Volume? [Re: Cab_Burge] #1102326
10/29/11 03:20 AM
10/29/11 03:20 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
remember he's asking about a stock 383 with edelbrocks........
Re: qqRe: Std. Volume Oil Puimp or High Volume? [Re: RemCharger] #1102327
10/29/11 01:21 PM
10/29/11 01:21 PM
Connecticut
5126brl No more Offline
Connecticut
Just drove the car to the shop to put away before snow.
80 psi oil at 170 degrees 2500 rpm, 15-40 oil and hv pump. I think I may add a milodon adjustable spring kit this winter,
Re: qqRe: Std. Volume Oil Puimp or High Volume? [Re: 5126brl No more] #1102328
10/29/11 03:08 PM
10/29/11 03:08 PM
New York, USA
New York, USA
Thanks for all the replies, guys. This is a street only motor, but the guy that owns it is a maniac on the street. It will definitely see about 6500 rpms and will be driven hard its entire life. It is a stick.
This guy owns a gas station and did 360's around his gas pumps.
The rod clearances just came out to .00265". I do intent to install the 6 quart pan on it for him. I just need to figure out the pump design and oil weight.
Thanks again.
Re: qqRe: Std. Volume Oil Puimp or High Volume? [Re: Chargerfan68] #1102329
10/29/11 03:39 PM
10/29/11 03:39 PM
The rod clearances just came out to .0265". I do intent to install the 6 quart pan on it for him. I just need to figure out the pump design and oil weight.
Thanks again.
High volume, cut the bypass spring (1 to 1 1/2 coil)to get 70 lbs hot above 5000 RPM with 15W40 WT
Re: qqRe: Std. Volume Oil Puimp or High Volume? [Re: Chargerfan68] #1102330
10/29/11 04:29 PM
10/29/11 04:29 PM
Delray beach, Florida
P
Performance Only Offline
P
Thanks again.
it's going to take a lot of pump to keep those rods from knocking with the clearance you listed.
you guys worry way too much about which pump to use. are you afraid you might have a little more pressure with the HV pump and lose a horsepower or two? is the standard pump really the right pump if you haven't done the standard oiling modifications to the block?
machine shop owner and engine builder
Re: qqRe: Std. Volume Oil Puimp or High Volume? [Re: Performance Only] #1102331
10/29/11 06:28 PM
10/29/11 06:28 PM
New York, USA
New York, USA
I get the general consensus that the high vol. pump is the way to go with this setup. Thanks for the info.
Re: qqRe: Std. Volume Oil Puimp or High Volume? [Re: Chargerfan68] #1102332
10/30/11 02:54 AM
10/30/11 02:54 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Dan was laughing at your last post, 26 thou rod clearance ....
Re: qqRe: Std. Volume Oil Puimp or High Volume? [Re: RemCharger] #1102333
10/30/11 08:21 AM
10/30/11 08:21 AM
P
P
sort of. but i was also wondering where the extra 5 at the end came from if he just missed adding the 0 in the beginning. that would make it .00265". how many bore guages read to the millionth? it's a wierd typo.
