what do you think i might gain ? #1101529
10/25/11 06:16 PM
10/25/11 06:16 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
just put a customer/friends 68 roadrunner back together after it sheared the crank woodruff key and bent a bunch of valves
440 stroker,511 ci,10.3:1,eddy heads pocket ported by Dwayne Porter,TTI 2" headers 3" pipes,6 pack induction with jettable outer carbs
had a custom comp ft solid 247/251@050 , 549/556 gross lift with 1.5 rockers,114 lobe separation
running lean,nearly 14:1,it made only 406RWHP - auto 4200 stall
i recommended a cam swap while apart,Lunati Voodoo 251/259@050 , 566/586 gross.014 lash,110 lobe separation
plus jetted up the outer carbs.
what do you see for gains,i will have it on the chassis dyno this Friday afternoon.
Greg the owner is not into an all out power,is street driven
it has gone 11.44,did this at 114 plus change, best with mph in the 115-116
i have also thought of this cam for my engine but will probly go a little larger though it is good to try it out to see how it performs
certainly sounds the goods
thoughts
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: what do you think i might gain ? [Re: tex013] #1101530
10/25/11 06:22 PM
10/25/11 06:22 PM
ill
dennismopar73 Offline
ill
IN THE 10 s somewhere,,
weight of the car? 3700 #?
guess , 10.40 124-5 mph?
Re: what do you think i might gain ? [Re: dennismopar73] #1101531
10/25/11 06:51 PM
10/25/11 06:51 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
11.20 at 118mph.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: what do you think i might gain ? [Re: deaks] #1101532
10/25/11 07:40 PM
10/25/11 07:40 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Dennis - wow you are optimistic,i wish
Deaks - this was about what i thought,low 20's and hopefully in the teens.
may need some suspension work from this point
car weighs about 3855lbs with Greg in it
Tex
New best MPH 130.32
Re: what do you think i might gain ? [Re: tex013] #1101533
10/25/11 07:40 PM
10/25/11 07:40 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
thoughts
Tex
If your talking the same cubes & just a cam change after fixing the engine or is this a new build?? Just a cam change & the fix from those 11.4s (running decent before) I'd have to say 11.0/11.teens @ 119-121.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: what do you think i might gain ? [Re: joedust451] #1101534
10/25/11 07:59 PM
10/25/11 07:59 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Joedust,
yes just the cam,jetting and service the heads
Tex
New best MPH 130.32
Re: what do you think i might gain ? [Re: tex013] #1101535
10/25/11 08:17 PM
10/25/11 08:17 PM
Is the chassis dyno O2 equipped? If so shoot for high 12.8 to low 13.3 AFR, I have a similar combination in a 3450 lb Duster that use to have the same heads and a similar duration solid roller cam and valve train, it ran mid to high tens10.69 at 124 MPH with 906 heads and mid tens (10.53) to 10.34 at 128.+ MOH with the Eddy heads. make sure you have enough fuel delivery Six paks use a lot of fuel
Re: what do you think i might gain ? [Re: Cab_Burge] #1101536
10/25/11 09:49 PM
10/25/11 09:49 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
thanks Cab,
that and supension are my only worries
though i thought with 3 needle/seats and 3 fuel bowls there might be a little lee way
they will all get woked through
Tex
New best MPH 130.32
Re: what do you think i might gain ? [Re: tex013] #1101537
10/25/11 09:57 PM
10/25/11 09:57 PM
Mo.
racerx Offline
racerx  Offline
Mo.
At 3800 lbs i'll say 11.00-10.90's
Re: what do you think i might gain ? [Re: tex013] #1101538
10/25/11 10:11 PM
10/25/11 10:11 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
11.20's-11.30's.....That car was already running good for what it was.
Re: what do you think i might gain ? [Re: Quicksilver440] #1101539
10/25/11 11:02 PM
10/25/11 11:02 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
My guess would be 11.20's with just the cam change and jetting. Just curious as I dont know if I just missed it but what gear and converter are in that Roadrunner ? Ron
Tex thats not your Runner in that pic is it ?? I mean yours is green right or am I crazy ? Ron
Re: what do you think i might gain ? [Re: 383man] #1101540
10/25/11 11:58 PM
10/25/11 11:58 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Id say about two tenths gain as well with the cam and jetting changes.
The duration change isnt that big, but combined with the LSA angle change it should help a bunch with that 10.+ comp. Jetting those carbs to richen it up should help too. Id say , two tenths minumum, 4 tenths max. Cam, two tenths, the rest will depend how truley your jetting was really off. JMO
Re: what do you think i might gain ? [Re: 383man] #1101541
10/26/11 12:03 AM
10/26/11 12:03 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
hey Ron,
this is a factory A12 car - dana with 4.1 and a 4200 stall -WAY TOO SMALL
275/60R15 MT
no it's not my satellite,your not crazy just fast
i would like it to go as fast as mine
Tex
New best MPH 130.32
Re: what do you think i might gain ? [Re: tex013] #1101542
10/26/11 12:19 AM
10/26/11 12:19 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
hey Ron,
275/60R15 MT
Tex
That is one very sweet Roadrunner. But its not the car you are talking about is it ?? Cause I think you said a 68 Runner and thats a 69 I believe ? Ron
Re: what do you think i might gain ? [Re: 383man] #1101543
10/26/11 12:23 AM
10/26/11 12:23 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
DUH- yes i am talking the blue 69 Runner
Tex
New best MPH 130.32
Re: what do you think i might gain ? [Re: tex013] #1101544
10/26/11 01:01 AM
10/26/11 01:01 AM
ill
ill
well i might be optimistic, maybe not, ?
511 ci motor is not small motor, and the cam not small either , along with heads,
we run 11.0s in a car with allot smaller motor and smaller cam , pretty close on convert, in 67 coronet, 3800# w/410 gear after we get it dialed in it should be 10.70-10.80 car?
Re: what do you think i might gain ? [Re: dennismopar73] #1101545
10/26/11 01:11 AM
10/26/11 01:11 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
hey Dennis,
not complaining.
the only other 511 i have helped with,same comp was in an E body.had more cam 260/260(?) with about 600 lift,1000 BG carb,bit more stall,295/65R15 MT's,full Caltrac setup,maybe 100lbs lighter.it went 10.66@124 with electric exhaust cutouts open shifting at 5800.
won't know till dyno then the strip.got to be ready for Mopar Rumble plus Nostalgia Drags in November
i am prepared to be suprised
thanks for all the replies
Tex
New best MPH 130.32
Re: what do you think i might gain ? [Re: tex013] #1101546
10/26/11 08:30 AM
10/26/11 08:30 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Wow I would have thought that combo would have run 11.20's out of the box. I'm at 11.38 @ 118.2 w/ less motor and less work. I'll be shooting for 11.20's this weekend after getting my axles in. What jetting are you running? I have 70's and 35 squirters (stock six pack) using purple springs I get zero bog and this thing jumps right up to 6k. They only thing different is I'm running a small solid roller cam (580/588), but I'm also running tiny 1 3/4 headers, 3800 stall and 3.91's. I would have thought those extra cubes would get it done w/o much more cam?????
Coming soon!!!!
Re: what do you think i might gain ? [Re: Mr.Yuck] #1101547
10/26/11 03:48 PM
10/26/11 03:48 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Tex make sure you tell your buddy how much we love his really fine looking Runner. That is really nice. Ron
Re: what do you think i might gain ? [Re: Mr.Yuck] #1101548
10/26/11 05:48 PM
10/26/11 05:48 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Mr Yuck,
for my part i always thought this car underperformed.it did have fuel issues which have been addressed though not to my satisfaction.the times were run with it quite lean,NO tacho or shift light.
jetting was 74/75 outers 62 inner,cruise is good so have gone up to 79 outer jetting.
squirter is i think stock have not checked springs but there is no bog.
yes it should blow the doors off my Satellite too
Ron i'll let Greg know
Tex
New best MPH 130.32
