Compressed head gasket thickness question. #1101148
10/24/11 09:41 PM
10/24/11 09:41 PM
Bowling Green, KY
K
KY Charger Offline OP
K
Bowling Green, KY
Would it matter if one gasket is .038 and one is .039 compressed thickness, the one on the passenger side is .039 and I was gonna buy a gasket that is .038 compressed thickness but didn't know if the different thicknesses would matter I had to pull off the driver side head due to it leaking.
Re: Compressed head gasket thickness question. [Re: KY Charger] #1101149
10/24/11 09:43 PM
10/24/11 09:43 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
nope!
Re: Compressed head gasket thickness question. [Re: KY Charger] #1101150
10/25/11 10:15 AM
10/25/11 10:15 AM
NC
440Jim Offline
440Jim  Offline
NC
The one side is 0.001" off. That is what it is.
If the one side is 0.039" why would you buy a 0.038" for the other side? No reason? Then don't do it.
Re: Compressed head gasket thickness question. [Re: 440Jim] #1101151
10/25/11 09:05 PM
10/25/11 09:05 PM
Bowling Green, KY
K
K
Bowling Green, KY
Was gonna go with a cometic gasket on the side that I had the problem with for better insurance. And don't want to pull the other head off unless I absolutely have to.
Re: Compressed head gasket thickness question. [Re: KY Charger] #1101152
10/25/11 09:18 PM
10/25/11 09:18 PM
Guitar Jones Offline
.001" isn't going to make any difference however you better measure that Cometic as I recall another post on here where someone measured one and it was off significantly from what was advertised. I don't know if it was packaged wrong or what but I would measure. The flat surfaces of a Cometic don't crush, only the embossed areas.
Re: Compressed head gasket thickness question. [Re: Guitar Jones] #1101153
10/25/11 09:29 PM
10/25/11 09:29 PM
Az
Crizila Offline
Crizila  Offline
Az
That would be me, and that's a big 10-4! Advertised at .040". Actual was .052". As was said, measure each section ( on the flat ) individually and add them up. Cost me just under 1/2 a CR.
Fastest 300
