Trailer gets new floor.What do you have in your trailer #1100284
10/23/11 10:23 PM
10/23/11 10:23 PM
Super Scamp Offline OP
I'm redoing the inside of my 30' Victory trailer new paint, rubber floor, carpet, 110 lighting,diamond plate trim and a hole bunch of other stuff.
What are you using for a floor? Rubber/Diamond plate,paint,carpet and I need some pics of your trailer for some idea's.
Just One Man's Opinion Mopar Mafia Racing
Re: Trailer gets new floor.What do you have in your trailer [Re: Super Scamp] #1100285
10/23/11 10:30 PM
10/23/11 10:30 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Your plywood is fine ? ... I am redoing parts of the floor on two diff motorhomes and am using 3/4 treated ply. SURE gives you a WORKout flinging that stuff around.
Re: Trailer gets new floor.What do you have in your trailer [Re: Super Scamp] #1100286
10/23/11 10:36 PM
10/23/11 10:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I like diamond plate... but dont get oil on it... you'll
end up on your butt
Re: Trailer gets new floor.What do you have in your trailer [Re: Super Scamp] #1100287
10/24/11 12:19 AM
10/24/11 12:19 AM
ky
68roadrunner Offline
ky
rubber coin on mine. not all rubber is made alike, some is very thin and wrinkles up. mine is the large coins made in it, have not had any trouble.
Re: Trailer gets new floor.What do you have in your trailer [Re: Super Scamp] #1100288
10/24/11 12:54 AM
10/24/11 12:54 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Truck bed liner, floor an ramp.
"Just a Bracket car dressed up like a streetcar"
Re: Trailer gets new floor.What do you have in your trailer [Re: Super Scamp] #1100289
10/24/11 07:36 AM
10/24/11 07:36 AM
Guitar Jones Offline
Mine is all diamond plate with aluminum sides.
Re: Trailer gets new floor.What do you have in your trailer [Re: Guitar Jones] #1100290
10/24/11 09:49 AM
10/24/11 09:49 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
That's what I would recommend, at least runners for your tires to set on.
Any kind of tile can come loose and allow things to move around, imo.
Wood kinda sucks because it can be stained so easy, same with carpet.
Re: Trailer gets new floor.What do you have in your trailer [Re: MR_P_BODY] #1100291
10/24/11 10:59 AM
10/24/11 10:59 AM
end up on your butt
I plan on using Diamond plate for runners under the car and carpet the front 9ft of the trailer.
Trying to find a thick rubber for the back 3/4 of the trailer Coin stuff is $$$$$$$.. and I'm on a budget. Mr. P that trailer looks nice with the "D" Plate on the sides.
I have diamond plate for the ramp.. got a great deal on it from the boys in Ohio.. Thanks Jack..
Re: Trailer gets new floor.What do you have in your trailer [Re: Super Scamp] #1100292
10/24/11 11:07 AM
10/24/11 11:07 AM
MR_P_BODY Offline
MR_P_BODY  Offline
end up on your butt
Thats who I got my diamond plate from also
Re: Trailer gets new floor.What do you have in your trailer [Re: Super Scamp] #1100293
10/24/11 05:44 PM
10/24/11 05:44 PM
Michigan, US
ben1692 Offline
ben1692  Offline
Michigan, US
ive got a big oil slick where motor is it seal the plywood great only sometimes its real slippery when wet
Post deleted by moparts [Re: ben1692] #1100294
10/24/11 05:45 PM
10/24/11 05:45 PM
Re: Trailer gets new floor.What do you have in your trailer #1100295
10/24/11 05:49 PM
10/24/11 05:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I keep horses in my trailer, and broke white women
Your getting around for a newbie
Re: Trailer gets new floor.What do you have in your trailer [Re: MR_P_BODY] #1100296
10/24/11 09:35 PM
10/24/11 09:35 PM
Niles, Michigan
Hitman340 Offline
Hitman340  Offline
Niles, Michigan
Here is mine,But it could be your if you-ed like.I need a bigger one.
Re: Trailer gets new floor.What do you have in your trailer [Re: Hitman340] #1100297
10/25/11 08:46 AM
10/25/11 08:46 AM
farmingdale ny 11735
blracing Offline
blracing  Offline
just paint and some floor tiles up front. diamond plate is nice, but why carry all that extra weight?
Re: Trailer gets new floor.What do you have in your trailer [Re: blracing] #1100298
10/25/11 09:02 AM
10/25/11 09:02 AM
Cincinnati, Ohio
Cincinnati, Ohio
Because diamond plate spreads the load across several cross members underneath and is a good traction surface for your tires.
Floor tiles can easliy be more weight than aluminum plate.
Re: Trailer gets new floor.What do you have in your trailer [Re: Super Scamp] #1100299
10/30/11 01:52 PM
10/30/11 01:52 PM
ohio
dragon Offline
dragon  Offline
ohio
when you are using diamond plate are you puting the plate down frist and then putting tile down this would get rid of the ridge and also would be less tile and save some money also does the diamond plate come in different thickens? also where in OHIO are you getting your plate and how about the tile THANKS
Re: Trailer gets new floor.What do you have in your trailer [Re: dragon] #1100300
10/31/11 12:23 AM
10/31/11 12:23 AM
I have seen 1/16 polished aluminum diamond plate, I have some scrap pieces I bought from a local scrap yard. I should measure it to make sure I have called metal supliers and ask about the different aluminum diamond plate available and the cost per sheet, I'm sure they said the thinnest is 1/16
