Can I get a little help reading some plugs please. #1098394
10/21/11 02:41 AM
10/21/11 02:41 AM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
Hi there....can I get a little help. What do you guys think about the spark plugs.
Fuel, 91 octane, pump gas.
Engine, 472 Hemi, 11 to 1 compression, aluminum heads,
Plugs, Autolite 63.
Timing, total is 30 degree.
What do you think??
Thanks, Troy
....there is nothing like driving my 1968 Hemi Dart around town and having people looking at you like you're nuts!!
Re: Can I get a little help reading some plugs please. [Re: Troy] #1098395
10/21/11 02:42 AM
10/21/11 02:42 AM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
....one more.
Re: Can I get a little help reading some plugs please. [Re: Troy] #1098396
10/21/11 03:48 AM
10/21/11 03:48 AM
Cab_Burge Online work
Cab_Burge  Online Work
Any speckles, black or bright silver, on the porclyn? If so I would be tempted to try some 62s and then take another look after hitting it a WOT I prefer a cold plug and a lean mixture. I don't have any real experience with a aluminum headed pump gas hemi on the street though so keep that in mind I also ran 34 to 36 degrees in the iron headed 426 Hemi I work on
Re: Can I get a little help reading some plugs please. [Re: Cab_Burge] #1098397
10/21/11 02:44 PM
10/21/11 02:44 PM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
There are no speckles showing and I think the color looks good. I was looking at the ground strap. I thought there was something about where the ground strap changes color but I cant remember what it was.
Re: Can I get a little help reading some plugs please. [Re: Troy] #1098398
10/21/11 02:57 PM
10/21/11 02:57 PM
Az
Crizila Offline
Crizila  Offline
Az
I likem. Demarcation on the ground strap ( heat range ) looks perfect. Color ring around barrel looks good too.
Fastest 300
Re: Can I get a little help reading some plugs please. [Re: Troy] #1098399
10/21/11 03:04 PM
10/21/11 03:04 PM
Once the plug is colored up it is harder to read, try a new set and hit it once at WOT and pull the plugs, look for a very narrow pencil like mark on the ground strap(no color yet on one hit ), You want it in the middle of the bend, if it is not in the middle,IE one third from the body or 1/3 third from the tip, then try a different heat range do you have a magnifier you can use? I use a 10X dental plug reader It is amazing what you can see with magafication
Re: Can I get a little help reading some plugs please. [Re: Cab_Burge] #1098400
10/21/11 03:23 PM
10/21/11 03:23 PM
SoCal
Brian Hafliger Offline
SoCal
They look good to me too but new plugs are the only way to be sure.
Why 30°? I would bet 35 or so would be alot better even with 11:1...
Brian Hafliger
Re: Can I get a little help reading some plugs please. [Re: Brian Hafliger] #1098401
10/21/11 05:40 PM
10/21/11 05:40 PM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Brian..I was thinking the same thing! 30* seems a little LOW to me! Troy,why not 34-36 degrees? Have you already tried that,with BAD results?
Re: Can I get a little help reading some plugs please. [Re: Troy] #1098402
10/21/11 07:17 PM
10/21/11 07:17 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
the best way to really check em,is to make a full pass&shut the car off..for the street ur timing looks good on the strap,i cant see the the rest
Re: Can I get a little help reading some plugs please. [Re: Troy] #1098403
10/22/11 03:05 AM
10/22/11 03:05 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Those look pretty good to me. Timing looks close, maybe add 2-degrees? Mixture may be a tad rich? Were these pulled right after a run?
Re: Can I get a little help reading some plugs please. [Re: fishy340] #1098404
10/22/11 12:34 PM
10/22/11 12:34 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Can you provide more info like... street or race use... how old are the plugs.... all in all they look ok to me
Re: Can I get a little help reading some plugs please. [Re: Cab_Burge] #1098405
10/22/11 12:59 PM
10/22/11 12:59 PM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Once the plug is colored up it is harder to read, try a new set and hit it once at WOT and pull the plugs, look for a very narrow pencil like mark on the ground strap(no color yet on one hit ), You want it in the middle of the bend, if it is not in the middle,IE one third from the body or 1/3 third from the tip, then try a different heat range do you have a magnifier you can use? I use a 10X dental plug reader It is amazing what you can see with magnification
X2
Hi Troy, how have you been?
NGK's are preferred because you can see the cadmium burn line on the ground strap. Fuel ring on the porcelain should be mid way up and watch for aluminum on the porcelain as well (detonation)
And one other thing, dont use anti-sieze with a power adder, it will make the motor detonate.
8.30's @3400 lbs
Re: Can I get a little help reading some plugs please. [Re: Mike Swann] #1098406
10/22/11 06:19 PM
10/22/11 06:19 PM
Mo.
racerx Offline
racerx  Offline
Mo.
umm.....never herd this b4
Re: Can I get a little help reading some plugs please. [Re: Troy] #1098407
10/22/11 07:30 PM
10/22/11 07:30 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
IS THAT ANTI SIEZE ON THE RIM OF THE PLUG MAY BE TO MUCH IF IT IS
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Can I get a little help reading some plugs please. [Re: WHITEDART] #1098408
10/22/11 09:30 PM
10/22/11 09:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its anti seize
Re: Can I get a little help reading some plugs please. [Re: MR_P_BODY] #1098409
10/23/11 04:43 AM
10/23/11 04:43 AM
West Coast, CA
Troy Offline OP
Troy  Offline OP
West Coast, CA
Thanks for all the remarks!
I'm at 30 degrees to be a little on the safe side and it is a stroker motor with a larger stroke...I plan on adding more timing soon. Looking at the plug I thought the timing was close. This is a street,strip car but has not been to the track yet so no passes yet.
Yes that is anti seize on the thread. I use it when running aluminum heads.
