Re: Winter storage, empty radiator or put in anti-freeze?
[Re: Baxter61]
#1098161
10/20/11 01:54 PM
10/20/11 01:54 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Put in anti freeze and run it like said... that way its in the block... if you empty the radiator you dont empty the block
[Re: Baxter61]
#1098162
10/20/11 04:58 PM
10/20/11 04:58 PM
Posts: 462 Stockholm, Sweden
fed
Stockholm, Sweden
You have two drainplugs! Lowe on both side on the block. Remove them and you drain the block. the are hard to reach beneeth Manifolds and ususlly hard to get loose. But wen you do, replace them with "petcoks" And draining is a breese next time
Cuda, -70 Valiant-65 AWB, Valiant Signet200 -65 Topchopped dragcar. Topolino Fuel Altered. NostalgiaFED Sold, SuperComp Bantam Altered, Sold Ex Harlan Thompsons Nitro funny car American Graffiti Sold,
[Re: nhramark]
#1098164
10/20/11 05:34 PM
10/20/11 05:34 PM
Posts: 1,019 Finland
mafo
Finland
anti freeze prevents rust, just a thing to remember
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
[Re: mafo]
#1098165
10/20/11 05:55 PM
10/20/11 05:55 PM
MR_P_BODY
That and I've had them damn block drains be plugged up with core sand ... it might dribble some and you think its drained but its just plugged up...I always use anti freeze when I put the car away
