What does a letter "R" mean on a 1969 383 engine pad? #1097969
10/20/11 01:45 AM
10/20/11 01:45 AM
Minneapolis, MN
hemi70se Offline OP
hemi70se  Offline OP
Minneapolis, MN
I've got a 1969 383 engine from out of a 1/2 ton pickup. It was a 2BBL with a 3 speed manual behind it. The block pad by the alt. has a lone letter "R" on it. I was wondering what this means. Also I was tickled to find 906 heads on it!!!!!!! It also has a steel crank.... pretty sure it got that because it was a stick shift. Anybody?
Re: What does a letter "R" mean on a 1969 383 engine pad? [Re: hemi70se] #1097970
10/20/11 01:52 AM
10/20/11 01:52 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Could be "R" for regular fuel
Re: What does a letter "R" mean on a 1969 383 engine pad? [Re: ScottSmith_Harms] #1097971
10/20/11 01:54 AM
10/20/11 01:54 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I just tried posting all the codes but it posted as a garbled mess so I deleted it.... R = Regular fuel
Re: What does a letter "R" mean on a 1969 383 engine pad? [Re: 1_WILD_RT] #1097972
10/20/11 02:04 AM
10/20/11 02:04 AM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: What does a letter "R" mean on a 1969 383 engine pad? [Re: hemi70se] #1097973
10/20/11 02:08 AM
10/20/11 02:08 AM
Neenah,Wi
rod440 Offline
rod440  Offline
Neenah,Wi
I think all 383's had steel cranks,except the '71 2 BBL?
Re: What does a letter "R" mean on a 1969 383 engine pad? [Re: rod440] #1097974
10/20/11 02:16 AM
10/20/11 02:16 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
& all '69 big blocks used "906" heads (non-HEMI)
Re: What does a letter "R" mean on a 1969 383 engine pad? [Re: 6bblgt] #1097975
10/20/11 10:08 AM
10/20/11 10:08 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
All above are correct , forged crank except the 71 2 bbl , R is a rated 9.2 compression engine , actual is more like 8.2 - 8.5 , and they all had 906's .
Re: What does a letter "R" mean on a 1969 383 engine pad? [Re: JohnRR] #1097976
10/20/11 12:50 PM
10/20/11 12:50 PM
dogdays Offline
dogdays  Offline
Except those that came with 250 heads, which are almost exactly like 906s. Or was that only on '68s? The deal was that Chrysler most likely didn't have the volume to support a low-perf AND a high-perf head like chevy did. That's one of the fun things about Mopars. Most any engine can be made to run strong without changing major components; blocks, heads, cranks and rods.
Anyway the 906 head features prominently in MOPAR mythology, even though any B/RB head made from 1968 on has the same lousy combustion chamber and virtually the same flow characteristics. Check out the Tech Archives.
R.
Re: What does a letter "R" mean on a 1969 383 engine pad? [Re: dogdays] #1097977
10/20/11 03:17 PM
10/20/11 03:17 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I think the 250 was a 68 head , I guess if we want to dig up obscure head numbers we could throw the 902 in there though I have never actually seen one of them .
Re: What does a letter "R" mean on a 1969 383 engine pad? [Re: JohnRR] #1097978
10/20/11 04:29 PM
10/20/11 04:29 PM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
-902 is '74, right? I have a set on a motorhome engine.
Re: What does a letter "R" mean on a 1969 383 engine pad? [Re: Fury Fan] #1097979
10/20/11 05:11 PM
10/20/11 05:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No clue , figured I may as well throw them out there since the obscure 250's were brought up ...
Re: What does a letter "R" mean on a 1969 383 engine pad? [Re: JohnRR] #1097980
10/20/11 05:25 PM
10/20/11 05:25 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have several sets of 902 heads, all that I could see that is different from 906 heads were smaller valves.
JB Rhinehart, Realist
A-Body's RULE!
Re: What does a letter "R" mean on a 1969 383 engine pad? [Re: Rhinodart] #1097981
10/20/11 05:35 PM
10/20/11 05:35 PM
dogdays Offline
dogdays  Offline
Different valve sizes?
'68 to '79 they were all 2.08/1.74. Even my 213 motorhome heads had'em.
R.
Re: What does a letter "R" mean on a 1969 383 engine pad? [Re: dogdays] #1097982
10/20/11 06:08 PM
10/20/11 06:08 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
R.
Well said; biggest difference between Chevies and Mopars is any B or RB can be easily modified to produce as much power as any Magnum or HP motor.......with a Chevy a low perf BB had cast cranks, 2 bolt mains, lower compression pistons, lower flowing oval port heads, hydraulic cams, cast iron intakes and Q jets and shared very little in terms of actual parts with it's high performance siblings.
Add 906 "Magnum" heads to the Mopar Mythbusters file!
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
