Re: What does a letter "R" mean on a 1969 383 engine pad?
[Re: JohnRR]
#1097976
10/20/11 12:50 PM
10/20/11 12:50 PM
dogdays
Except those that came with 250 heads, which are almost exactly like 906s. Or was that only on '68s? The deal was that Chrysler most likely didn't have the volume to support a low-perf AND a high-perf head like chevy did. That's one of the fun things about Mopars. Most any engine can be made to run strong without changing major components; blocks, heads, cranks and rods. Anyway the 906 head features prominently in MOPAR mythology, even though any B/RB head made from 1968 on has the same lousy combustion chamber and virtually the same flow characteristics. Check out the Tech Archives. R.
[Re: Fury Fan]
#1097979
10/20/11 05:11 PM
10/20/11 05:11 PM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
-902 is '74, right? I have a set on a motorhome engine.
No clue , figured I may as well throw them out there since the obscure 250's were brought up ...
[Re: Rhinodart]
#1097981
10/20/11 05:35 PM
10/20/11 05:35 PM
dogdays
Different valve sizes? '68 to '79 they were all 2.08/1.74. Even my 213 motorhome heads had'em. R.
[Re: dogdays]
#1097982
10/20/11 06:08 PM
10/20/11 06:08 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
R.
Well said; biggest difference between Chevies and Mopars is any B or RB can be easily modified to produce as much power as any Magnum or HP motor.......with a Chevy a low perf BB had cast cranks, 2 bolt mains, lower compression pistons, lower flowing oval port heads, hydraulic cams, cast iron intakes and Q jets and shared very little in terms of actual parts with it's high performance siblings.
Add 906 "Magnum" heads to the Mopar Mythbusters file!
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
