Re: Guys with indy ez heads. [Re: topbrent] #1097861
10/29/11 07:21 PM
10/29/11 07:21 PM
jersey
Spaceman Spiff Offline OP
jersey
Well then, looks like that idea won't work.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Guys with indy ez heads. [Re: Spaceman Spiff] #1097862
10/29/11 09:01 PM
10/29/11 09:01 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Well you could always go with the Stealth or Eddy heads and get the same results.The only reason I went with the Indy's is so I have room to grow I would consider notching and boxing the heater box in your car.Also with the EZ's all you really need to do is clean and blend the bowls,trim down the push-rod pinch,and just clean up the ports a little bit and they work very well.Just make sure you buy them from someone that will check the valve job and set the springs up for you.I wouldn't use the Indy springs and retainers,and some builders won't use the valves either for roller spring pressures.
I got mine from Nick at www.compu-flow.com Great guy and really knows the Indy heads.
Gus
64 Plymouth Savoy
Dana 60
Re: Guys with indy ez heads. [Re: fourgearsavoy] #1097863
10/29/11 11:18 PM
10/29/11 11:18 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I agree that edelbrocks would be a better choice for you, especially out of the box.
The eddies small port velocity along with 500 cubes would be a torque monster that wouldn't have any problem getting that pig moving. Also 440source sells the modern cnc ported stealths for under 2k.
Re: Guys with indy ez heads. [Re: viperblue72] #1097864
10/30/11 01:21 AM
10/30/11 01:21 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I went with the Indy EZ heads for the same reason Gus did. Room to grow and go faster down the road if I would want to step it up a little. The EZ's have more potential when worked all out over the Eddy's and Stealth.
But I do agree the Eddy's or stealth's will work fine on your combo. Dont get me wrong as they are great heads I just feel the EZ's have more potential to be worked more. Ron
Re: Guys with indy ez heads. [Re: 383man] #1097865
10/30/11 03:43 AM
10/30/11 03:43 AM
ohio
67mprfan Offline
67mprfan  Offline
ohio
As mentioned there are great guys to buy from and won't steer you wrong I got mine from Nick @ compu-flow. ez-1
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Guys with indy ez heads. [Re: 67mprfan] #1097866
10/30/11 12:27 PM
10/30/11 12:27 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
I'll be pulling my eddy heads off my dart for next year and plan on installing cnc 440-1's.
Re: Guys with indy ez heads. [Re: Mopar-Al] #1097867
10/30/11 12:30 PM
10/30/11 12:30 PM
Las Vegas
afxcoronet Offline
afxcoronet  Offline
Las Vegas
I got my MW EZs through Dwayne Porter, and his service has been second to none. They have been 9.40s in 3200lb car...
Curtis
Taking over the World one win light at a time.
Re: Guys with indy ez heads. [Re: afxcoronet] #1097868
10/30/11 12:46 PM
10/30/11 12:46 PM
Bellevue, NE
Charger453 Offline
Charger453  Offline
Bellevue, NE
If you think you'll want room to grow down the road, I'd go with the Indys. You say you want low 12's, high 11's ... but once you get there, you want more. If you think the Indys won't clear the heater box and you don't want to cut stuff up, Edelbrock RPM's will get the job done. I have a set of hand ported RPM's on a 453 (400 stroker) in my 3800-3900 lb Charger. She just clicked off a 6.79 in the 1/8, approx 10.70 in the 1/4. Edelbrocks will get you there.
