Re: Guys with indy ez heads.
[Re: topbrent]
#1097861
10/29/11 07:21 PM
10/29/11 07:21 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
Well then, looks like that idea won't work.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: Spaceman Spiff]
#1097862
10/29/11 09:01 PM
10/29/11 09:01 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Well you could always go with the Stealth or Eddy heads and get the same results.The only reason I went with the Indy's is so I have room to grow I would consider notching and boxing the heater box in your car.Also with the EZ's all you really need to do is clean and blend the bowls,trim down the push-rod pinch,and just clean up the ports a little bit and they work very well.Just make sure you buy them from someone that will check the valve job and set the springs up for you.I wouldn't use the Indy springs and retainers,and some builders won't use the valves either for roller spring pressures. I got mine from Nick at www.compu-flow.com Great guy and really knows the Indy heads. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 383man]
#1097865
10/30/11 03:43 AM
10/30/11 03:43 AM
Posts: 1,030 ohio
67mprfan
ohio
As mentioned there are great guys to buy from and won't steer you wrong I got mine from Nick @ compu-flow. ez-1
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: Mopar-Al]
#1097867
10/30/11 12:30 PM
10/30/11 12:30 PM
Posts: 1,151 Las Vegas
afxcoronet
Las Vegas
I got my MW EZs through Dwayne Porter, and his service has been second to none. They have been 9.40s in 3200lb car...
Curtis
Taking over the World one win light at a time.
