Looking for a 440 six pack #1097122
10/18/11 06:38 PM
10/18/11 06:38 PM
Rancho Cucamonga,Ca
3
392charger Offline OP
Rancho Cucamonga,Ca
Hey all,
Hope this is the right forum for this question. I am looking to buy a new 440 six pack. The complete set up from intake, carbs, air cleaner, linkage, etc... Who has the best price/service? Thanks Moparts
Re: Looking for a 440 six pack [Re: 392charger] #1097123
10/18/11 07:23 PM
10/18/11 07:23 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
any number of sponsers on this site will have what you are looking for. pick a few Dixie, Mancini, so-on and so-on, invest in a phone call and see what they are willing to do for you. your looking at spending a good chunk of change so i'll bet they will 'flex' with their pricing. what you are going to end up with by asking this question is 20 responses from 20 members all loving 20 different vendors! well, not really that many but you get the picture! (BTW, i got mine from Mancini years ago but lately i've been lovin' Dixie!)
Re: Looking for a 440 six pack [Re: 392charger] #1097124
10/18/11 09:55 PM
10/18/11 09:55 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Got mice from Atlantic Speed. Shipped to the door for $2100 complete, I did have a $100 ebay coupon.
P.S. it rocks.
Coming soon!!!!
Re: Looking for a 440 six pack [Re: Mr.Yuck] #1097125
10/18/11 09:58 PM
10/18/11 09:58 PM
P.S. it rocks.
I was just wondering if it had alot more power than a single 4 bbbl as I was considering piecing together one if so
Re: Looking for a 440 six pack [Re: RapidRobert] #1097126
10/19/11 08:21 AM
10/19/11 08:21 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
P.S. it rocks.
Like anything else it depends on the set-up...it won't do any worse that's for sure. Plus it looks cool.
Re: Looking for a 440 six pack [Re: Mr.Yuck] #1097127
10/19/11 01:01 PM
10/19/11 01:01 PM
dogdays Offline
dogdays  Offline
I don't think there is any question about the "WOW!" factor, but a good single 4-barrel on a decent intake will put a 6-pack on the trailer 9 times out of 10. The 6-pack intake has some flow problems that are almost impossible to deal with.
If you're asking the question I'd suggest looking at an Edelbrock Performer RPM or Holley Street Dominator topped by an 800-cfm Edelbrock Thunder Series or Performer Series if the Thunder Series is too pricey.
Also, the 6-pack flow rating if compared at the same pressure drop as a 4-barrel would be 850 cfm.
R.
Re: Looking for a 440 six pack [Re: dogdays] #1097128
10/19/11 01:16 PM
10/19/11 01:16 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
[quote a good single 4-barrel on a decent intake will put a 6-pack on the trailer 9 times out of 10. The 6-pack intake has some flow problems that are almost impossible to deal with.
Reason being most are unfamiliar with properly tuning a sixpack set up otherwise... a properly tuned sixpack set up will match/beat a modified 4 bbl set-up
That "flow" rating comparison would be more apt to be around 930-950 cfm
R.
Re: Looking for a 440 six pack [Re: DAYCLONA] #1097129
10/19/11 01:27 PM
10/19/11 01:27 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
R.
That's what I was thinking more like 950ish. When I bought this unit I had zero 6-pack working expierence. It's not as hard as you think as long as you follow the tuning tips here and from holley. I don't have any fancy metering blocks or anything. I'm looking to get into the 11.teens on the 29th, and after winter upgrades to 2" headers I think It will pull 11.0's or better. I say pull out the wallet and go get it done.
P.S. It will dead KILL the Eddy 800 thunder or other, wouldn't even be close.
Re: Looking for a 440 six pack [Re: DAYCLONA] #1097130
10/19/11 01:39 PM
10/19/11 01:39 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
R.
The whole " a 4bbl makes more power than a 6 pack " is largely yet another Mopar urban myth that is spewed forth every time the topic comes up.
Here's the proof; http://www.hotrod.com/techarticles/hrdp_0712_mopar_intake_manifold_comparo/
which shows that the 6 pack manifold is the best choice for average hp and torque out of the AFTERMARKET manifolds and carbs tested in a 450hp motor. For a stock intake, the results are amazing and right on target with the best the aftermarket has to offer.
Obviously if you're building a 600+ hp race engine there are better choices, but the stage II test showed the 6 pack doing quite well in the 500+ hp range as well.
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: Looking for a 440 six pack [Re: Mr.Yuck] #1097131
10/19/11 02:03 PM
10/19/11 02:03 PM
Sterling Heights, Michigan 483...
daniel_depetro Offline
I read an article a few years back in one of the magazines where they compared the Six Pack set-up against a few different 4-bbl. set-ups.
The two magazine shootouts I have read show the Edelbrock Performer RPM & Holley 4-bbl. carburetor set-up being dead even with the Six Pack set-up when they were both dialed in on the engine dyno.
$500.00 shipped = Holley ultra series double pumper. (All aluminum lightweight carburetor with billet metering blocks & baseplate, clear sight glasses, ...)
$250.00 shipped = Edelbrock Performer RPM aluminum intake manifold
$350.00 shipped = Reproduction 340/440 large oval air cleaner
$100.00 shipped = Reproduction large oval air filter element
($1,200.00 = total)
$2,400.00+ = Six Pack set-up (Intake manifold, carburetors, linkages, fuel lines, air cleaner & filter, ...)
Is the 'wow factor' worth double the cost to you?!?
1969 Dodge Super Bee A12 (440 Six Pack, 4-speed, Dana 60 4.10)
1972 Plymouth Road Runner (400, 4-speed, 8.75" 3.23)
1974 Plymouth Duster 360 (360, 4-speed, 8.75" 3.23)
Re: Looking for a 440 six pack [Re: 392charger] #1097132
10/19/11 02:13 PM
10/19/11 02:13 PM
Cab_Burge Online work
Cab_Burge  Online Work
Hey all,
you have a PM
Re: Looking for a 440 six pack [Re: daniel_depetro] #1097133
10/19/11 02:24 PM
10/19/11 02:24 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
($1,200.00 = total)
Yes only thing that draws more attention is a Hemi, And I can't afford one of those.
Re: Looking for a 440 six pack [Re: daniel_depetro] #1097134
10/19/11 02:35 PM
10/19/11 02:35 PM
DPelletier Offline
DPelletier  Offline
($1,200.00 = total)
Absolutely right. So it really breaks down like this;
6 pack advantages;
- power while still a stock setup
- fits under N96 hoods
- "wow" factor as mentioned.
RPM/Holley advantages;
- cheaper
- only one carb to mess with
......Choice is up to the individual......but as I said, the 6 pack is an amazing STOCK setup. If this hobby was all about speed for the money, we'd all be driving 440 powered A bodies (yes, with 4bbls!!)
Re: Looking for a 440 six pack [Re: DPelletier] #1097135
10/19/11 03:02 PM
10/19/11 03:02 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
And if you want to cheap out what you can always do is a Holley SD or edelbrock RPM intake and pick up a drop-base 4bbl oval 6-pack type air cleaner assy from hybrid fiberglass solutions. Since the air cleaner covers most of the intake anyway, you have the same wow-factor when you pop the hood. You can be a poser and put on 6-pack decals if you want to as well.
Re: Looking for a 440 six pack [Re: DaytonaTurbo] #1097136
10/19/11 03:15 PM
10/19/11 03:15 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
true rating for a six-pak is 1030cfm. a big 4bbl on a dual plane intake making big power gains over a six-pak is insane.
Re: Looking for a 440 six pack [Re: daniel_depetro] #1097137
10/19/11 04:49 PM
10/19/11 04:49 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
($1,200.00 = total)
You need to rethink the cost of the reproduction oval element, since they are no longer in production those that have them, and know it, will be hard pressed to let one go for $100 ...
Re: Looking for a 440 six pack [Re: lewtot184] #1097138
10/19/11 06:03 PM
10/19/11 06:03 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
actually the rating is - 500cfm for EACH outboard + 350cfm for the center. that would be 1350cfm. and the seat of the pants effect when they kick in is amazing to say the least!
Re: Looking for a 440 six pack [Re: mikemee1331] #1097139
10/19/11 06:09 PM
10/19/11 06:09 PM
DPelletier Offline
DPelletier  Offline
As was said, the flow of 2bbl carbs is measured differently than 4bbl carbs. The 1350 CFM 6 pack setup equates to approximately 950CFM in a 4 barrel.....but yes they work well.
Re: Looking for a 440 six pack [Re: mikemee1331] #1097140
10/19/11 06:28 PM
10/19/11 06:28 PM
dogdays Offline
dogdays  Offline
Yeah, magical thinking strikes again! The 2-barrel carb ratings are at 3" Hg depression, the 4-barrel at 1.5" Hg. So to convert flow from 2-barrel terms to 4-barrel terms you have to divide by the square root of 2. The ACTUAL combined CFM of the three 6-pack carbs, RATED AS A 4-BARREL, is 955 cfm.
Now on to the article that Dpelletier referenced. The engine was a 383. You don't have to be a Mopar nut to know that 383 and 440 intakes are different. But given that the article was about 383 intakes, the results are somewhat favorable for the 6-pack. In average over 2500 - 6000 rpm it made the highest torque by 1 lb-ft over the Torker 383 and tied the Torker 383 in average horsepower.
In peak horsepower the 6-pack was beaten by the TM6, Performer RPM, Victor 383, Torker 383, Weiand High Ram single 4-barrel, Street Dominator and the M1 Single Plane. So it seems that there is truth in the contention that a good single 4-barrel will make more power on a good manifold.
There are flow problems inherent to the 6-pack design that limit its power potential on larger or higher revving engines.
Here's a quote from the referenced article: "We've seen this intake lose a lot of power compared to modern four-barrel intakes on bigger engines or ones with more rpm, but it seemed we just hit a really happy spot with our little 395ci big-block under 6,000 rpm."
R.
Re: Looking for a 440 six pack [Re: dogdays] #1097141
10/19/11 06:36 PM
10/19/11 06:36 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
R.
but they ARE really, really cool!
