66 & 67 B body Cars rear slicks #1096865
10/18/11 11:48 AM
10/18/11 11:48 AM
MS
redex79 Offline OP
redex79  Offline OP
MS
I am trying to fit as much tire under my 66 Belvedere as possible. I am trying a friends set of Hoosiers radials 30 x 9 on steel rims 4 1/2 off set. They fit in the wheel well but they rub the outside inner well just a little. I'm using stock location on the springs and would rather not mini tub. What tire and wheel combo are you 66 67 B body guys using? Any help appreciated.
Truckin Weekend !
70 Dodge Dart Swinger
11 Ram 1500 Laramie 4x4
21 Dodge Durango GT
Re: 66 & 67 B body Cars rear slicks [Re: redex79] #1096866
10/18/11 01:34 PM
10/18/11 01:34 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
275/60-15 BFG Drag Radial mounted on a 15 x 7 Cragar S/S on the back of my '67 R/T. I believe that's a 4 1/2" backspace. Ever so slight rubbing going around corners from the outer wheelhouse. But, I also keep them at something near 30psi on the street.
Michael
Re: 66 & 67 B body Cars rear slicks [Re: redex79] #1096867
10/18/11 01:46 PM
10/18/11 01:46 PM
TMP66 Offline
TMP66  Offline
On my old '67 Coronet wagon I ran 9x30 Bias Firestones (94.0" circumference)on a 15x7 4 1/4" backspacing steel wheel. I cut the pads off and centered the housing before setting the pinion angle and re-welding new pads. No sidewall rubbing issues.
Re: 66 & 67 B body Cars rear slicks [Re: redex79] #1096868
10/18/11 02:09 PM
10/18/11 02:09 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
I am putting this 67 together,9X29" slicks with a 5" backspace. I relocated the springs to the framerail though. Plenty of clearence on both sides of the tire this way.
Re: 66 & 67 B body Cars rear slicks [Re: redex79] #1096869
10/18/11 04:43 PM
10/18/11 04:43 PM
Sterling Hts, MI
2
2FASTCORONET Offline
Sterling Hts, MI
If they work for you I have a brand new set of Phoenix 30 x 9 mounted on 8" cop wheels,tubes, screwed, matched circumference and balanced by Harlo Tire I am going to sell if your interested. Dennis
Re: 66 & 67 B body Cars rear slicks [Re: 2FASTCORONET] #1096870
10/18/11 05:05 PM
10/18/11 05:05 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I've run 275/60/15's on the back of 2 67's. I had to roll the inner wheel lip up some.
Coming soon!!!!
Re: 66 & 67 B body Cars rear slicks [Re: redex79] #1096871
10/18/11 05:14 PM
10/18/11 05:14 PM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
I use a 15 x 8 wheel with a 4.5 inch backspacing and M/T 9 x 28 slicks or 11.50 x 28 x 15 M/T ET Streets.
Springs in stock location, stock wheelwells and no alteration of the front of the wheelwell. Completely removed the inner lip on the quarterpanel. No issues with this set up.
Re: 66 & 67 B body Cars rear slicks [Re: redex79] #1096872
10/19/11 03:25 AM
10/19/11 03:25 AM
Canada
CrAzYMoPaRGuY Offline
Canada
12.50/28/15 ET Streets on 15x8 with 3 3/4" backspace
CrAzYMoPaRGuY
Re: 66 & 67 B body Cars rear slicks [Re: CrAzYMoPaRGuY] #1096873
10/19/11 07:52 AM
10/19/11 07:52 AM
S.W. PA
6PACMAC Offline
6PACMAC  Offline
S.W. PA
10x28 Goodyears on 8.5 centerlines with 4.5 backspace I think. Maybe alittle more backspace than that. All stock springs location in a 67' GTX. Pretty tight though. New slicks will be 9x29s.
Re: 66 & 67 B body Cars rear slicks [Re: redex79] #1096874
10/19/11 07:14 PM
10/19/11 07:14 PM
Oklahoma City
Jwilli500 Offline
Jwilli500  Offline
Oklahoma City
I believe mine are 28.5"x9" on "Cop" wheels. Two things. To put em on you have to jack the car up by each side individually. Also if you dont slow down enough before you turn around at the end of the track, they'll rub very slightly in the outer wheel house.
Re: 66 & 67 B body Cars rear slicks [Re: actionange] #1096875
10/19/11 08:33 PM
10/19/11 08:33 PM
MS
redex79 Offline OP
redex79  Offline OP
MS
I like that set up you have on your car. What kind of rims do you have? Here's a shot of one side of my wheel well and tire.
Thanks for input everyone.
Truckin Weekend !
21 Dodge Durango GT
Re: 66 & 67 B body Cars rear slicks [Re: CrAzYMoPaRGuY] #1096876
10/20/11 09:53 PM
10/20/11 09:53 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
The Charger is a completely different beast when it comes to rear wheelwells. I think a 28x9/15 on a 7 or 8 inch rim will work without hassle. Anything bigger is gonna be Hit and miss. In the fenderwell picture above, you can see that tire is rubbing pretty good (28x10?)
Re: 66 & 67 B body Cars rear slicks [Re: StealthWedge67] #1096877
10/20/11 11:53 PM
10/20/11 11:53 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
I think the Coronets are diff. too. Dodge quarter panels bulge out compared to a pretty straight Plymouth quarter panel. I've got 10" wide tires on my '66 Belvedere on Centerline rims and they just barely rub. That's next years project..
Re: 66 & 67 B body Cars rear slicks [Re: actionange] #1096878
10/20/11 11:55 PM
10/20/11 11:55 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
Great looking Belvedere!!!
Re: 66 & 67 B body Cars rear slicks [Re: 52savoy] #1096879
10/21/11 02:33 AM
10/21/11 02:33 AM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
Just be aware that although the qtr panel skin bulges out on the coronet, the inner wheel house bulges in toward the tire. Don't know why they did it that way, but they did.
Re: 66 & 67 B body Cars rear slicks [Re: 52savoy] #1096880
10/21/11 09:22 AM
10/21/11 09:22 AM
anywhere@ anytime
actionange Offline
actionange  Offline
anywhere@ anytime
Thanks. Here's how it looks now with Nostalgia Super Stock lettering.
Re: 66 & 67 B body Cars rear slicks [Re: CrAzYMoPaRGuY] #1096881
10/21/11 10:12 AM
10/21/11 10:12 AM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
I dont know if I have seen this car on here befor! Very nice!
67' charger 499 RB 10.57 at 127
Re: 66 & 67 B body Cars rear slicks [Re: dragram440] #1096882
10/23/11 01:26 AM
10/23/11 01:26 AM
Canada
Canada
Thanks!!!!!
I got it a few months ago, almost on the road... just waiting for the UPS truck to be nice and drop off a rad, waterpump housing and starter.... engine and trans are in and waiting.
Won't be running YOUR numbers or anywhere near, but I will hopefully be having fun!!!!
CrAzYMoPaRGuY
