Chrysler techs: Grand Voyager radiator question #109648
08/24/08 12:49 PM
08/24/08 12:49 PM
SoCal
68HemiB Offline OP
68HemiB  Offline OP
SoCal
First off, I know that the pro techs sometimes get grief and abuse around here, and then in a stunning bit of irony, get asked the next day for help fixing the wife's minivan. Let me point out that I have never been one of those to heap abuse, and (in younger days) know what it's like to earn a living out of one's rollaway (on an earlier generation of cars).
Anyway... I just got through pulling the radiator from the wife's '98 Grand Voyager. There is a stunning amount of carnage laying around the shop floor. In my defense, I will say that the rear hatch is not among the parts I pulled in my [successful] attempt to keep the A/C system intact. At fault, among other minor nuisances, were the two lower fasteners attaching the condenser to the radiator. Seeing how this thing is put together, I see two ways of doing the radiator R&R - pull the condenser with the radiator (including an A/C recharge with the job), or pull the nose of the van.
I would appreciate input on any or all of the following questions from real world techs:
1. Does R&R radiator automatically include recharge A/C, or do you pull the nose, or do you use some third method?
2. Can the transmission cooling lines be replaced with high-pressure fuel hose, or do they have to be molded, kryptonite-impregnated dealership hoses?
3. Is a cracked radiator tank (120k miles) on these vans rare as hen's teeth, common as dirt, or somewhere in between?
Thanks for your time.
Down to just a blue car now.
Re: Chrysler techs: Grand Voyager radiator question [Re: 68HemiB] #109649
08/24/08 02:03 PM
08/24/08 02:03 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
pull the front fascia and upper radiator support / upper tie bar then seperate the radiator from the condenser , it's not a bad job once the fascia is out of the way. recharging the A/C is not required
Hoses need to be trans fluid compatible, fuel hose will just deteriorate rapidily.
And No , cracked radiator tanks are not repetitive problems
Re: Chrysler techs: Grand Voyager radiator question [Re: gtx6970] #109650
08/24/08 05:33 PM
08/24/08 05:33 PM
Mass
charge70 Offline
charge70  Offline
Mass
You can use power steering return hose for transmission lines.It will work fine. John.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: Chrysler techs: Grand Voyager radiator question [Re: gtx6970] #109651
08/24/08 06:04 PM
08/24/08 06:04 PM
US of A
A38s! Offline
A38s!  Offline
US of A
The facia comes off surprising quickly, then again I'm in a world of my own...
WANTED: Your 71-78 Late B-body sedan parts! Police or Civilian.
Re: Chrysler techs: Grand Voyager radiator question [Re: A38s!] #109652
08/24/08 10:55 PM
08/24/08 10:55 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
cracked plastic tanks are common...
Re: Chrysler techs: Grand Voyager radiator question [Re: charge70] #109653
08/25/08 10:39 AM
08/25/08 10:39 AM
It's a dry heat
It's a dry heat
OE trans lines are 5/16" hoses and I'm not aware of power steering hoses that are not 11/32" hose. Unless there's something in the aftermkt I'm not familiar with
