Hoses need to be trans fluid compatible, fuel hose will just deteriorate rapidily.
You can use power steering return hose for transmission lines.It will work fine. John.
OE trans lines are 5/16" hoses and I'm not aware of power steering hoses that are not 11/32" hose. Unless there's something in the aftermkt I'm not familiar with
