Powder Coating leaf springs #1095962
10/16/11 11:04 PM
10/16/11 11:04 PM
canada
mridolfo Offline OP
mridolfo  Offline OP
canada
I was planing on taking apart my leaf springs and having them powder coated. My question is would the heat from the oven damage(De arch)the springs.
Re: Powder Coating leaf springs [Re: mridolfo] #1095963
10/16/11 11:49 PM
10/16/11 11:49 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
I can't speak to the question about the oven, but I would think the powder coating would crack and flake off with the flexing of the springs.
Re: Powder Coating leaf springs [Re: MarkZ] #1095964
10/16/11 11:56 PM
10/16/11 11:56 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Just paint-em with some good engine enamel ...
Re: Powder Coating leaf springs [Re: MarkZ] #1095965
10/17/11 02:09 AM
10/17/11 02:09 AM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Powder coating should be fairly flexible. At least the product I'm familiar with is. However, if the ovens raised the spring temp above 400 degrees f, then temper of the springs could become an issue as many spring steels temper anywhere around 400. 350 and lower,it shouldn't be a problem. Any metallurgists, powdercoaters care to confirm or deny?
Re: Powder Coating leaf springs [Re: mridolfo] #1095966
10/17/11 08:04 AM
10/17/11 08:04 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I was always taught the reason stressed items were not chrome plated was that the plating visually hid stress cracking. The same might be said for powder coating, but then who ever checks their leaf springs for telltale cracks?
I personally would not powder coat them
Re: Powder Coating leaf springs [Re: mridolfo] #1095967
10/17/11 08:08 AM
10/17/11 08:08 AM
detroit, mi
POS Dakota Offline
POS Dakota  Offline
detroit, mi
With paints out there as good as rust bullet and POR-15, I would go that route.
Re: Powder Coating leaf springs [Re: POS Dakota] #1095968
10/17/11 12:29 PM
10/17/11 12:29 PM
dogdays Offline
dogdays  Offline
The real reason you don't chrome plate suspension parts is because of HYDROGEN EMBRITTLEMENT. It works like this: when the part is being plated, hydrogen atoms migrate into the steel. There is enough space for a hydrogen atom to fit in the matrix. But the hydrogen atom isn't "happy" with being all alone and "wants" to join up with another hydrogen atom to make an H2 molecule. There isn't enough room in the matrix for that. Thus, the steel is internally stressed and can break with a brittle-appearing fracture at much lower stresses than the original steel part. To safely use chromed suspension parts the part has to be baked for several hours after plating to drive out the hydrogen atoms, even then you can't be sure.
R.
PS: To all those who know the correct ways to refer to the atoms, ions and molecules, I apologize as I can't remember after 35 years away from the classroom.
Re: Powder Coating leaf springs [Re: dogdays] #1095969
10/17/11 01:22 PM
10/17/11 01:22 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Another option is to blast the springs and leave them bare metal. Coat them with RPM so they don't rust.
Re: Powder Coating leaf springs [Re: burdar] #1095970
10/17/11 06:40 PM
10/17/11 06:40 PM
west kentucky
gomangoRTSE Offline
gomangoRTSE  Offline
west kentucky
Coat them with RPM? Im sorry, what is this?
Re: Powder Coating leaf springs [Re: gomangoRTSE] #1095971
10/17/11 08:06 PM
10/17/11 08:06 PM
Witness Protection Program
Kudakidd Offline
Kudakidd  Offline
Spend your money elsewhere. Powder coating a flexible part is asking for headaches.
Re: Powder Coating leaf springs [Re: Kudakidd] #1095972
10/17/11 09:59 PM
10/17/11 09:59 PM
canada
mridolfo Offline OP
mridolfo  Offline OP
canada
The oven temp would be 330 degrees. I work in a Ecoat - powdercoat shop so its not going to cost anything.
Re: Powder Coating leaf springs [Re: mridolfo] #1095973
10/18/11 01:41 PM
10/18/11 01:41 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
http://www.ecsautomotive.com/RPM/
Re: Powder Coating leaf springs [Re: dogdays] #1095974
10/18/11 05:55 PM
10/18/11 05:55 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
R.
Good reply, however that applies to most plating and should make many scratch their heads regarding using yellow zinc plated grade 8 bolts, etc. My plater says they after bake my grade 8, stressed stuff, but how does one really know?
Re: Powder Coating leaf springs [Re: jcc] #1095975
10/18/11 07:17 PM
10/18/11 07:17 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
I thought sand blasting is not good for springs, or torsion bars?
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Powder Coating leaf springs [Re: Rug_Trucker] #1095976
10/19/11 01:11 PM
10/19/11 01:11 PM
dogdays Offline
dogdays  Offline
Two comments:
Rug, I would not sandblast a torsion bar or leaf spring because if the sand is sharp enough it could put discontinuities in the surface that would initiate cracks. The exterior fiber is the most highly stressed.
However, shot blasting or peening may have a positive effect.
On the other topic, I have not understood that to be the case with yellow dichromate bolts, maybe that's why the ARP stuff is black? I wanna know.
R.
Re: Powder Coating leaf springs [Re: dogdays] #1095977
10/19/11 02:44 PM
10/19/11 02:44 PM
Minnesota
peabodyracing Offline
Minnesota
We blast and powder coat coil springs, leaf springs and torsion bars all the time here. We've done them for cars, 4 wheelers, motorcycles, trailers, mudders, etc. (JIT Powder Coating, Farmington, MN) In 10 years of catering to the hobbiest I've yet to have any come back for paint failure.
We use a crushed glass/plastic media combo for blasting which works very well for maintaining a good surface appearance. The cure cycle on most typical blacks like we put on springs is 18-20 minutes at 340-360 degrees F. This is the desired surface temp of the painted part, not the cure oven temp set point. This isn't enough temp or dwell time to affect the spring.
If you've ever visited a spring shop and seen how they're made I don't think you'd be concerned about cure oven temps.
As previously mentioned there is no similarity at all between chrome plating and powder coating.
Lead, follow or get the hell out of the way
Re: Powder Coating leaf springs [Re: peabodyracing] #1095978
10/19/11 04:05 PM
10/19/11 04:05 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
So which one is the one that you can see stress cracks beginning underneath?
Re: Powder Coating leaf springs [Re: jcc] #1095979
10/19/11 04:18 PM
10/19/11 04:18 PM
dogdays Offline
dogdays  Offline
It's been my experience that any brittle coating will show cracks when the substrate deforms. I use it to discover where deformation has occurred. Chrome either cracks or flakes. Powder coat cracks unless it is very elastic. Paint cracks. Even mill scale, the blackish stuff on the surface of hot rolled steel, will crack if the part deforms.
Of course, I was using something I had already learned. An older way of determining strains in parts (before finite element analysis) was to make a part and coat it with special paint called "brittle coat". Then load the part. Remove the load and inspect the part. Cracks in the brittle coat would be perpendicular to the strain. One could tell from the cracks what strains were occurring.
R.
Re: Powder Coating leaf springs [Re: dogdays] #1095980
10/20/11 01:12 AM
10/20/11 01:12 AM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline
Powder coating leaf springs should be just fine! I had it done on two cars, one over 10 years ago. Still looks as good as the day it was done, no cracking whatsoever. Same with the torsion bars. No sag in the springs either. I wouldn't go any other route except for a true 100 point OEM resto.
Re: Powder Coating leaf springs [Re: Barnabas_Kriss] #1095981
10/20/11 02:20 PM
10/20/11 02:20 PM
NORTHERN VA
THESHAKERPROJECT Offline
NORTHERN VA
I would do it if the springs are pit free after blasting (most are not) and BTW, after you blast and powdercoat , get a re-build kit with the interleafs and straps you may have over $500 into a set of old worn out springs.
